Old 03-16-2006, 10:37 AM   #13336
Hello Everyone,
Just wondering what caster blocks are prefered on asphalt (2,3,4 or 6deg).
Obsidian is offline   Reply With Quote
Old 03-16-2006, 10:46 AM   #13337
Originally Posted by csdspeed
That's what I noticed on my tc3. I broke a cvd when I used spool at the front. But anyway, I'll just be careful in driving. Anyway, is there a front diff available for 415? I notice that the rear diff isn't the same with the front, so where can I find a diff?
Unfortunately, Tamiya doesn't make a front diff for the car...just a spool. However, there's an article on the Tamiya website that tells you how to make a diff using Yokomo parts. There's also a guy named Jurgen who makes an aluminum front diff for the car that's pretty good. I have his email address somewhere if you're interested
DOTMAN is offline   Reply With Quote
Old 03-16-2006, 10:59 AM   #13338
csdspeed's Avatar
Send a message via Yahoo to csdspeed
I prefer the one where you use yokomo parts since it's easy for me to order here in Asia. Is it in tamiyausa.com? I'll try it out.
csdspeed is offline   Reply With Quote
Old 03-16-2006, 11:11 AM   #13339
Trader Rating: 37 (100%+)
Originally Posted by Barry_Hughes
Have to disagree, there are 5 or 6 of us at my club running outside on a proper asphalt circuit and we are using diffs in the front.
Unless the track is large with sweeping corners a one way is out.
Previous experience with spools put me off, tendency if the car hit anything you always ended up with somewhee in the drive train broken
Every track will be different...but in most cases you will see guys running a oneway or spool at the big races outdoors.
Unfortunately yea you will break more things using either of those :P I've used the diff/oneway/spool and each has it's advantages.
CSD...I have the parts list needed and pics from my assembly I can post later tonight.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 03-16-2006, 11:14 AM   #13340
csdspeed's Avatar
Nexus, thanks in advance. I decided to get those spools, but when I tried ordering in a hongkong hobby shop, they were out of stock. And I needed them because we'll be having a national race here at our local track. So those yokomo diff conversion is my only way now.
Old 03-16-2006, 11:20 AM   #13341
csdspeed's Avatar
Hey I found this on another forum,
Tamiya Parts:
51055 TRF415 Ball Differential Pulley (35T)
53379 3mm Lightweight Diff Ball Set [Or 53124 Tungsten Carbide]
53030 850 Sealed Ball Bearing
51092 TB Evo 4 46mm Swing Shaft
Yokomo Parts:
ZS-501 MR-4 Differential Outdrives
ZS-506 MR-4 Diff Rings
ZS-507 MR-4 Thrust Race
ZS-508 MR-4 Differential Bolt and Locking Nut
Is this correct? And do I still need the 51092 TB Evo 4 46mm Swing Shaft? My 415 is the original version.
Old 03-16-2006, 11:35 AM   #13342
Tamiya Parts:
Yokomo Parts:
This was from the Tamiya site:
TRF 415 Ball Diff
Tamiya America is fully aware that many of our U.S. customers are racing on carpet. As we have found it is preffered to have a ball diff in the front for best performance. At this time Tamiya does not offer a front diff as both the Asian and European markets have no need. This is due to the fact that racers in those markets run mostly on sweeping high speed flowing tracks, hence the dominant choice of one-way cars.
Interim solution
In the interim, Tamiya America recommends the following Yokomo parts to directly fit a ball diff on your 415.
YOK-ZS-501 complete diff half's
YOK-ZC-507 diff thrust bearing set
YOK-ZS-508 diff adjusting kit
The stock Tamiya 415 diff rings will work with these parts as well as the stock rear pulley. Note: depending on what suspension arm system you use it may be necessary to use either 42mm or 46mm universal swing shafts. This is a interim solution and we hope you find it useful. For you TCS racers out there, please note that this modification is not TCS legal
Old 03-16-2006, 11:36 AM   #13343
TryHard's Avatar
Originally Posted by snopro31
Has anyone ran a centre oneway with a front diff , for stock foam on carpet? if so did it do anything either way good or bad.
I wouldn't do it tbh... you'd loose the advantage of brakes. Also, you might loose a little throttle response.
As a guideline, if you need to run a one0way, run it with dual one-ways.
For a spool or Diff, run a locked centre.
And regardng the tweak issue... this might sound stange, but since I've a) put the centre post on the conversion, and b) started using the Tamiya/RC champ Ti and Al screw kit (Ti underneath, Al on top), I've not had a major tweak issue, the car stays consitent between runs.
If you use the Ti/Al screw kit, just make sure you have a good Hex driver, with a square edged tip... otherwise you can just end up striping heads of the screws.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 03-16-2006, 01:47 PM   #13344
Not sure which Tamiya drivers are at the Nats in Stockton but this is a pretty sweet custom topdeck for foam tire racing!
http://www.rc50.com/modules.php?name...lbum=25&pos=46
Maybe it's J.Numans...not sure.
Old 03-16-2006, 01:51 PM   #13345
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
Grrrr RC50 still coming up as a locked site
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 03-16-2006, 01:56 PM   #13346
Until you can hit RC50....I attached the pic.
RC50 has a larger full size version.
Old 03-16-2006, 01:59 PM   #13347
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
If you look closely, (rc50 site) it lloks like a 4mm chassis as well. I like the use the chassis posts...look alot cleaner than my rigged system
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 03-16-2006, 02:20 PM   #13348
Looks like TRF Driver EJ Evans car.
He normally has a red pit towel.
tiggersz is offline   Reply With Quote
Old 03-16-2006, 02:29 PM   #13349
What you put together actually looks and I'm sure would work really well. From Liverc.com they said maybe it's Jimmy J's car.
Interesting to see how all the TRF drivers who are fast rubber tire racers do on carpet using foams.
Old 03-16-2006, 02:42 PM   #13350
Originally Posted by TryHard
I
HiH
Ed
Done that with my screws Damn hudy driver!!!
Smoking motor.. is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
