Old 02-15-2006, 04:56 AM   #12796
I read this on one of Josh Cyruls tips page
Free Drivetrain
Q: When you free up the drive train of your xray, do you cut every other tooth out on both front & rear pulley or just front? Also, do you cut the teeth out of belt too? I also saw that you extended the steering knuckles where steering linkage connects to, what does that do?
A: I just cut every other off of my front pulley. I DIDN"T CUT THE BELT!!! The extensions on my steering are actually pieces of the "foam tire" front shock tower cut off to fit. It gives the car less Ackerman - more high speed steering..
Anyone tried this on the 415?
cheers
noobie is offline   Reply With Quote
Old 02-15-2006, 08:16 AM   #12797
Originally Posted by Eirik
Brian,
It's Tamiya's own Flourine coated ball ends, super smoooooth!!
TAM53599 Tamiya FL Coated Aluminum Ball Nut 5mm
TAM53598 Tamiya FL Coated 5mm Aluminum Ball Studs
I don't know why more people don't run Tamiya. I just decided in the last few weeks to check it out and I've been overly impressed with all they have to offer. I think I'm just over half way reading through this thread and you guys got your stuff together with knowing this car. Thanks for the help. I'm sure I'll have a few more questions as I go.
Brian Anthony is offline   Reply With Quote
Old 02-15-2006, 08:25 AM   #12798
Trader Rating: 118 (100%+)
Does anyone have a picture or scanned image of the world's part set sheet showing all the suspension blocks and what angles they generate? Would be useful to all of the new and future MSX owners. Thanks
Erik
http://store01.prostores.com/servlet/whipracing_bluescrews/StoreFront
ewippler is offline   Reply With Quote
Old 02-15-2006, 08:31 AM   #12799
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
Your right, especially since the X-Ray T2 is a good copy of the MSX. I have both and decided to sell the X-Ray after one run...did not see the advantage over the MSX. (other than the fact that everyone around me runs an X-Ray one)
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 02-15-2006, 10:39 AM   #12800
Eric look under Tryhard's signature he has a portion of his site that has that info.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 02-15-2006, 03:43 PM   #12801
Trader Rating: 37 (100%+)
posed a Tamiya related question in the TCS thread if anyone happens to know the answer...
http://rctech.net/forum/showthread.php?t=18976
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 02-15-2006, 03:48 PM   #12802
JimmyMac's Avatar
Originally Posted by Simon A
Maybe your setup was to soft?
marc was running a very hard setup in vegas. 60wt oil and 33lb and a 28lb springs.I ran harder springs and oil lately and it is much better. I would love to get the 4mm chassis tho
My setup was almost the same as Marc's minus the 4mm chassis and a few tweaks here and there. I always run XRay springs on carpet Violet/Purple. I also had AE 60wt. Blah blah blah.. hehe. The setup is fast here at the local track. But it slowed down at the Birds. Honigl's car stayed the same during all 3 rounds in Mod. 28 laps at 5:06.
Anyways, setting the car back up for asphalt. Gotta get ready for TCS next month in MD. This should be a fun one....
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 02-15-2006, 03:53 PM   #12803
Casey's Avatar
Jimmy, I will be waiting !! with msx and MINI
Casey is offline   Reply With Quote
Old 02-15-2006, 04:15 PM   #12804
TRF415boy's Avatar
Free Drivetrain
cheers
Tried what ? Cutting every other tooth off the pulleys ? Nope and I wouldn't do it if i were you. Reason is, it won't change the drivetrain efficiency, and you won't get enough teeth in contact to transmit all the power, the drivetrain is struggling enough as it is now IMHO that I had bigger primary pulleys made up. Remember the XXX-S had massive pulleys so they could do it without fearing to have the belts skipping.
For the Ackermann you can try using the outer holes on thefront hubs that's exactly what they do, don't forget to re-set your EPA if you do this.
TRF415boy is offline   Reply With Quote
Old 02-15-2006, 04:46 PM   #12805
JimmyMac's Avatar
You better get dialed in while you are up there!! I plan on reclaiming my TQ again!!
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 02-15-2006, 05:27 PM   #12806
Josh dremeled off every other tooth on the front diff pulley of his X-ray. I believe it is a 32 tooth pulley he did this to. The Losi guys used to cut every other tooth off of the yellow belt on the XXX-s. They they got the frictionless black belt and did not need to do this.
Old 02-15-2006, 07:44 PM   #12807
i wish i could go tou big events all the time
But not that many down here
Simon A is offline   Reply With Quote
Old 02-16-2006, 04:10 AM   #12808
TRF415boy's Avatar
Oh right i thought there was something wrong in there, josh and XXX-S, lol. I still don't see the use of it, drivetrain efficiency is given by the radius of curvature of the belt and the longitudinal speed of the belt, cutting teeth on the diff pulley won't change any of those parameters.
Old 02-16-2006, 07:13 AM   #12809
Casey & Jimmy...are you guys racing at Mimi's the weekend of March 3rd. Carpet season is not yet over
Old 02-16-2006, 08:33 AM   #12810
TFR
TFR's Avatar
Just saw these pictures from an Hong Kong forum, seems Tamiya driver at TITC is testing new steering system.
Muchmore l AHRP l Xenon l Futaba
TFR is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
