Old 03-27-2006, 10:02 AM   #13531
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
Raise your hands if you having trouble with the screws on the underside of the chassis? Ive stripped the hexes in my last screws, ive had enough. seems the alloy is sticking to the screws inside, and even with a very decent hex driver, ive managed to round all but 3 screws on the underside of my newly aquired MSX. Can anyone advise whether the new blue Ti screw kit will be better for this problem? Or has anyone chosen a different screw type for the chassis? Has anyone tried applying a drop of oil to the thread before screwing it in, or will this allow the screws to come out too easy? Im speaking of the small machine countersunk screws which hold the bulk heads, and suspension blocks. Thanks
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 03-27-2006, 11:52 AM   #13532
Ballsie's Avatar
Default 4mm Chassis arrived
My 4mm Chassis arrived today from Ricky @ speedtech, shame my 415 MSX is pretty much retired
Those suspension shafts are also included, I haven't measured the size of them yet so I'm not sure if they are a new design or not.
Ballsie is offline   Reply With Quote
Old 03-27-2006, 12:07 PM   #13533
Probably cause the blocks are the old 415 distance apart? So people can use the old suspension and still have wheel base adjustment.
Rick Draper is offline   Reply With Quote
Old 03-27-2006, 12:34 PM   #13534
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
The suspension pins included with the 4mm chassis are the same length as the suspension pins used on the standard 415 (ie: non-LWT suspension.) I like the fact that the 4mm chassis allows one the felxibility to run both types of suspension systems.
My only concern: next year, Tamiya will release a new steering rack (as used by Tamiya drivers in Thailand.) the 4mm and other chassis are not drilled for this.
The 4mm is really nice...top-notch Tamiya quality.
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 03-27-2006, 02:04 PM   #13535
I didnt think about cutting the bearing holder. That probably makes more sense. I do think it would be better to use the diff pully though and ream out the center hole so it can ride on the one way. It looks like the outer holes are the same regardless of whether it is a one way pulley or a diff pulley. Can someone verify this?
FT B44 - FT J82
LRP TC SPHERE - Futaba Fasst
Orion Lipo & Vortex motors
" Go that way really fast, if something gets in your way, turn"
tcmerf is offline   Reply With Quote
Old 03-27-2006, 03:27 PM   #13536
Burlap's Avatar
Send a message via MSN to Burlap
I have had no issues with either the standard steel kit screws or the RC Champ titanium hex screws on my car. I use a Hudy 2mm driver for all of them, and that driver gets some work, because another friend of mine with an XRay is too lazy to by his own 2mm driver.
Burlap is offline   Reply With Quote
Old 03-27-2006, 06:35 PM   #13537
A Ilievski's Avatar
Trader Rating: 39 (100%+)
hi guys hows it going, just wondering im aboutn to own a msx and i wanted to know if theres anything i need to change on it for carpet racing.
all help would be apreciated
Alex Ilievski
*INFINITY * R1 WURKS * PLAIG BEARINGS* SPEEDY RC
A Ilievski is offline   Reply With Quote
Old 03-27-2006, 06:35 PM   #13538
A Ilievski's Avatar
sorry double post
Alex Ilievski
Old 03-27-2006, 06:45 PM   #13539
veecee's Avatar
Trader Rating: 34 (100%+)
Sometimes there is a tendency to overtighten screws to the point where they bind into each other especially when you don't use threadlock. As strange as this may sound, I think you're much better off using threadlock and not over tighten your screws. Anyway this is just my experience.
veecee is offline   Reply With Quote
Old 03-27-2006, 07:37 PM   #13540
A Ilievski's Avatar
let me refraise my post, I AM A NEW OWNER OF A MSX .
some pics
http://rctech.net/forum/showthread.php?t=107487
Alex Ilievski
Old 03-27-2006, 08:05 PM   #13541
Burlap's Avatar
So you have posted three times already on the same page. We get it already. Now properly read this thread for your answers.
Old 03-27-2006, 08:09 PM   #13542
dodo's Avatar
Send a message via Yahoo to dodo
you need to use TA05 one-way pulley to fit the MSX one-way unit, but you also need to thin the center part of the pulley because with the standard thickness, it will not fit properly. (msx oneway pulley is thinner than TA05 oneway pulley)
dodo is offline   Reply With Quote
Old 03-28-2006, 12:04 AM   #13543
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
they said that the old suspension works better in carpet rather than the low weight suspension that is already included in your msx plus new 4mm chassis is best suited for carpet racing
buboy28 is offline   Reply With Quote
Old 03-28-2006, 12:07 AM   #13544
buboy28's Avatar
is there any advantage if i used the TA-05 pulleys in place of the stock MSX pulleys
Old 03-28-2006, 12:49 AM   #13545
dodo's Avatar
from previous page
http://www.rctech.net/forum/showpost...ostcount=13521
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
