Old 03-28-2006, 01:48 AM   #13546
Originally Posted by Black Adder
How many teeth do the TA05 diff and center pulley have?
Thanks.
Black Adder is offline   Reply With Quote
Old 03-28-2006, 01:50 AM   #13547
dodo's Avatar
Send a message via Yahoo to dodo
diff pulley : 36
center : 16
dodo is offline   Reply With Quote
Old 03-28-2006, 01:58 AM   #13548
Originally Posted by dodo
diff pulley : 36
center : 16
Thanks.
Old 03-28-2006, 04:14 AM   #13549
TryHard's Avatar
Originally Posted by axle182
Raise your hands if you having trouble with the screws on the underside of the chassis? Ive stripped the hexes in my last screws, ive had enough. seems the alloy is sticking to the screws inside, and even with a very decent hex driver, ive managed to round all but 3 screws on the underside of my newly aquired MSX. Can anyone advise whether the new blue Ti screw kit will be better for this problem? Or has anyone chosen a different screw type for the chassis? Has anyone tried applying a drop of oil to the thread before screwing it in, or will this allow the screws to come out too easy? Im speaking of the small machine countersunk screws which hold the bulk heads, and suspension blocks. Thanks
The blue Ti screw kit you speak of is actually a combination of blue aluminium screws for the top, and silver titanium screws for underneath. However, I will say there are of good qulaity. I'm personally using them at the moment, and a full screw kit from RC champ worked out at about 25
Apart from that, try putting some light grease on the screws, diff lube is quite good for this.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 03-28-2006, 04:25 AM   #13550
TryHard's Avatar
Originally Posted by kid TT-01
let me refraise my post, I AM A NEW OWNER OF A MSX .
some pics
http://rctech.net/forum/showthread.php?t=107487
What type of carpet racing are you doing? Foam or Rubbers?
TBH, I've found my MSX with the LWT suspension to be well suited to racing on carpet, it just needs a fair bit more tuning compared to the std/orignal 415 suspension.
My current carpet setup isn't too far off one I got from David Spashett, but tuned more towards my driving style, and running stock.
I've been meaning to put the setups up on my site, but have been too busy recently to do anything about it.
I'll post it on here if you want to try it out, bear in mind it is for rubber tyres.
HiH
Ed
Old 03-28-2006, 04:42 AM   #13551
Default 415ms
hi im needing help i was just wodering if there is any down sides or up sides by using metal c hubs on a 415 ms on carpet any help would be good
thanks matt
snap_u2000 is offline   Reply With Quote
Old 03-28-2006, 05:12 AM   #13552
t4m1y4niac's Avatar
haii i'm having the same problem with you, even i'm using Mugen 2mm hex driver its not helping so much. now i have 3 countersunk screws stuck in my MSX
SABRE S4 by TOP RACING....
t4m1y4niac is offline   Reply With Quote
Old 03-28-2006, 05:18 AM   #13553
t4m1y4niac's Avatar
Originally Posted by veecee
Sometimes there is a tendency to overtighten screws to the point where they bind into each other especially when you don't use threadlock. As strange as this may sound, I think you're much better off using threadlock and not over tighten your screws. Anyway this is just my experience.
is there any tips how hard we can tighten our screws? i'm affraid if we did not tigthen them properly, the chassis can be tweak or something.
Old 03-28-2006, 05:33 AM   #13554
veecee's Avatar
Trader Rating: 34 (100%+)
This may help if u have seen this already http://rctech.net/forum/showthread.php?t=107632
veecee is offline   Reply With Quote
Old 03-28-2006, 05:36 AM   #13555
Trader Rating: 27 (100%+)
I never used the stock black TAMIYA screws since the 414M. They strip to easy so I used all stainless. On my TRF415 was all titanium throughout. You can still strip the heads if you do not have a good hex drive. On my MSX, I am using the hop-up screw kit, titanium & aluminum. What I am going to do though, I am going to use stainless just only on the bottom.
Never use any type of locktite. I srew it in all the way and then give it a quick little turn to make it tight. I never any break or strip since the first 415 series. (knock on wood)
JoeyE is offline   Reply With Quote
Old 03-28-2006, 05:38 AM   #13556
veecee's Avatar
Hard to say but I usually tighten screws by holding the driver using the ends my fingers only, rather than grabbing the driver in my hand.
Old 03-28-2006, 05:46 AM   #13557
t4m1y4niac's Avatar
i see so you can control your power just with your finger right so you not overtighten the screw. ok i'll remember it thanks....
Old 03-28-2006, 05:51 AM   #13558
t4m1y4niac's Avatar
maybe i'll try the Ti screw since it easy to buy...and light weight too than stainless. thanks.
Old 03-28-2006, 06:12 AM   #13559
dodo's Avatar
just realized that i lost 1 tamiya Ti screw on the rear bulkhead...
Old 03-28-2006, 06:30 AM   #13560
t4m1y4niac's Avatar
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
