Old 02-23-2006, 04:46 PM   #12961
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Just finished building an MSX last night and ended up short of 2 ball ends for the steering linkage. All steps per manual were followed.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 02-23-2006, 05:02 PM   #12962
Thats strange i ended up with to spare ball ends
maybe they put yours in my kit
Simon A is offline   Reply With Quote
Old 02-23-2006, 05:05 PM   #12963
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
does anyone have a good setup for the 415msx refine 2 kit, running cs-27s on high bite carpet.
wallstreet is offline   Reply With Quote
Old 02-23-2006, 05:06 PM   #12964
You must have lost some ball ends. There should be 2 extra.
trf_racer is offline   Reply With Quote
Old 02-23-2006, 05:29 PM   #12965
danjoy25's Avatar
Can anyone confirm if the option part below for a TA-05 will fit the MSX as well.
http://cgi.ebay.com.au/TA05-TA-05-Al...QQcmdZViewItem
I did get 2 spare posts and other bits extra so that evens out the missing ball ends.
Old 02-23-2006, 05:44 PM   #12966
snopro31's Avatar
Trader Rating: 36 (100%+)
I think the TA05 has the old style arms on it and your msx (if stock) will have the reversible arms on it.
snopro31 is offline   Reply With Quote
Old 02-23-2006, 05:52 PM   #12967
Originally Posted by TryHard
BTW, anyone got a clue on whats going on with Surikarns brush wiring in this pic? Can't figure it out meself, looks like its got extended copper shunts
Ed
Here in the US many of the mod drivers run 2 and sometimes 3 fans on the motor to try and keep the motor from unsoldering. I've seen pics of Hara wrapping wet paper towels around the wires to help.
But I would think the question that would be of bigger deal is what brushes are they using? Especially after seeing this pic:
http://sudacolumn.cocolog-nifty.com/...s/P1040465.JPG
I'ld love to know what the copper shunt brushes are.
Also does anyone know if that is a homemade shotky diode or does someone make that?
Brian Anthony is offline   Reply With Quote
Old 02-23-2006, 05:57 PM   #12968
wallstreet's Avatar
any help on a msx cs-27 high grip carpet setup ?
Old 02-23-2006, 06:07 PM   #12969
snopro31's Avatar
Here try this set up its for a super fast canadain racer.
Front:
Tamiya white spring (hard)
60wt oil
3 hole piston
outer hole on front shock tower
1.5 camber
2mm spacer under upper camber link (inside)
0 degree toe
4 degree caster
197mm width
Rear:
Tamiya blue spring (medium)
40wt oil
3 hole piston
2nd hole down from top of rear shock tower
1.5 camber
flat upper camber link (inside)
2.5 degree toe (0 degree rear hub)
outer camber link hole on rear hub
198mm width
Old 02-23-2006, 06:09 PM   #12970
Default Balance Problem
Just built a TRF415MS ran it for the first time and the rear end was so loose it was spinning out at every corner.
The set up was (basically Dave Junns setup sheet data)
Yellow springs all around
60wt front
40wt rear
One hole in on all top shock mounts
Takeoff 27's
on Net ball courts (like green tennis court surface, very grippy!)
EA monster stock
IB3800's
The car was lightning fast (several guys commented on the speed)
It just was so loose in the rear end.
I ended up with White springs on the front & red springs on the rear
I adjusted the front shock mount out one hole and the rear in one hole and it was much better, still a bit loose.
I look at the threads and everybody says how much grip they get from the 415.
My question is have I set something else up wrong which is causing the poor rear end grip?
Any input would be great.
Thanks guys.
PRO 2 RACER is offline   Reply With Quote
Old 02-23-2006, 06:17 PM   #12971
Burlap's Avatar
Send a message via MSN to Burlap
60wt front
40wt rear
Takeoff 27's
EA monster stock
IB3800's
Thanks guys.
Have you got the front one way diff installed correctly? The screw heads should be pointing to the right hand side of the car (if looking from the rear of the car). I made the mistake of putting it in the wrong way and it spun like a top with power on.
Burlap is offline   Reply With Quote
Old 02-23-2006, 06:37 PM   #12972
TRF415boy's Avatar
60wt front
40wt rear
Takeoff 27's
EA monster stock
IB3800's
Thanks guys.
did you put the rear blocks as per instuctions ?
TRF415boy is offline   Reply With Quote
Old 02-23-2006, 06:45 PM   #12973
60wt front
40wt rear
Takeoff 27's
EA monster stock
IB3800's
Thanks guys.
I am running modified 12T motor in an indoor track and the rear end was loose to when I let go of the throttle. My one-way is installed correctly. BTW, I don't think people would install one-way backward because you would know when you spin the tires.
Anyways, try not to let go of the throttle, make sure you finger is always pushing the car on throttle.
Old 02-23-2006, 06:47 PM   #12974
XMSRacing's Avatar
Send a message via AIM to XMSRacing Send a message via Yahoo to XMSRacing
60wt front
40wt rear
Takeoff 27's
EA monster stock
IB3800's
Thanks guys.
Where is it loose? entering the corner? mid? exit? on/off power?
XMSRacing is offline   Reply With Quote
Old 02-23-2006, 06:53 PM   #12975
JimmyMac's Avatar
http://sudacolumn.cocolog-nifty.com/...s/P1040471.JPG
Looks like they are using Team Orion Platinum battery bonez or battery bars. It's a pain in the arse to solder wires to the V2's. So they just made an extension it looks like to me. That's the one thing I hate about the V2's... soldering motor wires and shuts suck!!!
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
