Old 04-06-2006, 03:18 AM   #13696
csdspeed's Avatar
Send a message via Yahoo to csdspeed
Thanks for the suggestions. . My current final drive ratio is 6.56 34T pinion and 102T spur. My stock motor is a T-MAX. Is the ratio alright for this motor for those who have tried this kind of motor? Or should I lower the ratio more?
csdspeed is offline   Reply With Quote
Old 04-06-2006, 07:22 AM   #13697
t4m1y4niac's Avatar
try around 6.3...
SABRE S4 by TOP RACING....
t4m1y4niac is offline   Reply With Quote
Old 04-06-2006, 07:12 PM   #13698
dodo's Avatar
Send a message via Yahoo to dodo
the best is to ask the people at your track on which ratio works best. If you ask me what ratio, i tell you 5.3-5.5 cos that's the ratio the people at my track using. So it really depends on the motor and on the track itself. cheers
dodo is offline   Reply With Quote
Old 04-07-2006, 07:20 AM   #13699
t4m1y4niac's Avatar
guys, i'm desperate with my MSX, the understeer problem is killing me. i'm running rubber (sorex 36R) with a lot of air gap (orion soft inner)-smooth medium grip asphalt-front one way-mid one way pulley-standard anti roll bar-no spacer in camber link front bulk head-2.5mm spacer on rear hub-4' caster-1.5' camber on all wheels-0.5' toe out-40wt 3 hole pistons yellow spring-5mm ride height front&5.5mm rear-9T motor.
please help me to solve my understeer.
Old 04-07-2006, 07:36 AM   #13700
Charles Godwin's Avatar
You could move the front shocks in one hole and move the rear shocks out one hole on the shock towers also shorten the rear wheelbase 1mm.
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 04-07-2006, 07:40 AM   #13701
Cool Bumper
Hi.
Look the Bumper !
http://www.rczone.net/files/tamiya/t...eassen0505.pdf
TEAM GONZO
Team GONZO is offline   Reply With Quote
Old 04-07-2006, 08:15 AM   #13702
Eirik's Avatar
Try a different bodyshell, Mazda 6 gives allot of steering!!
Removing the swaybars also helps sometimes....
The Orion inserts works really good in Sorex tires, very good balance, but you could also try the Bomber Red inserts or the Hara Grey Ver.2 as they have given me allot of steering. Sometimes too much!!
Eirik is offline   Reply With Quote
Old 04-07-2006, 08:53 AM   #13703
Trader Rating: 37 (100%+)
Eirik,
What's up man...finally ran your MSX 3mm/standard suspension setup a few weeks back. With some minor camber link changes it worked real well.
Thanks again.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 04-07-2006, 11:08 AM   #13704
Martin Crisp's Avatar
It is hard to tell if you are running a sway bar front and rear from the description. I will assume front and rear. Also I assume from you description that you are running no spacers on the inside mounting point of the upper links both front and rear.
Some things to try...
Reduce the rear toe to 2.0 degrees if you have not alrady done so.
Add a rear sway bar if you don't use one.
Remove both swaybars..
If the push is on power then reduce the front droop.
If the push is off power then increase the rear droop.
go to .7mm spacer on rear uprights/hubs.
just some thoughts...
Martin Crisp
Power-Story.com | LearnSetup.com
Martin Crisp is offline   Reply With Quote
Old 04-07-2006, 03:26 PM   #13705
Eirik's Avatar
Hello Anthony,
Well not much is happening here at the moment actually! Indoor season is over and we still have to wait for the snow to melt before we can run outdoors....
Glad the setup worked good for you!!
Noticed you where selling allot of your Tamiya stuff.... whats the reason for that??
Catch you later
Old 04-08-2006, 08:22 AM   #13706
t4m1y4niac's Avatar
thanks a lot guys....i already record all the tips from all of you, monday i'll practice again and i'll give a reports. thanks a lot.
Old 04-08-2006, 08:26 AM   #13707
t4m1y4niac's Avatar
hai martin, now in my MSX is using yellow front sway bar & red rear sway bar.
about the .7mm spacer, you mean just using .7mm spacer or add .7mm spacer bcoz now i'm using 2.5mm sapcer on my rear uprights. thx a lot martin.
Old 04-08-2006, 04:35 PM   #13708
Hey,
If you are using a red swaybar on the back, in my experience it does not really do much given it is so thin. I would try the yellow swaybar to get more steering. In terms of the spacers, I was suggesting to just use the 0.7mm spacer on the rear uprights. What if any spacers are you using where the upper links attach to the bulk heads on both the front and back of the car? By the way are you running on carpet or asphalt? Can you run softer rubber?
M
Martin Crisp
Old 04-08-2006, 08:37 PM   #13709
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Sorry for the interruption...............I am looking for the small round pivots that go on the suspension shafts. The pieces that go inside the mounts # 1/a 1/b and so on..................Thanks Guys.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 04-08-2006, 10:27 PM   #13710
t4m1y4niac's Avatar
Hey,
M
i guess i must buy the sway bar set.i'm not using any spacer on the front bulkhead, bcoz a thought it can eliminate the understeer problem.on the rear bulk head i'm using the standard spacer set up from the book (i forgot how much mm is). on the rear upright using 2.5mm spacer to eliminate the oversteer problem,when using the standard spacer my rear always lose when cornering.
i always running on asphalt. i can't run softer rubber like 32R, 28R or 25R bcoz the track temp is relatively high about 48'C - 60'C
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
