Old 02-26-2006, 11:30 PM   #13036
Jack2's Avatar
Originally Posted by bender
@F1 Larry
For example: I have often been told that if the car gets more roll at the front, then it will have more steering. My experience has been the complete opposite - so if someone suggests that as something to try, then I would rather try another suggestion first, one that might be more likely to work for me.
What I have found with adjusting roll centre, front or rear, is it really depends on the rest of the car's setup. Many other factors seem to affect how valuable adjusting the roll centre is in certain situations.
I have found that adjusting the car to roll more at the front sometimes will work very well, it will seem to load up the front end very well and the car will be very quick and will behave well. On other occasions, different setup, tires etc, I have made the same adjustment and it just seemed to delay the steering and when the car did decide to turn, it turned like a battleship. Once the front RC was raised, the car reacted much faster, seemed a lot "sharper" in the turns and just turned better all round.
So depending on the balance and overall setup on the rest of the car, in my opinion, seems to play a huge part on what the adjustment will do. Especially when adjusting RC.
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 02-27-2006, 01:11 AM   #13037
SchuMi2's Avatar
Trader Rating: 34 (100%+)
Yes but remember that the roll centres F/R affect the cars handling immediately because the car has to be rolling before any of the other tunning options such as shocks, springs, swaybars etc come into affect. I would try the roll centres first and then fine tune with springs/oils etc. This is what I have always done and it seems to work for me
SchuMi2 is offline   Reply With Quote
Old 02-27-2006, 01:18 AM   #13038
well, for starters, where I come from, thats no medium size track. That looks quite large to me........ Is that track in NZ ?
I will PM you a setup
Lol it looks a little larger in the photo but it is still quite big
Yeah its in North harbour, the most northern part of Auckland.
You should come down for the HD/RL international!
Simon A is offline   Reply With Quote
Old 02-27-2006, 03:05 AM   #13039
Jack2's Avatar
Yes, RC is almost always the first thing I will adjust too.
Schumacher Mi4CX
Mugen MTX & MRX
Old 02-27-2006, 03:58 AM   #13040
Hello, I plan to buy a Refine 2, can you tell me which toe blocks are included in the kit???
Also is there a direct pulley for the spool??
Hugo is offline   Reply With Quote
Old 02-27-2006, 05:33 AM   #13041
Is this new springs : TAM53440AO to replace the regular ones???
Or are they for carpet with foam???
Old 02-27-2006, 05:41 AM   #13042
kentech's Avatar
Blocks included with MSX:
1 x XD
1 x XB
1 x A
2 x B
The spool comes without a pulley. It uses the same pulley as the front one way, part# 51054 TRF415 Front One-Way Pulley - 35T
The part# for the direct center pulley is #53708 TRF415 Direct Center Pulley
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 02-27-2006, 05:46 AM   #13043
Thanks for the answer.
Also I'd like to know if the kit comes with the 1° or 0° aluminium rear hubs.
Old 02-27-2006, 07:05 AM   #13044
Martin Crisp's Avatar
Default Bender,
Hi Bender,
Thanks for reading my XXXMAIN setup guide. You are correct in saying that the different setup guides out there will sometimes contradict each other. The reason for this from my experience, as I tried to explain in my book, but maybe not well enough is that there are many examples in setting up a car when the same type of change will produce different results. It's about finding the "sweet spot" of an adjustment. So the bottom line is all the setup books are correct given the right combination of setup and track conditions.
For example it is generally agreed that going with a softer spring will make that end of the car have more grip. e.g. put softer springs on the rear and we will have more grip. However we can go too soft which will take away grip.
Roll center is a tricky thing as well. If we add more roll center in the front then the car will typically have more steering but if we go too far with the roll center that end of the car can start to push. Also when trying to correct the car from traction rolling somtimes I have found that more roll (i.e. lower rc) will reduce the car's tendency to flip and sometimes the opposite happens, depending on the spring rates, foam v.s. rubber tires etc. From my experience if you have a heavy spring rate you will tend to want a low rc (more roll) and if you have a very very light spring rate you will want a higher rc (less roll), but again this does not always work. For example at a roar nats carpet rubber race in stockton a few years back I found a high rc with soft springs (15lbs) prevented the traction rolling issue I was having. When I tried that same approach at vegas last year (again on rubber tires) the car still flipped. When I when up on the spring rate, took off the sway bars, decreased the cast and allowed more roll (lower rc) the car stopped flipping.Vegas had more grip than stockton because there was no foam class in stockton at the time.
In the end my book provides a starting point to understand setup adjustments, but we need to gain setup experience to truly know when it will go one way or the other, by constantly making adjustments, seeing the results and adding that you your experience base. But this is one of the things makes our hobby so much fun, because finding that perfect setup is very challenging.
f1larry - thanks for the reference to my book.
Martin Crisp
Power-Story.com | LearnSetup.com
Martin Crisp is offline   Reply With Quote
Old 02-27-2006, 07:17 AM   #13045
Stein Tumert's Avatar
Default Diff covers for 415
Originally Posted by veecee
I’ve read that some of you have been running ceramic diff balls and adapting some covers to make the diffs last longer between rebuilds. Can someone describe this in more details, preferably with part numbers? Sorry if this has been covered before.
Thanks,
Vincent
Atlas diff covers for 415 (MH7-TRF) See attached picture.
Stein
Stein Tumert is offline   Reply With Quote
Old 02-27-2006, 07:20 AM   #13046
Default ceramic diff balls
yeah...ever since I switched to ceramic diff balls, I just keep reusing the same diff balls everytime I rebuild the diff. I seem to be able to rebuild the diff about 10 times before I replace the diff balls.
Martin Crisp
Old 02-27-2006, 07:38 AM   #13047
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
Martin, thanks for the explaination...(and the book)
Perhaps a little clarification: in your definition: High rollcenter (rc) = more or less shims under the toe-in blocks?
I've always found that for my driving style, even in fuel on-road. I like to run the inner hinge pins higher than most other drivers. (same effect as adding shims under the toe-in blocks)
Problem is everytime someone asks me what's your roll center? I never know how the answer them? (ie: low or high rc?)
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 02-27-2006, 07:42 AM   #13048
Any answer???
Old 02-27-2006, 07:42 AM   #13049
Any answer???
Old 02-27-2006, 07:43 AM   #13050
I believe Martin is reffering to the upper camberlink position, not the hinge pin carriers. Although those will also slightly alter roll center as well.
Joe
Real men race MODIFIED!!
JoeGlover is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
