Old 02-22-2006, 12:30 PM   #12931
bender's Avatar
I think rc champs regular MSX price is approx US$340
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 02-22-2006, 01:55 PM   #12932
kentech's Avatar
A couple of interesting pics from the TITC posted here:
http://sudacolumn.cocolog-nifty.com/typer/
I'm sure more will be posted soon...
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 02-22-2006, 02:04 PM   #12933
Charles Godwin's Avatar
Good pictures
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 02-22-2006, 02:09 PM   #12934
R/C Tech Charter Subscriber
What I don't understand is why are they using the TA05 center pulleys and spurgear adaptor? What's the advantage? The pulley's are the same size so you can use the stock 415 layshaft pulleys with the TA05 diff pulleys.
NismoSkyline17 is offline   Reply With Quote
Old 02-22-2006, 02:43 PM   #12935
Originally Posted by C van der Hagen
Anyone noticed that Meazumi used the old rear suspension arms and the LW in front. He did also use plastic rear uprights (HPI?)
Was his car the same as Marc's car at the TITC?
Nope he has LTW rear arms on his car. Just with the little moulded balls for the roll bars cut off. Look real close you can just about see.
Rick Draper is offline   Reply With Quote
Old 02-22-2006, 02:46 PM   #12936
hi wats the diff b/w msx and msx refine 2?
XingXing is offline   Reply With Quote
Old 02-22-2006, 03:07 PM   #12937
maxepower's Avatar
Talking Must have items!
Originally Posted by swimbikerun
I'm going to be back in southern Cal for buisness for several weeks in March and was wondering what the typical MSX setup for both Socal raceway and Hot Rod Hobbies in stock and mod classes since I would like to limit the amount of gear I will have to take on the plane. Looking for Spur/Pinion, Tires,Springs, Shock Oil, and Motor for mod info. Also is there anywhere else I need to look at racing? I grew up in southern Cal but haven't lived there since '94. Thanks.
Tires = Sorex 36R's with yokomo super thins(these should work well at So.cal and tamiya tracks)
Springs = yellow of coarse!!
oil = 40-50wt.
Spur/pinion = any combo that will put you in the 6.0-7.5 final ratio range(Tamiya large track/ sweeping turn--So.Cal Med./ tight turns)
Mod motor = V-2
Stock motor = Monster or Cobalt27
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 02-22-2006, 03:37 PM   #12938
Starter going through 415 last night and realized the only thing really left from the original car is the chassis and the bearings for the outdrives! Anyway the wheel bearings are pretty bad already as far as grittyness and slop go. Does anybody make a bearing that is a higher tolerance or something. The smaller bearings for the ltw suspension just did not hold up very well. Also what is final verdict on the ta05 pulleys. Will they bolt right on with the 415 center shaft or do i nedd some unobtaium to make it work!
FT B44 - FT J82
LRP TC SPHERE - Futaba Fasst
Orion Lipo & Vortex motors
" Go that way really fast, if something gets in your way, turn"
tcmerf is offline   Reply With Quote
Old 02-22-2006, 04:14 PM   #12939
TRF415boy's Avatar
Nope, TA05 diff pulleys are 36T as opposed to the 415's 35T, pulleys are 17T as opposed to 415's 16T. So you need longer belts, the stock belts won't fit.
TRF415boy is offline   Reply With Quote
Old 02-22-2006, 04:24 PM   #12940
Nope 16t so stock 415 should fit just have to run the belt a little looser than stock.
http://www.tamiyausa.com/product/ite...oduct-id=51213
Old 02-22-2006, 04:29 PM   #12941
Bottom line is you should be able to use the TA05 diff pulleys with everything else stock (from the looks and mathmatically). I just don't get the advantage of using the center hardware from the TA05. Only reason would be easier access to the spurgear and the only thing it would be changeing would be the FDR.
Old 02-22-2006, 04:41 PM   #12942
TRF415boy's Avatar
Agreed, if the centre pulley was bigger there would be an advantage of having less wrap, but a slightly bigger diff pulley only has an advantage of allowing lower gear ratios for low wind mods.
Old 02-22-2006, 04:43 PM   #12943
Maybe that is the only reason they are running them. I wonder if the diff pulleys are dyeable.
Old 02-22-2006, 04:57 PM   #12944
TRF415boy's Avatar
don't know, i run bigger centre pulleys but i'm not fussed about gearing for low winds since i mainly run 19T indoors and outdoors i don't think i'll go lower than 8T. When running indoors with 8T as the top drivers do here, they sometimes have to go to 9.5 or something that stupid.
Old 02-22-2006, 05:54 PM   #12945
I'm gonna take a stab that the TA05 center pulleys are lighter then the 415 Al. ones. I'm also going to guess that the plastic TA05 center pulleys "bite" less into the belts then the Al. ones do. Though I could be wrong.
Brian Anthony is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
