Old 03-28-2006, 06:34 AM   #13561
bomberman's Avatar
hows everything going tamiya users?
bomberman is offline   Reply With Quote
Old 03-28-2006, 07:32 AM   #13562
Charles Godwin's Avatar
The Speedtech Ti screw set is very good, light weight, strong and looks cool
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 03-28-2006, 07:33 AM   #13563
TRF415boy's Avatar
Originally Posted by t4m1y4niac
haii i'm having the same problem with you, even i'm using Mugen 2mm hex driver its not helping so much. now i have 3 countersunk screws stuck in my MSX
Buy a 3mm drill bit, drill the head of the screw, it will pop off and you'll only have to take the rest of the screw with a pair of pliers.
TRF415boy is offline   Reply With Quote
Old 03-28-2006, 07:34 AM   #13564
Trader Rating: 27 (100%+)
Originally Posted by Charles Godwin
The Speedtech Ti screw set is very good, light weight, strong and look cool
Charles
.........yea, I stripped a few of those with my Hudy
JoeyE is offline   Reply With Quote
Old 03-28-2006, 08:06 AM   #13565
Jimmy Jacobson's Avatar
Hey Joey
Jimmy Jacobson is offline   Reply With Quote
Old 03-28-2006, 08:25 AM   #13566
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
Mr. Jimmy Jacobson...YANKEES RULE...call me if your coming over to the east coast...201-788-5525
Just want to confirm the part numbers for the TA-05 pulley conversion for the MSX…I already have the rear diff and front on-way pulley…need to confirm the part numbers for the center layshaft? (I forgot to order them)
I looked on line and found 2x part numbers 51213 and 53841, see photos below…not sure which parts I need? Also, do I need the TA05 layshaft #51214 to make the conversion work?
On another note, I’m a little confused with why some earlier Tamiya users had problems fitting the concentric hubs with the TA05 pulley between the MSX alum bulkheads…If you using the MSX front one-way unit with the TA-05 pulley the item should fit properly without the need to modify the concentric pieces? I have not yet done this modification as I’m waiting to order the center one-way pieces…
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 03-28-2006, 08:29 AM   #13567
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
I think ill have to go for this option, as the 2.5 chassis is in mint condition so i dont want dremel score marks. Thanks for the link to the heat option, but unless i can get a good cut with the dremel and not take out the chassis, it'll be "OFF WITH THEIR HEADS!"
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 03-28-2006, 08:31 AM   #13568
TRF415boy's Avatar
I can answer the second question. The one way on the 415 takes the pulley in sandwich. That means the overall width of the one way unit depends on how thick the part of the pulley that is taken in sandwich is. Now the TA05 pulley is a tad thicker which increases the distance between the bearings, whilst the distance between the bulkheads remains the same (obviously). Other problem is the one way pulleys have a difference of 1mm in the diameter of the hole which is why it wobbles.
Old 03-28-2006, 08:32 AM   #13569
axle182's Avatar
Pic number one is just the locked pulleys, you need the TA05 spur mount. The pulleys slide onto this. The second pic is the TA05 centre one way so that doesnt help you. Thirdly the TA05 one way pulley (im told) is wider where it bolts between the one way halfs, which means it takes up ALL the slop in the mounts. havent gotten around to this yet, its on my list of things to do
Aaron "AJ" Freind
Old 03-28-2006, 08:34 AM   #13570
Originally Posted by Jimmy Jacobson
Hey Joey
Hey Jimmy, what's up? Long time no see. Miss pitting with you in Newark or was it you missing pitting with me, hahaha. Got a new MSX yesterday
Old 03-28-2006, 12:11 PM   #13571
Stein Tumert's Avatar
Originally Posted by Team GONZO
Stein Tumert
Made in Switzerland !
Yeah!! Some good things come from that place as well
Stein Tumert is offline   Reply With Quote
Old 03-28-2006, 12:19 PM   #13572
Originally Posted by tcmerf
I It looks like the outer holes are the same regardless of whether it is a one way pulley or a diff pulley. Can someone verify this?
Believe I looked at it and found that the MSX one way hardware does not fit the TA05 diff pully (screw holes), but not 100% sure...
Old 03-28-2006, 12:20 PM   #13573
415boy & axle..thanks for the response. I now understand the issue...with using the 415 front one-way and TA05 pulley....has anyone tried to used the front one-way for the TA05 on a 415MSX? Not sure if they are the same.
I will most likely use the Tamiya spool up front so I won't have this problem...your feedback helps if I decide to use the front one-way. Thanks
So now if I use the front spool, I need to get the TA05 locked center pulley. To get the proper 2.25 drive ratio which everyone is looking to achieve.
Or....I can just stick with the stock 415 stuff...although the white diff pulley's look trick
Old 03-28-2006, 12:25 PM   #13574
Here is the parts list you need for the center pully from our excellent man in Switzerland, Mr, Sunshine:
- 51214 Centershaft
- 9808019 Centershaft-C-rings
- 9808018 Centershaft-Spacer (alu 2,8mm wide)
- 51213 Centerpullys (2pcs.)
- 3455870 Spurgear-holder
- 53874 precision-bushing (1pcs.)
- 9805672 BB 840 (2pcs.)
- 51211 Spurgear-screws
- 53586 spacer for centershaft
Stein
Old 03-28-2006, 01:01 PM   #13575
TRF415boy's Avatar
You can either use the 415 or TA05 pulleys on the layshaft you'll have the same ratio.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
