Old 03-02-2006, 06:13 PM   #13111
is it legal to just clip the transpoder through the front window?
Originally Posted by Charles Godwin
Edgarski no real need to get the transponder holder, just get a old peice of lexan off of a bodyshell and stick it to the servo and the transponder.
Charles
Edgarski is offline   Reply With Quote
Old 03-02-2006, 06:15 PM   #13112
Found it but not sure if its OK. I haven't seen the actual pic yet.
Square STM-7MS TRF415/EVO4 REVERSIBLE ALUMINUM TRANSPONDER & SERVO STAY
Originally Posted by MrTamiya
RC Square have released a transponder holder for the MSX/EvoIV. Part # anyone?
Old 03-02-2006, 06:28 PM   #13113
veecee's Avatar
Trader Rating: 34 (100%+)
Originally Posted by TRF415boy
Can you tell me what friction is involved in there ? There are teeth in this drivetrain so no the friction between the pulleys and the belts is in no way influencing the efficiency, just because there is no slip involved, only small movements between the belt and the pulley from when you go from on to off power or the opposite.
The white belts are more flexible than the black ones, because they are a different material (which is also quite crap in terms of longevity) that's the only reason why they sort of give a better efficiency. I've been running both types of belts and frankly can't tell the difference on the track, that's why i use black belts, they last a lot longer.
I agree efficiency due to friction would be fairly negligible but it does exist everytime the teeth engage and disengages against each other as the pulley rotates. The biggest benefit is wear (an effect of friction) and weight (effect spool up). I used to regularly chew through the aluminium pulleys on the Pro2 centre one-ways before I went to a GRM delrin item.
veecee is offline   Reply With Quote
Old 03-02-2006, 06:47 PM   #13114
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
Well the TA05 mod certainly sounds good for me, given that I typically race at medium/large style tracks with low turn Mod Motors.
I'll have to get myself some.
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 03-02-2006, 10:49 PM   #13115
Kenneth Tan's Avatar
Originally Posted by NismoSkyline17
I finished getting the white front and rear pulley's on my MSX. The rear fit perfectly in the diff. The front oneway pulley fit fine on a Speedtech spool but I had to drill the holes out to fit it on a Tamiya spool. The holes that the screws go through are a little further out from center than a stock 415 oneway pulley. Hopefully I can get some pictures taken soon of my new ride. Onroad season isn't coming soon enough.
I tried last evening. I ended up with 4mm holes on the pulley for the screw mounting. I enlarged each hole with different bits until i reached 4mm. Any larger, the holes might have been busted...
Now i got white diff pulleys on my MSX, which I might never feel the difference...
Kenneth Tan is offline   Reply With Quote
Old 03-02-2006, 11:03 PM   #13116
Oh Darn... I wanted to try install them.... Any difference in the run time dept? Since we're running 7mins races??
Ben.C is offline   Reply With Quote
Old 03-02-2006, 11:06 PM   #13117
I was just running through the R10 stock listing and noticed a 18t pulley for the TA05 from Tech Racing. I was thinking the Tamiya 05 pullies and the larger centre pulley, would make a good combo, less belt wrap.
I guess the only factor would be could you back off the belt tensioners enough to fit the bigger centre pulley?
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 03-02-2006, 11:10 PM   #13118
Jack2's Avatar
hhmmmm... I don't know, but I think I might give that a try. I think that combo would be really good if you can get the right tension. If they don't I can play with them on my 05, no loss.........
I'll order the parts tonight and see how they go together next week when they get here.
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 03-02-2006, 11:53 PM   #13119
Has anyone heard anythinhg about a different car being used at the worlds?
Or will they use the 415msx at the worlds?
Simon A is offline   Reply With Quote
Old 03-03-2006, 12:33 AM   #13120
Easy installation. No need to mess with the 415 spool. Just enlarge the existing mounting holes on the ta05 pulley.
Haven't ran them, but I don't think I am pro enough to feel it... Looks really good though...
Old 03-03-2006, 12:37 AM   #13121
There are rumours here and there...
But I guess that they would probably use the MSX,the version used in the TITC with some slight modifications. Tamiya has been doing their R&D constantly,so won't' be surprise a new cars suddenly pops up.
Old 03-03-2006, 12:50 AM   #13122
F. Alonso's Avatar
Okay, so if you leave the 415 Alloy pulleys on the car and put on the TA05 White pulleys, you achieve an internal ratio of 2.25 so I've heard. I thought that the main advantage was having a higher internal ratio (2.25 as opposed to 2.1875) so if you had the 18T Tech Racing Pulley, that would bring your internal ratio down to 2.00 if you use the TA05 Diff Pulleys, or 1.94 if you used the 415 Diff Pulleys.
Why would you want to use the 18T TA05 Pulleys on the 415 if the IR is lower??
Simon Feigl
Old 03-03-2006, 05:17 AM   #13123
TRF415boy's Avatar
Quick answer : no you cannot, I use an 18T pulley and had to get longer belts for it.
TRF415boy is offline   Reply With Quote
Old 03-03-2006, 05:21 AM   #13124
TRF415boy's Avatar
let me think, if you're not running low wind motors (for example 19T like me) then you'll see an advantage because there is much less belt wrap with an 18T pulley. As a matter of fact, if you can gear a low wind mod properly for the track, you'll see an advantage in mod too.
Old 03-03-2006, 07:34 AM   #13125
F. Alonso's Avatar
Okay, sorry for sounding a bit dumb, but what is belt wrap?
Simon Feigl
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
