Old 03-13-2006, 02:19 AM   #13261
is there a reason people use the Bumper by Square? they seem popular...
noobie is offline   Reply With Quote
Old 03-13-2006, 02:25 AM   #13262
Eirik's Avatar
More steering
Eirik is offline   Reply With Quote
Old 03-13-2006, 02:33 AM   #13263
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Originally Posted by csdspeed
Thanks for the help guys! Thanks also for the part numbers which I thought on acquiring but you gave them so no need anymore. For all your suggestions and tips, I'll take note of it. . All I need know is to choose whether to buy a new 415(w/c will bust my wallet ) or a used one.
a new 415 will cost you around 24K to 25K Philippine Peso its cheaper getting it either in Honkong or in Japan but problem is the shipping cost plus the tax that you will pay for said item
buboy28 is offline   Reply With Quote
Old 03-13-2006, 03:44 AM   #13264
csdspeed's Avatar
Send a message via Yahoo to csdspeed
Pretty close. The 415 MSX costs 23K Philippine Peso. And I found a used 415 for about $200 but I'll try to persuade him to sell it around $180. I'll just make sure that his car is still in good condition. If I buy a new one, I wouldn't be able to buy other R/C stuff like a discharger/equalizer w/c I don't have and some new battery packs.
csdspeed is offline   Reply With Quote
Old 03-13-2006, 08:11 AM   #13265
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Does anyone know a quick way to get more mid-corner steering? I have great steering both in and out of corners but the car lacks very much of mid corner steer..
I run on carpet and rubbers (LRP VTEC 27 or Sorex 28R), MSX with LW susp, Oneway, Stratus 3 AP. I'll see if i can write down a complete setup sheet
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Savx - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 03-13-2006, 11:17 AM   #13266
Default Parts for sale
I got a super good deal on a bunch of left over 415 trd parts.
Here's a picture. $60.00 includes shipping. my ebay is rc_products 370 postives.
I know it's not a "For Sale" thread...just want to give you guys first crack.
My Email is [email protected]
Tamiya TRF415-3-13-03-051-small-.jpg   Tamiya TRF415-3-13-03-052-small-.jpg   Tamiya TRF415-3-13-03-053-small-.jpg   Tamiya TRF415-3-13-03-054-small-.jpg
gonad is offline   Reply With Quote
Old 03-13-2006, 12:46 PM   #13267
Martin Crisp's Avatar
You might want to try a long upper rear link with 1.5 camber front and rear...but it is hard to suggest anything without knowing the rest of your setup.
Martin Crisp
Power-Story.com | LearnSetup.com
Martin Crisp is offline   Reply With Quote
Old 03-13-2006, 12:55 PM   #13268
TryHard's Avatar
Agreed with martin, hard to suggest stuff without knowing the rest of the setup.
But have you tried some front arm sweep? I found B/A on the front to be really good the other week on high grip carpet with rubbers. Went from D/D to B/A (plus a few other changes) and the car was better, from entry to exit.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 03-13-2006, 03:33 PM   #13269
hi anyonw here got reinards setup from the TITC?
Old 03-13-2006, 03:58 PM   #13270
The TRF guys had option parts on their cars, i attempted to use a version of their early setup but it didnt work too well on the std car, or maybe it was because i cant drive like them
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 03-13-2006, 04:13 PM   #13271
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
Can anyone suggest ways to handle a bumpy indoor track on Carpet with foams? Some of my setup (off the top of my head)
Front
Springs - AE Copper
Oil - 30wt AE 3 hole pist
Shock Position - Outside hole on arm, Second from outside on tower
Blocks - A-A (1mm spacers under both)
I cant remember the C1-C2 config, but the front axles are lower in the suspension....
Camber - 1
Castor - 4
Upper Link - ~3mm spacers on inside
Arms Central between blocks
Swaybar - Red
Droop - 3-4mm
Ride - 4.5mm
D pink orange
Rear
Springs - AE Red
Shock Postion - Outside hole on arm, third hole from outside on tower
Blocks - B-D (1mm spacers under both)
1 deg hubs (total 2 deg toe in)
Upper Link - Central hole in hub 1.5mm spacer on outside ball cup. 0 spacers on inside.
Camber - 1.5
No Swaybar
Droop - ~1mm
Ride - 4.5 ~ 5mm
D pink
Im running locked centre, Jergen front ball diff, loose belts, G6 body and its in stock class. Track is usually tight but has some speed parts, good combination, but its the bumps which are making the car really unpredictable. Does anyone have any suggestions on what to try to make the car more user friendly over the bumps, while not loosing corner speed? I was matching times with the fast T2's at our local track, but wasnt as consistent. Thanks
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 03-13-2006, 04:42 PM   #13272
TRF415boy's Avatar
Front
Springs - AE Copper
Camber - 1
Castor - 4
Swaybar - Red
Droop - 3-4mm
Ride - 4.5mm
D pink orange
Rear
Springs - AE Red
Camber - 1.5
No Swaybar
Droop - ~1mm
Ride - 4.5 ~ 5mm
D pink
First off your oil/spring combination don't seem right to me. Your oil is way too thin for the springs you're using. As an example, we'd use 60W/3 holes with tamiya white/blue on carpet. So what's probably happening is that your car's way underdamped. When it goes over a bump, it's not much affected by it, but then the wheel bounces off the track and you loose grip.
From your setup, all i'd change for a starter would be the oil, I'd go to 60W and see how it handles bumps. I'd also remove the front sway bar, no one uses them on carpet. Then see how the car goes, if when you go on a bump it sort of flies then you might want to try something intermediate (but i don't think it'll do it with 60W, I've used it on very bumpy tracks). You might also want to try to go one rate softer on springs if you're racing on a bumpy track.
TRF415boy is offline   Reply With Quote
Old 03-13-2006, 04:47 PM   #13273
axle182's Avatar
Awesome thanks trf415boy. Ive got a second set of TRF shocks on another car with 60w oil and heavier springs which ill definately try. Ill swap the shocks and springs around. Ive found that it i go softer on the springs, the car is much less direct and a little lazy? at the moment the car is hard to drive and inconsistent, but its fast. Ive tried a few little changes, but the car gets slower. But i hadnt tried the oil change so ill be sure to try that tomorrow night. thanks
Aaron "AJ" Freind
Old 03-13-2006, 04:56 PM   #13274
TRF415boy's Avatar
the car's quite lazy on carpet with the front sway bar... Also heavier oil will make it more responsive so you'll probly be able to use softer springs.
Old 03-13-2006, 07:28 PM   #13275
veecee's Avatar
Trader Rating: 34 (100%+)
I think you mean heavier oil makes the car LESS responsive - more resistance = slower response. This is why you want to use heavier oil to better control the quicker rebound of the stiffer springs.
axle182, my only other suggestion would be to try running softer srpings all round and raising the roll centre. The softer springs will allow the car to handle the bumps a bit better but the raised roll centre will give you regain the roll resistance lost by running softer springs. However this is just my theory as I haven't never run on bumpy carpet before.
veecee is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
