Old 03-09-2006, 02:37 PM   #13216
TryHard's Avatar
Originally Posted by Eirik
asw7576,
With less grip and more stabillity I mean that when the car starts to slide it's much easier to controll the slide!
Longer link will give more traction to a certain point where it will break loose more abrupt....
Kind of hard to explain, so you better try it on your car and then you will fully understand what I mean
I experienced this at the weekend... was running the outer hole on the rear hub to start with, but car was very difficult to drive off power, would suddenly snap put mid turn if I let the throttle off too fast. I moved the link in one hole and this solved that problem.
I believe that the reason it has more stability is due to having more camber change over the wheels travel... although I could be wrong.
Cheers
Ed
| THard.co.uk | Xray | MuchMore |
Old 03-09-2006, 02:46 PM   #13217
Sryder7's Avatar
Originally Posted by Ben.C
Be sure to check that the bearing isn't the other way round. If installed correctly,both your front wheels should spinning freely forwards.
Cheer...
the other side works, i'll try putting it in the other way tonight, see if that's it
Sryder7 is offline   Reply With Quote
Old 03-09-2006, 03:14 PM   #13218
Eirik's Avatar
Cheers
Ed
You are absolutely right Ed! Longer rear link will give you allot more turn inn, it will be a litle more stable on power....
It's more stable because the longer link will make the suspension more roll stiff.
Eirik is offline   Reply With Quote
Old 03-09-2006, 05:53 PM   #13219
A Ilievski's Avatar
Trader Rating: 39 (100%+)
can a standard 415 be converted to a msx or does it have to be a ms
Alex Ilievski
*INFINITY * R1 WURKS * PLAIG BEARINGS* SPEEDY RC
A Ilievski is offline   Reply With Quote
Old 03-09-2006, 06:49 PM   #13220
dynoman007's Avatar
Send a message via MSN to dynoman007 Send a message via Skype™ to dynoman007
Default pics
who has a few current pics of marcs 415msx or any other factory tamiya rides ?? post em up .......
dynoman007 is offline   Reply With Quote
Old 03-09-2006, 07:29 PM   #13221
maxepower's Avatar
Talking
YES!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 03-09-2006, 08:50 PM   #13222
JUST GOT MYSELF 415MSX I RACE CARPET RUBBER AND RUBBER ASHPHALT STOCK, HAS ANY ONE GOT A GOOD SETUP, AND WHAT SPOOL DO USE.
THANKS BEN
SLIDEQ is offline   Reply With Quote
Old 03-09-2006, 08:52 PM   #13223
Originally Posted by maxepower
YES!
except you wont have the LWS ....
XingXing is offline   Reply With Quote
Old 03-09-2006, 10:26 PM   #13224
THANKS BEN
You can try this website...
THard.co.uk The TRF415 Resource
Or http://www.tamiyausa.com/articles/fe...?article-id=79
Cheers...
Ben.C is offline   Reply With Quote
Old 03-09-2006, 11:17 PM   #13225
from the 2006 TITC MS own car. looked very pretty, the preparation for these guys is amazing.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 03-10-2006, 07:24 AM   #13226
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
By looking at that photo above, different layshaft and diff pulley, new steering rack, which means a new chassis and top plate, I'd say we are in for something towards the end of 2006. Lets just hope the 4mm chassis is released with the new hole patterns.
THis car just keep getting better and better
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 03-10-2006, 10:22 AM   #13227
csdspeed's Avatar
Send a message via Yahoo to csdspeed
Would just like to ask a question, is Tamiya 415 durable? If possible make a comparison between other cars especially tc3. What is its possible weak points where parts might break? or to rephrase, what are the essential spare parts needed for this car? Need help because I'm planning to get a new touring car and 415 is one of my choices. Thanks for the help in advance.
csdspeed is offline   Reply With Quote
Old 03-10-2006, 10:26 AM   #13228
Originally Posted by csdspeed
Would just like to ask a question, is Tamiya 415 durable? If possible make a comparison between other cars especially tc3. What is its possible weak points where parts might break? or to rephrase, what are the essential spare parts needed for this car? Need help because I'm planning to get a new touring car and 415 is one choice. Thanks the help in advance.
Is definatley one of the most durable...trust me, when I hit the boards stuff usually goes flying...
The car is most duarable for indoor racing with the standard suspension arms. Using this set-up still allows you to run foam tires without any modifications.
Old 03-10-2006, 10:34 AM   #13229
csdspeed's Avatar
Our track here is outdoor, and rubber tires are used. Most of the racers here use Xray's. Can you give some more opinions about this car? . I have a tc3 and I hate always fxing my car again and again. I even almost lost my patience just today at our race fixing my tc3 that seems to break often.
Old 03-10-2006, 11:05 AM   #13230
TRF415MSX is definately a good car for outdoors. It's very durable and easy tp setup.
trf_racer is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
