Old 02-23-2006, 07:02 PM   #12976
f1larry's Avatar
R/C Tech Charter Subscriber
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
Originally Posted by wallstreet
does anyone have a good setup for the 415msx refine 2 kit, running cs-27s on high bite carpet.
MIke,
I sent you Martin Crisp's setup from the IIC. Do you want me to send it to you again?
larry
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Exotek F1R3|X-Ray T4 16|CRC Xti Altered Ego|Associated B5M|TT02|TA05|TL01RA|TL01|
f1larry is offline   Reply With Quote
Old 02-23-2006, 07:54 PM   #12977
Kevin CBR's Avatar
Originally Posted by danjoy25
Can anyone confirm if the option part below for a TA-05 will fit the MSX as well.
http://cgi.ebay.com.au/TA05-TA-05-Al...QQcmdZViewItem
I did get 2 spare posts and other bits extra so that evens out the missing ball ends.
Standard TA05 front knuckle uses 5x11 (1150) bearings.
415MSX uses 5x9 (950) bearings.
If you put this on a 415, you would also need to to change the axle shaft to the "regular" size like used on the TA04 / TB02 / TA05 / 415.
Panda Performance / Nemo Racing top secret R&D lab hidden in a lush bamboo forest....
Scorpion Power Systems
Kevin CBR is offline   Reply With Quote
Old 02-23-2006, 08:32 PM   #12978
Default Balance
Front one way is OK.
Rear arms OK
It spins as I first turn into the corner.
PRO 2 RACER is offline   Reply With Quote
Old 02-23-2006, 08:44 PM   #12979
Rear arms OK
You should not let go the throttle. The throttle must be on at least 20%. I am sure that your car will steer enough when entering the corner with throttle on.
trf_racer is offline   Reply With Quote
Old 02-23-2006, 08:49 PM   #12980
maxepower's Avatar
Talking Set-up issues!!
Rear arms OK
Too much weight transfer to the front wheels when you go into the corner! What is the droop set at? The DJ set-up measures from the top of the axle to the bottom of the chassis!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 02-23-2006, 09:25 PM   #12981
Note sure about the droop I am at work and will have to check when I get home.
Old 02-23-2006, 09:39 PM   #12982
rayhuang's Avatar
Hey rubber tire gurus!!
ON a black groove Ozite track, if one tire is glued to rim, but the bead can seperate fully from rim (Lift off) will that casue a severe loose condition. To be very specific, if the LEFT fronts lifting off like that, will it spin out while entering or off power in right hand corners? Assume perfect tweak and perfect circles, perfect shocks, etc. This was with my 415Ms with one-way.
btw-the car felt great in left hand corners.
Thanks,
Ray
Old 02-23-2006, 09:53 PM   #12983
f1larry's Avatar
if your tire starts to come of the rim you usually get a push, at least thats what I have experienced
Old 02-23-2006, 10:13 PM   #12984
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
Depending on what rim/tyre is coming unglued will determine how your car will behave. If the tyre unglues at the front of the car, then it will push, and it will be particularly bad in one direction then the other. If its unglued on the rear, its spin time! You can control it to a point, but really it can be tough to drive.
Also, be prepared to see a stuffed rubber tyre too if thats what happens, particularly with a Sorex.
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 02-23-2006, 10:17 PM   #12985
F. Alonso's Avatar
Just built a TRF415MS ran it for the first time and the rear end was so loose it was spinning out at every corner.
The set up was (basically Dave Junns setup sheet data)
Yellow springs all around
60wt front
40wt rear
One hole in on all top shock mounts
Takeoff 27's
on Net ball courts (like green tennis court surface, very grippy!)
EA monster stock
IB3800's
The car was lightning fast (several guys commented on the speed)
It just was so loose in the rear end.
I ended up with White springs on the front & red springs on the rear
I adjusted the front shock mount out one hole and the rear in one hole and it was much better, still a bit loose.
I look at the threads and everybody says how much grip they get from the 415.
My question is have I set something else up wrong which is causing the poor rear end grip?
Any input would be great.
Thanks guys.
Just to try and work it out to be sure, you aren't using the DJ Pro Module suspension are you?? I thought that the only setups online were setups for Pro Module suspension, therefore may not be ideal for just std LWT suspension. Try to revert to kit setting I think, with a bit of antisquat. I think that is a fairly decent enough setup as it is, as kit setting has quite a bit of push. Also, remove the urethane bushing too. I'd also run without sway bars too if you could help it.
Simon Feigl
Old 02-23-2006, 10:58 PM   #12986
XMSRacing's Avatar
Send a message via AIM to XMSRacing Send a message via Yahoo to XMSRacing
Rear arms OK
Go find one of the fast guys at your track and ask them to drive it. I'd be willing to bet your letting off the throttle to much upon entry causing the rear to come around. I had the same problem for a few sessions when I first got my MS... once you learn to drive the one-way, its stupid fast. I dropped 7 tenths off my best lap time with my TC4 in only my second race with the MS.
I'm officially a Tamiya addict!
XMSRacing is offline   Reply With Quote
Old 02-23-2006, 11:00 PM   #12987
Welcome to the club....
Ben.C is offline   Reply With Quote
Old 02-24-2006, 02:24 AM   #12988
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
guys, anybody know the part number of the new steering bellcrank of the msx just like the one that rheinard used in the recenly concluded TITC
buboy28 is offline   Reply With Quote
Old 02-24-2006, 02:50 AM   #12989
Its a prototpye...Don't think it'll be available to the common man that soon.
Old 02-24-2006, 02:50 AM   #12990
alan1467's Avatar
I think you'll find it just a prototype and not on sale, but you wouls also need a new top deck and chassis as it's futher back than the standard steering
Tamiya TRF - Tekin
F104W Pro - CRC Gen X10
alan1467 is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
