Old 05-01-2006, 01:48 PM   #13966
TRF415boy's Avatar
Originally Posted by Crashmaster
Missed that part, lol.
B on rear front (flipped with spacers)
C on front front
X on front rear
B on rear rear
Previosuly ran A-B on front with 5mm hexs, but I found the 46mm bones were too long, so made the switch to B-C with 4mm hexs to try and keep the track the same.
Used locked centre pulley and spool aswell.
Cheers
Dan Chambers
What spool you using ? 46mm bones shouldn't be too long with any spool with those blocks on.
TRF415boy is offline   Reply With Quote
Old 05-01-2006, 01:57 PM   #13967
Crashmaster's Avatar
The original one-way lubricated with epoxy resin, lol. Its from the original 415, I thought I read somewhere that the outdrives for use with the LW suspension was different.
Trying to get hold of a Tir spool, but they haven't emailed me back, as for the tamiya one, only got 1 good outdrive left....
Cheers
Dan Chambers
Crashmaster is offline   Reply With Quote
Old 05-01-2006, 01:58 PM   #13968
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Ok I'm confused and since I'm gonna get a MSX soon I should ask. David used Pro4 arms on his car, but why? What does it do for the car? And what parts do you need to make it work?
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 05-01-2006, 02:01 PM   #13969
David:
From what I understand, the HB/hpi arms on the car make it better for indoors on carpet, mainly with rubbers I beleive due to slightly different length and shock mounting positions
. As the inner hinge pin on the 415 and the pro 4/cyclone is the same, its just a case of dropping and shimming the HPI arms (with hubs etc) onto the car. I think you need the cyclone axles to do it aswell as the bearings for the hubs.
Dan Chambers
Old 05-01-2006, 02:16 PM   #13970
TRF415boy's Avatar
Cheers
Dan Chambers
Yeah the outdrives for the std 415 are different, you'd want to use 42mm bones. As for your setup, if you were round stafford i wouldn't recomment anything else than 3 deg rear toe in mod.
Old 05-01-2006, 02:18 PM   #13971
TRF415boy's Avatar
If I were you i'd just wait for the new wishbones that are coming out, I reckon they'll sort the issue on carpet. If you're racing anything else than carpet rubber keep the LW.
Old 05-01-2006, 02:20 PM   #13972
Cheers mate, wondered if the rear toe was abit lack luster. Made for some cool drifting though.
Old 05-01-2006, 02:22 PM   #13973
TRF415boy's Avatar
Well if it was very bad i'd check my hinge pins for straightness.
Old 05-01-2006, 02:24 PM   #13974
I'll do that aswell. I had also change the front wheel base (moved the arms 1mm back) in a practice session before yesterday. Do you think moving them back forward 1mm to take some weight off the front end would make it better?
Old 05-01-2006, 02:45 PM   #13975
TRF415boy's Avatar
it might but it won't make a big difference.
Old 05-01-2006, 03:37 PM   #13976
Default a 415 msx built by billy easton in the for sale section
It's brand new and looks great
mrfastrc51 is offline   Reply With Quote
Old 05-02-2006, 02:11 PM   #13977
Stein Tumert's Avatar
Originally Posted by TryHard
hmmm... looks familiar... good thing I don't care who uses the chart
Aha...so now we know Mr. Sunshine had a source for this...
Stein Tumert is offline   Reply With Quote
Old 05-02-2006, 11:59 PM   #13978
Hey guys, does anybody know where I can find a spool for a 415msx? Everywhere I look they are out of stock. THX
Charles is offline   Reply With Quote
Old 05-03-2006, 01:58 AM   #13979
Can you tell me if this spool can be used in msx?
http://www.hobbymania.com.hk/eng/more.asp?id=424
TA05 Front Direct Coupling
I would like to use standard diff pulley or one way pulley (black).
I'm looking for this spool because i can't find spool that is made for msx.
Tral is offline   Reply With Quote
Old 05-03-2006, 02:20 AM   #13980
Default Spool
http://www.titaniumracing.com/
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
