Old 03-02-2006, 07:57 AM   #13096
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
Really?? Then why the change on Rheinard and Maezumi's car?? Also, do we really need to get TA05 belts then if the difference only lies with the diff pulleys, because I'd have thought that you'd have been able to simply slacken the tension to make up that difference?
I am really keen to try it out, just want to make sure of everything that I need to get.
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 03-02-2006, 08:04 AM   #13097
alan1467's Avatar
Not 100% sure why they are using the pullies but I think it a little more efficient with the plastic pullies. I have fitted TA05 diff/spool pullies on my MSX with standard white belts, you need to adjust the cams to the loose side
Tamiya TRF - Tekin
F104W Pro - CRC Gen X10
alan1467 is offline   Reply With Quote
Old 03-02-2006, 08:30 AM   #13098
TRF415boy's Avatar
Don't use TA05 belts on your 415 they won't fit no matter what. the main advantage i see with using the centre pulleys would be that they're cheaper to change than the alloy one, efifciency wise it won't change anything, the efficiency of the drivetrain isn't a function of the friction between the pulley and the belt since there isn't any movement between them.
TRF415boy is offline   Reply With Quote
Old 03-02-2006, 10:23 AM   #13099
F. Alonso's Avatar
Great. So really all that you need to get is TA05 Diff Pulleys. Great!
Simon Feigl
Old 03-02-2006, 10:28 AM   #13100
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
see posts 13082 & 13084 above...the change in internal drive ratio better suits the chassis for modified racing on large tracks....perhaps setting-up for the upcoming worlds event.
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 03-02-2006, 10:40 AM   #13101
R/C Tech Charter Subscriber
It allows to gear for very low turn mod motors.
NismoSkyline17 is offline   Reply With Quote
Old 03-02-2006, 12:50 PM   #13102
TryHard's Avatar
Originally Posted by Carl Giordano
besides changing the internal drive ratio, what other benefits are there to changing the diff pulleys to the white pulleys? Are they machined from delrin (hence the white color), slightly larger. or it just cause they look trick?
with the higher internal ratio, (2.25 with the white diff to 2.1875 stock) you would have to go up almost one tooth on the pinion to achieve the same roll-out ratio? perhaps the change is better suited for modified racing?
Got this direct from Dave Spashett
"Anyway yes with ran the different transmission, better punch and top speed and way more run time ! simply better in all departments."
Good thing I have some of the pulleys on order
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 03-02-2006, 01:11 PM   #13103
Crashmaster's Avatar
Ed,
Have you just ordered the diff pulleys then, or the layshaft ones aswell? Any chance of some part no's aswell.... lol
Cheers
Dan Chambers
Crashmaster is offline   Reply With Quote
Old 03-02-2006, 01:15 PM   #13104
just ordered the diff pulleys (51212) and on-way pulley (53867) from Speedtech...hope I ordered the correct ones
Old 03-02-2006, 01:36 PM   #13105
yup
Old 03-02-2006, 01:41 PM   #13106
Ballsie's Avatar
how do you manage to fit the TA05 layshaft and centre pulleys???
Anyone tried it?
Ballsie is offline   Reply With Quote
Old 03-02-2006, 02:11 PM   #13107
Anyone tried it?
I think its just the diff / oneway pulleys that are being changed...
Old 03-02-2006, 02:52 PM   #13108
Burlap's Avatar
Send a message via MSN to Burlap
So for 27T Stock racers, the conversion to the TA05 centre pulley and diff pulleys is not worth it?
Burlap is offline   Reply With Quote
Old 03-02-2006, 03:03 PM   #13109
veecee's Avatar
Trader Rating: 34 (100%+)
I think you'll find Delrin pulleys (if they are Delrin) have lower friction and much better wear properties than alloy pulleys. This was my experience back when I raced a Pro2 competitively in modified years ago. If drivetrain efficiency isn't a function of friction between the pulley and the belt, then why are there so many people running the white belts?
veecee is offline   Reply With Quote
Old 03-02-2006, 03:16 PM   #13110
TRF415boy's Avatar
Can you tell me what friction is involved in there ? There are teeth in this drivetrain so no the friction between the pulleys and the belts is in no way influencing the efficiency, just because there is no slip involved, only small movements between the belt and the pulley from when you go from on to off power or the opposite.
The white belts are more flexible than the black ones, because they are a different material (which is also quite crap in terms of longevity) that's the only reason why they sort of give a better efficiency. I've been running both types of belts and frankly can't tell the difference on the track, that's why i use black belts, they last a lot longer.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
