Old 03-04-2006, 09:33 AM   #13141
Trader Rating: 37 (100%+)
Originally Posted by g12314
Just checked Tamiya USA's site and they list the 415 4mm chassis as "See your local hobbyshop". Anybody have any details about its release?
Thanks,
Jimmy
Jimmy...that's awesome you are at TCS at Trackside and still find time to check updates online! LOL
4mm chassis...nice.
I was looking at the pic of it on Tamiya's site....does that 4mm chassis have the hole drilled for the MSX center brace thing? From the picture it looks like it doesn't.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 03-04-2006, 09:45 AM   #13142
4mm chassis...nice.
No hole in that pic but i would presume it will be changed beofre it is put in production.
Rick Draper is offline   Reply With Quote
Old 03-04-2006, 09:53 AM   #13143
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
wallstreet is offline   Reply With Quote
Old 03-04-2006, 09:57 AM   #13144
Ballsie's Avatar
Default 4mm chassis
I've posted a message for Steve in the Speedtech section a few days ago, but I've had no reply.
Ballsie is offline   Reply With Quote
Old 03-04-2006, 01:12 PM   #13145
TRF415boy's Avatar
Originally Posted by bender
The problem with the belt wrap improvements you guys are talking about is that you increase efficiency in one area and reduce it in another.
Buy increasing the diameter of the pulley, the belt doesn't have to follow as tight a bend as previously, and this increases efficiency.
However, as the pulley diameter increases, so does the number of teeth which are in contact with the belt at any given moment, - and this reduces efficiency.
And it's just as complicated if you only change (for example) the diff pulley.
If you increase the size of the diff pulley, you lose efficiency by increasing the number of teeth in contact with the belt, but you gain efficiency by increasing the bend-diameter the belt has to travel over the pulley, but you also increase efficiency at the layshaft pulley because the belt angle to the layshaft has been reduced, therefore there are now less teeth in contact with the layshaft pulley!
Of course, one thing that is forgotten is belt tension, which severely effects efficiency:
bigger pulleys = more teeth in contact with the belt = looser belt tension possible = better efficiency
Err no, more teeth in contact won't change the efficiency, but it will reduce wear on both the pulley and the belt because each teeth has to transmit less power.
TRF415boy is offline   Reply With Quote
Old 03-04-2006, 02:53 PM   #13146
bender's Avatar
In my experience it does, and has always done so with any car I've ever raced, and I have over the past 20 years conducted various tests both physical and computer simulated, which prove the theory is sound.
You can disagree if you like, but don't simply post that I'm wrong without even an explanation as to why I'm supposedly wrong
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 03-04-2006, 03:42 PM   #13147
TRF415boy's Avatar
Simply put, the teeth once in contact theoretically don't move relatively to the pulley, so there cannot be any change in efficiency because there are more teeth in contact. In reality there are small movements due to the efforts not being constants: imperfections of the track, the drivetrain (like when you turn the driveshafts will induce variations of the load on the belt and subsequently the drivetrain), the motor (due to the design of motors the torque isn't constant during a revolution of the armature). With more teeth in contact those movements will be smaller due to the fact there is more material in contact between the belt and the pulley. Also, with bigger pulleys the centrifugal force on the belt is bigger, which means as the car goes quicker the belt gets looser around the pulley and frees the drivetrain up a bit more.
I think what you're seeing is the change in linear speed of the belt which will decrease efficiency to a certain level. Thing is, this only happens when the driven pulley (aka diff/one way/spool pulley) has its number of teeth risen, because it determines the linear speed of the belt (for a give tyre diameter, which does not vary with rubber tyres, but does with foam).
If you put a bigger centre pulley you will only change belt bending and the rotational speed of the shaft. You will not increase the losses due to the belt making and losing contact with the pulley simply because the number of those contacts made and lost for a given traveled distance is given by the diff pulley's number of teeth.
BTW computer simulation isn't a proof, it is barely a way of getting a ballpark idea of where things might stand (if you're lucky and if you have taken the right parameters and assumptions) .
Old 03-04-2006, 08:56 PM   #13148
JimmyMac's Avatar
4mm chassis...nice.
Aside from the hole that Rick mentioned.. it would suck for them to come out with this chassis and then come out with the new steering system which needs different holes as well. On top of that.. carpet season is coming to a close soon (for some) and this chassis would usless til next season. Of course next season Tamiya will have a new car!!
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 03-04-2006, 09:37 PM   #13149
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
Hey guys,
Why is it that Satoshi/Rheinard, etc, use a bumper that is very narrow?? Do anyone know why?? They either cut up the standard Tamiya one or they run the narrow one made by Square.
Any ideas?
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 03-04-2006, 09:54 PM   #13150
JimmyMac's Avatar
Good question, I've always wondered the same... I have theories... but unsure as to why..
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 03-04-2006, 09:59 PM   #13151
F. Alonso's Avatar
Eirik will know. I got a setup from him once when I got my RCManiax spool a while ago now, and on the setup sheet it showed how far along the bumper he trimmed, so hopefully we'll get the right answer soon enough.
Simon Feigl
Old 03-04-2006, 10:56 PM   #13152
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by F. Alonso
Hey guys,
Any ideas?
My personal theory is that it lets them run more aggressive around traffic without taking them out..... ie. more rubbing and racing without taking out the car in front.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆TEKNO☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 03-04-2006, 11:51 PM   #13153
Jack2's Avatar
hhmmmmm..... interesting theory ! I am curious as to why they run the narrow bumbers too..
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 03-05-2006, 03:42 AM   #13154
MrTamiya's Avatar
Just a guess.... maybe to avoid the bumper bottoming on kerbs/ripple strips when taking that millimetre perfect line around the apex....
MrTamiya is offline   Reply With Quote
Old 03-05-2006, 03:59 AM   #13155
Eirik's Avatar
Running the narrow bumper will give you more steering!!!!
I dont know how or why....... something with airflow I guess.
Eirik is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
