Tamiya TRF415
same with the turnbuckle tie ends and the ball connecters.... so much slop
19 TURN MS ROLLOUT
Hey what are you guys running for a final roll-out for your 415/ 19turn/ rubber.
Because I was running 33.00 roll out. It was working great for my sedan.I am running a dynasty 19 turn and the motor was operating around 150deg it was running perfectly, and then suddenly the motor got extream hot after the next run, like it was running 215 deg. Whats the cause Of that??? I was running Reedy 767's, brush hood aligned, and comm was cut.
Of course the got motor really hot and a little bit of smoke came out, but the weird thing is the brushes were not burnt or discoloured around the face of the brush. But they were DISCOLOURED AT THE BACK WHERE THE SHUNT ENTERS. crazy
thanks
edward pickering
thanks
edward pickering
Anyone find a way to get rid of ALL OF THAT SLOP in the steering? i mean mine is HORRIBLE SO MUCH PLAY!!!
http://www.speedtechrc.com/store/ebp...id=188&id=1435
traction roll
Originally Posted by Martin Crisp
Hey Stein,
I my testing with the old v.s. the lw arms, I found that on very high grip indoor carpet (rubber tires) that the old arms caused the car to traction roll more easily than the lw arms. Have you experienced this?...or the opposite?...just curious.
First, thanks for the great book you have written! Since I got your book, I now know what I am doing with my car!!
One want of course to get around the track as fast as possible and in our experience we do go faster when the car is a bit looser (a bit oversteer/rear slide into the curve). Our experience was that with the LW arms we had too much grip, we could not get the car loose enough to go fast around the corners. Especially visible with some of my faster buddies here With the old suspension we have found setups that allows us fairly easy to get that loose feeling and get around the corners faster. I would not say we are bothered with traction roll, basically trying to have the roll center not too low.
This all for carpet/rubber, track a bit on the technical side with medium to high grip. We are running mostly Sorex 28 or LRP VTEC 27 tires. We are also running the standard 2.5 mm MSX chassi (no foam tires here). If you are interested in our basis setup, PM me your email address.
Stein
Someone please help!, I have a newly purchased 415 and I ran it for the first time today on asphalt with a one-way up front with a center one way and runs great on power but when I hit the brake the rear just wants to slide out. I put a spool up front and it still wants to slide out badly ( uncontrollable ) . Im wondering if I should take out the Center one-way and keep the spool up front so I will have 4 wheel braking. Please let me know, greatly appreciated.
-Brett
-Brett
-Brett
-Brett
Hope this helps.
-Brett
-Brett
Dial out the brakes and reduce the rear droop. Less rear droop stops the forward weight shift and dialing out the brakes obviously keeps the back tires from locking up.
Originally Posted by JRRobiso
If you want 4 wheel braking, then replace the center pullies with a fixed Tamiya center pulley. But if you like how the original drive train performs (front one-way & center one-way) then try driving the car without using the brakes. The driving style with the one-way drive train is to let the car coast thru the turns & let go of the throttle a good distance before your approach the turns. Also the one-way drive train is more suitable for large flowing tracks. For tight technical tracks, then you'ld want to use the front spool & fixed center pulley.
Hope this helps.
Hope this helps.
Originally Posted by tony q
jun, kamusta na.
Ayos lang.
are you planning to come down here for the TCS NATIONALS?
Hey guys, any ideas on what I can use as an improvised spacer or some replacement spacer for the hex hubs? I'm not choosing to buy longer hubs, so now I need to find some spacer that I can use (I think 2mm spacer). If there's a part number for it, the better. Thanks.
I went out and got the pulleys for the TA-05. How are you guys mounting them. The front pulley does not share the same mounting holes. Should have known it was to simple! Factory guys always have unobtanium! I guys thats why they are factory.
