Like Tree3Likes
Tamiya TRF415
Old 04-30-2006, 01:35 PM
  #13951
tamiyarcracer's Avatar
Originally Posted by Charles
I just finished building my Tamiya shocks for my new 415 MSX. Wow they are nice and easy to build, very smooth. I am impressed.
What hobby shops carry Tamiya 415 msx refinr 2 parts in Souther California? I will be there on business in the coming week and I would like to pick up some parts as Speedtech is out of the parts I need.
Thx
Go Directly to Tamiya if you want, they are in Aliso Viejo (Orange County) And while you are there admire the track.
tamiyarcracer is offline
Old 04-30-2006, 07:17 PM
  #13952
TRF415boy's Avatar
Originally Posted by Charles Godwin
Yea, i thought you said he was using hotbodies wishbones? I must have mis-read it
Charles
That's exactly what i said, the team drivers had hot bodies/pro 4 wishbones on their cars.
TRF415boy is offline
Old 04-30-2006, 07:28 PM
  #13953
JoeyE's Avatar
Trader Rating: 45 (100%+)
Very nice track! Hey, theres me and theres my car
JoeyE is offline
Old 04-30-2006, 09:32 PM
  #13954
JRRobiso's Avatar
Post TA05 Alum Transponder Holder
Quick question.
Would the TA05 alum transponder holder fit on the 415?
Thanks.
JRRobiso is offline
Old 04-30-2006, 10:20 PM
  #13955
Kevin CBR's Avatar
Thx
The only other shops that would carry any 415 parts are Ultimate Hobbies in Orange and So Cal Raceway in Huntington Beach. However, check with Steve to see if he has a shipment coming in just before you arrive.
Kevin CBR is offline
Old 04-30-2006, 10:22 PM
  #13956
Burlap's Avatar
Originally Posted by JRRobiso
Quick question.
Thanks.
I don't know, but I used to use a RC Square 415 Transponder holder/servo stay. You can find them at Rainbow Ten or Speedtech RC.
Burlap is offline
Old 05-01-2006, 12:50 AM
  #13957
C van der Hagen's Avatar
Originally Posted by TRF415boy
with hb wishbones on his car...
Does anyone have some pics or set-up of Marc's car used at the LRP Masters 2006?
C van der Hagen is offline
Old 05-01-2006, 05:55 AM
  #13958
Heres one
PhatPat is offline
Old 05-01-2006, 08:49 AM
  #13959
linger's Avatar
Looks like Tamiya is FINALLY releasing an aluminum FRONT diff for the 415.
Translated from the Tamiya Japan website:
< Temporary > TRF415 front aluminum diff. joint
Item No.53921
July 1st (Saturday) Around Sale * 2,625 Yen (2,500 Yen in substance price)
June 28th (water) Dispatch * JAN cord/code: 4950344539215
linger is offline
Old 05-01-2006, 09:06 AM
  #13960
JoeyE's Avatar
Item No.53921
NICE! Should be better then the YOKOMO set up one that I am using now.
JoeyE is offline
Old 05-01-2006, 09:50 AM
  #13961
Davids car. HPI suspension and old steering.
Rick Draper is offline
Old 05-01-2006, 11:23 AM
  #13962
Crashmaster's Avatar
set-up question
Evening all,
Got a question for you on setup. Had first outdoor race yesterday, and had a few issues with the car. Was fast as anything else there (which I was quite pleased with), but I did seem to suffer with a lack of rear end grip, would have the tendacy to almost snap round on the entrance to the corner. Other times it would just loose all rear end grip for about a lap, however I think that was more to do with the intermitant rain....
my setup was:
Front:
LW suspension, mounted on 3rd hole
3rd hole on shock towers
B-C blocks
4mm hex's
60wt oil, 3 hole pistons
yellow springs
-1 deg camber
4 deg hubs
ride height 5.5mm
droop 5mm
Rear:
LW suspension, 3rd hole
3rd hole on tower
X-B blocks
1 deg hubs
middle hub hole
5mm hex
60wt, 3 hole shocks
yellow springs
-1 deg camber
droop 4mm
Other:
std MSX role centre and inner stud position
Peak DS 8x1
Mazda 6 body with std wing
3mm chassis
I was thinging that a change to X-C block (2.5 deg rear toe) would do a good move, aswell as maybe lengthening the wheel base, but don't know if thats the way to go?
Cheers
Dan Chambers
Crashmaster is offline
Old 05-01-2006, 11:36 AM
  #13963
On Davids car pictured above - Is he using a QC2 or 3 speed control? Does anybody know which companies fans those are?
Thx
Charles is offline
Old 05-01-2006, 12:38 PM
  #13964
TRF415boy's Avatar
Originally Posted by Crashmaster
Evening all,
my setup was:
Front:
B-C blocks
4mm hex's
yellow springs
-1 deg camber
4 deg hubs
ride height 5.5mm
droop 5mm
Rear:
3rd hole on tower
X-B blocks
1 deg hubs
middle hub hole
5mm hex
60wt, 3 hole shocks
yellow springs
-1 deg camber
droop 4mm
Other:
Peak DS 8x1
3mm chassis
Cheers
Dan Chambers
You say B-C blocks on the front end ? which one where and how did you put the one on the rear ?
Old 05-01-2006, 12:44 PM
  #13965
Missed that part, lol.
B on rear front (flipped with spacers)
C on front front
X on front rear
B on rear rear
Previosuly ran A-B on front with 5mm hexs, but I found the 46mm bones were too long, so made the switch to B-C with 4mm hexs to try and keep the track the same.
Used locked centre pulley and spool aswell.
Cheers
Dan Chambers
