Old 02-20-2006, 11:14 AM   #12886
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
Originally Posted by viper1
Hi Alan,
The truth is that the drive train u are seeing on the MSX from the Tamiya team is from the TA05. they also have a new steering bell crank system on the cars. According to Marc and Satoshi this 2.25 drive train from the 05 is actually smoother than the original one how true i am not sure.
Cheers.
I guess you're right about that. We'll probably see more pics & info re the new mods soon.
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 02-20-2006, 11:39 AM   #12887
Charles Godwin's Avatar
Got a diff built for the front (Tamiya/Yokomo) for my local club (extremely tight track ), but it wobbles from side to side. Should i put shims to the sides of the diff or leave it and if i need shims can you tell me what sizes please
Cheers, Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 02-20-2006, 01:59 PM   #12888
Yeah i noticed the checkpoint motor too.
And my spur gear holder is carbon fiber.
And a quick question....
The front and the rear wheels have alot of play way more than my old car.
Is it supposed to be like this or how could i fix it?
Simon A is offline   Reply With Quote
Old 02-20-2006, 02:05 PM   #12889
Joys of a tamiya . My car is like that but it seems fine. To try and limit the slop in the wheels add a shim or two behind the pin which holds the wheel hex on
Charles
Old 02-20-2006, 02:43 PM   #12890
Sushi Man's Avatar
Send a message via AIM to Sushi Man
Cheers, Charles
hey charles you should use 10 mmx 0.1mm shimms.. tamiya makes them, make sure there a tiny bit of play too.
And yes my wheels have a lot of slack to. i put 2 shims under it. I still have slack but none is not always good.
Sushi Man is offline   Reply With Quote
Old 02-20-2006, 03:10 PM   #12891
stuey's Avatar
hey
i've just got hold of a 415ms can anybody tell me if the msx conversion kits are still avalible and were i could get one from (preferbly in the uk)
stuey is offline   Reply With Quote
Old 02-20-2006, 04:37 PM   #12892
Many hobby stores have the conversion kits that will ship to you.
Precision rc has the best price i think. $180usd.
http://www.precisionrc.com/nv/car/pr...oduct_id=12463
Hope this helps.
Old 02-20-2006, 05:37 PM   #12893
stuey's Avatar
Hope this helps.
That is spot on thanks
Old 02-20-2006, 07:54 PM   #12894
Formula1fan's Avatar
I have been running 12th scale the last few months and itís getting close to outdoor time and I have to decide what touring car to get. I live in OH and we run foam tires out side. Has anyone tried the 415 like this, if so what do you think? I have posted this in T2 and cyclone forms also; I didnít want to start another this vs. that thread. I am leaning heavily towards this car, but after the love affair I had with my Fk05 itís hard to pull the switch.
Formula1fan is offline   Reply With Quote
Old 02-20-2006, 08:07 PM   #12895
Trader Rating: 37 (100%+)
One of the tracks I raced at last summer was Open Mod/Foam tires...
The 415 was awesome and required very little setup change from week to week. Especially with foam tires on asphault. That type of racing is not that common but easy to run fast with Mod motors. Our track was about 200x100ft...I ran both the standard and LW type suspension with both being very durable.
I've owned a FK05 and that car is awesome as well. For strictly foam/carpet racing I'd run the FK05. But for any rubber tire or outdoor racing (foam or rubber tire) I like the 415, 415MS, MSX cars.
Any of the cars you mentioned will work well though.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 02-20-2006, 09:57 PM   #12896
Trader Rating: 35 (97%+)
Send a message via AIM to King of B Main
Hey Rod could not see the difference between each side of thrust, am I using the right one or were you just messin with us. Numan wanted me to take a picture for you on both sides and you tell us what side to use.
Hey but in a serious note thanks for the help put in the carbide balls in and it made a huge difference in how my car handled. I finally had a rear diff. I think it helped Numan too.
King of B Main is offline   Reply With Quote
Old 02-20-2006, 10:34 PM   #12897
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Look at the brass sleeve in the center of the bearing, one side is square, the other has a small chamfer.
tamiyarcracer is offline   Reply With Quote
Old 02-21-2006, 02:21 AM   #12898
Drcy's Avatar
Default MSX with TA05 drive train.
Hi Alan,
Cheers.
Hi,
does somebody know what would be necessary to buy in order to get the TA05 drive train fitting in the MSX? (I mean also the black belts?)
I have to confess that I also would like to have this "new" steering bell crank system on my car, since I am not happy with the original nor with the wobling Spur.
thanks in advance
Cy
Drcy is offline   Reply With Quote
Old 02-21-2006, 03:32 AM   #12899
TRF415boy's Avatar
Originally Posted by Drcy
Hi,
thanks in advance
Cy
I don't think you can get the belts from anywhere else than the producer. For the spur, they're just using the TA05 spur holder that goes with the pulleys that's why the spur mounts the other way round.. Oh and the reason the belts are black is they don't exist in white on that size.
TRF415boy is offline   Reply With Quote
Old 02-21-2006, 08:32 AM   #12900
rtypec's Avatar
Hi Mike, it's somewhat hard to notice but I have attached an illustration that demonstrates what to look for. It's hard to see at times but you should be able to see it. I hope this helps.
rtypec is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
