Old 03-14-2006, 02:49 PM   #13291
TryHard's Avatar
Not if I'm not online
| THard.co.uk | Xray | MuchMore |
Old 03-14-2006, 03:09 PM   #13292
Sleighty's Avatar
Tryhard is my hero
A1-RC.com
Team Scream
Xray
Sleighty is offline   Reply With Quote
Old 03-14-2006, 04:49 PM   #13293
TRF415boy's Avatar
Originally Posted by axle182
Well on my car, i already have 1mm shims under the blocks, no shims under the inner linkage point, and about 3mm of shims under the outer upper linkage point. My question was more of the / \ versus \ / when looking at the rear or front arms. I just noticed that the T2 is alot different than the 415 in this area. I was ondering if anyone has tried T2 hubs on the 415? Anyways, ill see what the oil change in the shocks will do, and go from there. Thanks guys
Which way the arms are oriented does not affect the way the RC is calculated. You have to find the point where the lines continuing the arms and the upper link crosses each other. Then from that point, you draw a line that goes right to where the opposite tyre is in contact with the ground. Do that for both sides, and where those lines crosses is where your RC lies.
To answer your question regarding oils and springs, given the same layout and surface, going from a perfect oil/springs setup for the flat track, you'd go down in both oil and springs for the same bumpy track.
TRF415boy is offline   Reply With Quote
Old 03-14-2006, 09:03 PM   #13294
snopro31's Avatar
Trader Rating: 36 (100%+)
Originally Posted by Carl Giordano
Biggest benefit: was the chassis braces I used from an old 415 standard kit attached to the front & rear chassis post to stiffen the overall chassis.
Can i see what you mean by this i am not sure i fully understand
snopro31 is offline   Reply With Quote
Old 03-14-2006, 09:07 PM   #13295
Default Awe Tamiya Deals
Please no advertsing.
twoh is offline   Reply With Quote
Old 03-14-2006, 09:16 PM   #13296
Default Wow Check this out
Advertising.
Old 03-15-2006, 07:22 AM   #13297
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
see photos below...the braces and posts were from the original 415. I cut them to fit the MSX chassis. If you try this, make sure you have a good assortment of shims. The plates must be shims on to the posts in order to avoid tweaking. You'll see if you try it.
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 03-15-2006, 08:31 AM   #13298
John-Tag's Avatar
Wow cool looking car..hope to see it in person June 23-25 in Jackson NJ...
John-Tag is offline   Reply With Quote
Old 03-15-2006, 08:49 AM   #13299
Looking forward to it...you should have stopped by the pits at Mimi's I was running the chassis... Hope to see you at the regionals in Horsham
Old 03-15-2006, 10:17 AM   #13300
Charles Godwin's Avatar
Ever since i got my MSX i have used a centre pulley with the standard one-way. I am wondering what effects i would notice if i used the one-way with the centre one-way?
Cheers, Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 03-15-2006, 10:39 AM   #13301
By the way...whats scheduled on June 23rd?
Old 03-15-2006, 12:01 PM   #13302
TryHard's Avatar
Cheers, Charles
The car will be much smoother, and easier to drive.
Good example of this was Richmond Rogers at the last carpet wars meeting. He was running the car like you were, put it on TQ, but admitted himself that it was only really by being consistent that he managed it. Had a little look over his setup, and suggested trying the dual 1-ways.... went onto easily win the meeting over the two finals (won both).
He came back and said the car was just much smoother and easier to drive, whilst still being as quick.
The reason, I believe, is to do with not having the front belt rotating off power, letting the front one-ways do there job much more effectively.
HiH
Ed
Old 03-15-2006, 12:29 PM   #13303
bender's Avatar
Double one-ways is something that confuses me.
As one-ways increase turn-in, wouldn't running 2 (diff + layshaft) make the car turn-in even more?
Can someone explain why having the front belt/diff rotating off power makes a difference to the car's steering/handling?
I know it means more rotating mass but how does that actually effect the car?
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 03-15-2006, 01:44 PM   #13304
TryHard's Avatar
I wouldn'r pretend to say that I know exactly why, but it is deffiently something involving the non-rotation of the front belt.
I think the best way to explain it is like this....
With a front belt rotating off power, you have more momentum/inertia in the drive system, this in effect acts to slow the car more rapidly... which can cause problems when running a 1-way axle. You are also relying on the bearings in the front one-way to provide all the free-roll, whilst also working against a rotating pulley...
With dual one-ways, a direct link with the centre layshaft is removed, and the whole of the belt/front pulley no longer rotates off-power. a) it means the front one-way bearings will work more effectively, as they are no longer working against the pulley and b) aids corner speed as there is less rotating mass in the drivetrain.
Honestly, your best bet is to try it back to back. Personally I always use dual-1ways.
HiH
Ed
Old 03-15-2006, 01:46 PM   #13305
Cheers Tryhard, i'll try this on saturday
Charles
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
