Old 03-16-2006, 03:12 PM   #13351
linger's Avatar
Originally Posted by Nexus
What you put together actually looks and I'm sure would work really well. From Liverc.com they said maybe it's Jimmy J's car.
Interesting to see how all the TRF drivers who are fast rubber tire racers do on carpet using foams.
Jimmy's car is different. That car shown is definitely EJ Evan's car.
I used to be a spitter, now I'm a swallower. I graduated.
linger is offline   Reply With Quote
Old 03-16-2006, 03:23 PM   #13352
Burlap's Avatar
Send a message via MSN to Burlap
Originally Posted by Smoking motor..
Done that with my screws Damn hudy driver!!!
Haven't had that issue with my Hudy driver, and the XRay drivers at my club sometimes use it as well. They also seem to use hammers on their outdrives too
Burlap is offline   Reply With Quote
Old 03-16-2006, 03:28 PM   #13353
nikkiesteban's Avatar
Send a message via Yahoo to nikkiesteban
what pinion should i use on my stock johnson 540 for my 415... my spur is 102t... i want top acceleration and speed.. tnx =)
nikkiesteban is offline   Reply With Quote
Old 03-16-2006, 03:50 PM   #13354
You only could have one or the other You can't have both top accerleration and top speed. I say 39T pinon will be a good starting point.
trf_racer is offline   Reply With Quote
Old 03-16-2006, 05:44 PM   #13355
Burlap's Avatar
Depends what class you are racing in. Are you racing it?
Some novice classes have a gearing limit, so check that first.
In regards to 540 Pro, where gearing is open, depends on the track. If it is a twisty tight track, I'd run 4.4-4.5:1, with an open track, closer to 4.2:1.
Check www.gearchart.com for gearing on the 415. Just choose the Tamiya 415 option, as the gearing is the same for all models of 415, unless you are running TA05 stuff in it.
Old 03-16-2006, 05:52 PM   #13356
Kevin CBR's Avatar
Originally Posted by csdspeed
Is this correct? And do I still need the 51092 TB Evo 4 46mm Swing Shaft? My 415 is the original version.
46mm swing shafts are needed for the lightweight suspension (MS / MSX). If you are runing the original 415 "regular" suspension, you will use 42mm.
Panda Performance / Nemo Racing top secret R&D lab hidden in a lush bamboo forest....
Scorpion Power Systems
Kevin CBR is offline   Reply With Quote
Old 03-16-2006, 11:17 PM   #13357
At my local club (indoor carpet) most of the guys that run the stock 540J motor run 4.2 i think.
And for an outdoot track i think 3.8 would be a good starting point.
Simon A is offline   Reply With Quote
Old 03-17-2006, 02:17 AM   #13358
Barry_Hughes's Avatar
For those of you who want a front diff complete try this link
http://www.precisionrc.com/nv/car/pr...oduct_id=27516
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 03-17-2006, 04:01 AM   #13359
Stein Tumert's Avatar
Thanks. I'm planning to use a spool from titanium racing. At least I have 4 wheel braking like diffs have. And it can act like a diff and a one-way at the same time.
An alternative spool from funnygear
http://www.rczone.net/modules.php?na...rticle&sid=609
(looks like the funnygear website is temp down)
Stein Tumert is offline   Reply With Quote
Old 03-17-2006, 06:41 AM   #13360
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
Originally Posted by bender
Well I haven't had any earlier 415, but my MSX tweaks very easily!
I usually have to reset the top deck after each run, even if I haven't hit anything.
Though this depends upon the track - for some reason the car doesn't seem to tweak at all on the bumpiest track I race on
Hey Guys,
I had some tweak problems with my MSX but it wasn't any more then I had with the MS in all honesty. Since then though, I have put some TOP blue countersunk shims and countersunk screws to reduce the possibility of tweaking and have not had the car out of whack yet. Has been good so far.
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 03-17-2006, 06:49 AM   #13361
Martin Crisp's Avatar
Default jurgen diff
I don't know if Jurgen is still making diffs, but here is his email if you would like to contact him. I use his 415 front diffs and they work great.
[email protected]
Martin Crisp
Power-Story.com | LearnSetup.com
Martin Crisp is offline   Reply With Quote
Old 03-17-2006, 08:52 AM   #13362
Default parts for sale CHEAP!!!
Originally Posted by gonad
I got a super good deal on a bunch of left over 415 trd parts.
Here's a picture. $50.00 includes shipping. my ebay is rc_products 370 postives.
I know it's not a "For Sale" thread...just want to give you guys first crack.
My Email is [email protected]
New price $50.00. The 4 low friction belts are worth that much.
Tamiya TRF415-1.jpg   Tamiya TRF415-2.jpg   Tamiya TRF415-3.jpg   Tamiya TRF415-4.jpg
gonad is offline   Reply With Quote
Old 03-17-2006, 12:29 PM   #13363
Mason's Avatar
Originally Posted by TRF415boy
can you READ ? He asked for someone in the UK. And there ain't no Tamiya USA in the UK, hell there isn't a proper distributor in the UK for tamiya.
I read fine. Thanks for asking.
The point is nobody (distros) has these parts. Nobody has had these parts for months now. It's why I didn't drive my car much before the 'Birds and haven't touched it since. I did most of that with CA.
If anyone knows where to get these parts at without sending my credit card info through email insecurely, please share the info.
But wait, there is also more great news from Tamiya - a new car coming out next month and its another kit based on the same parts you can't get now.. BRILLIANT!
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 03-17-2006, 12:57 PM   #13364
MikeR's Avatar
Trader Rating: 15 (100%+)
TWEAK : not had a single issue with my MSX regarding tweak. If the car's properly assembled and the screws tight it won't tweak, and the centre brace helps in the car not tweaking.
Oh and trust me i've hit plenty of stuff with it while trying to get a decent carpet setup (which i didn't manage to find unfortunately, went back to the good old standard 415 for carpet ).
After you swore off the MSX as going to be the 'tweak master' before it came out you did get one after all
I don't blame you. The car is a work of art and hard to resist. I wish I could afford one.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆TEKNO☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 03-17-2006, 01:48 PM   #13365
Customworksking's Avatar
Trader Rating: 73 (100%+)
Post
PM me if they didnt sell i will buy em
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
