Old 03-01-2006, 08:28 AM   #13081
R/C Tech Charter Subscriber
I finished getting the white front and rear pulley's on my MSX. The rear fit perfectly in the diff. The front oneway pulley fit fine on a Speedtech spool but I had to drill the holes out to fit it on a Tamiya spool. The holes that the screws go through are a little further out from center than a stock 415 oneway pulley. Hopefully I can get some pictures taken soon of my new ride. Onroad season isn't coming soon enough.
NismoSkyline17 is offline   Reply With Quote
Old 03-01-2006, 08:50 AM   #13082
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
besides changing the internal drive ratio, what other benefits are there to changing the diff pulleys to the white pulleys? Are they machined from delrin (hence the white color), slightly larger. or it just cause they look trick?
with the higher internal ratio, (2.25 with the white diff to 2.1875 stock) you would have to go up almost one tooth on the pinion to achieve the same roll-out ratio? perhaps the change is better suited for modified racing?
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 03-01-2006, 08:53 AM   #13083
Stein Tumert's Avatar
Default Square STV-70 Tamiya TB Evo4 Evo 4 Transponderhalter
Originally Posted by MrTamiya
No, that's for MS and std 415, also only for personel.....
The servo mount is thicker, placing the servo further forward on the chassis, uses same std. mounts as Evo IV (that's for MSX )
That's nice bling though...
Here is the same one for EVO IV
(Must be better to get a personal transponder...!)
Stein
Stein Tumert is offline   Reply With Quote
Old 03-01-2006, 08:55 AM   #13084
Basically everything you said. They are going to let some of the electric guys run mod this year on the nitro track. Should be loads of fun. That's the main reason for using the white pulleys. That and the look good esspecially with the Tamiya spool.
Old 03-01-2006, 08:56 AM   #13085
Stein
I don't know what I would do without my personal transponder. Best $60 I ever spent.
Old 03-01-2006, 06:55 PM   #13086
Kenneth Tan's Avatar
How much looser does the belt tension need to be in terms of notches on the bearing holders when using the TA05 pulleys? Thanks.
Kenneth Tan is offline   Reply With Quote
Old 03-01-2006, 08:22 PM   #13087
mini master's Avatar
Send a message via AIM to mini master Send a message via Yahoo to mini master
Cool
ya just get a personal and get some velcrow and put it on your bumper
mini master is offline   Reply With Quote
Old 03-01-2006, 08:31 PM   #13088
Sushi Man's Avatar
Send a message via AIM to Sushi Man
it would be greatly appriciated if someone could help me out. Ive asked the question several times but found that no one knows. How do imake use of the TA05 16t plastic white pulleys to fit on my 415? How do i get the TA05 center shaft!? thank you
Sushi Man is offline   Reply With Quote
Old 03-01-2006, 08:48 PM   #13089
Jimmy Jacobson's Avatar
leave the stock pulleys in your car you will not notice a difference when they make a 17 tooth pulley then you will notice the difference
Jimmy Jacobson is offline   Reply With Quote
Old 03-01-2006, 09:52 PM   #13090
My car is still new so the belts haven't broken in yet but mine are 2 notches to the center of the car from the center mark.
Old 03-01-2006, 10:01 PM   #13091
The std setting (as it says in the manual) is fine, don't need to change it.
Simon A is offline   Reply With Quote
Old 03-02-2006, 01:41 AM   #13092
nordheim's Avatar
Do you guys know of anywhere in the US where you can order TA-49382 White on-road spring set?
Thanks guys!
SEATTLEINDOORRACEWAY.COM - VALLEYVIEWRC.COM
nordheim is offline   Reply With Quote
Old 03-02-2006, 02:27 AM   #13093
Default White spring set
Thanks guys!
Looks like you can order directly from Tamiya USA
http://www.tamiyausa.com/product/ite...oduct-id=49382
I am in Germany and got it from my dealer in Switzerland
http://www.rc-sunshine.ch/
Stein
Old 03-02-2006, 07:50 AM   #13094
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
What is the difference in the number of teeth between the TA05 center pulleys and the 415 center pulleys??
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 03-02-2006, 07:52 AM   #13095
alan1467's Avatar
They are both the same size 16T
Tamiya TRF - Tekin
F104W Pro - CRC Gen X10
alan1467 is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
