Old 02-14-2006, 10:24 AM   #12781
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
Getting my MSX carpet car ready
I’ve decided to scrap my old set-up which was a 3mm chassis and standard arms and copy Mark R. set-up from the Vegas race (exception of the 4mm chassis – lets go Tamiya USA get it together)
I used the D/D blocks in the front as he did with the LWT arms. (I used HPI steering knuckles to clear foam tires) I assume he used the HPI knuckles as well. I used the 4mm wheel hexes as well, no shims.
Mark used Jaco Foams, I usually use Parma Foams.
I noticed that the track width exceeds the 190MM limit with the Parma Foams.
Anyone know if the Parma and Jaco rims have a different offset. I would assume they do since I copied Mark’s set-up with the exception of the tire brand.
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 02-14-2006, 11:49 AM   #12782
Originally Posted by Simon A
Its same down here in New Zealand.
Id love to buy stuff from my local hoby shop but its way too exspensive.
The price of cars has come down lately (cyclone here is 600nzd which is about 400-450) which is great but alot of other hings are way too exspensive.
I wouldnt beable to race if i had to buy my stuff from my local hobby shop
Here we have to fork out 5100 ZAR (That's 831.497 USD according to xe.com) for the MSX.
Now tell me, we're not being ripped off?
flashvc is offline   Reply With Quote
Old 02-14-2006, 12:03 PM   #12783
f1larry's Avatar
R/C Tech Charter Subscriber
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
Can anyone give me a good setup for the 415. I run rubber tires on Carpet.
Thanks,
Larry
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Exotek F1R3|X-Ray T4 16|CRC WC-Xti|TT02|TA05|TL01|
f1larry is offline   Reply With Quote
Old 02-14-2006, 12:06 PM   #12784
Trader Rating: 37 (100%+)
Thanks,
Larry
NO! muh haa haa haaaaaaaaaaaaaa
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 02-14-2006, 01:00 PM   #12785
Yes the Parma tires are a different offset and they will make the car wider. I can't remember how much the offset is off hand.
Brian Anthony is offline   Reply With Quote
Old 02-14-2006, 01:37 PM   #12786
Thanks Brian...looks like I'll have to change brands
Old 02-14-2006, 04:05 PM   #12787
I want to know if foam tires are direct fit onto the TRF415MSX or do I need to do some modification. I have never ran foam tires on this car and I want to know what I need to run foam tires.
trf_racer is offline   Reply With Quote
Old 02-14-2006, 05:13 PM   #12788
JimmyMac's Avatar
Well I ran my 415MSX at the Birds. I didn't do good at all. Seemed as the traction went up.. my car got slower. I just ended up running my EvoIV instead. Anyways, there was a factory driver there with Marc's car (or setup same as Vegas). Hubert Honigl I believe was running it. I took some pics of it. The 4mm chassis on it was sick!! Wish I had it. But once again.. Thanks to Tamiya for their support!!
Anyways, to answer TRF_RACER's question... you do not have to modify the car to run Parma foams. You only need the silver 6mm wheel hexes and a red axle shim (1mm). If you want to run Jaco foams, you need HPI Pro4/Cyclone steering knuckles with a 4mm wheel hex and a blue (0.5mm) axle shim. However, running the D/D front blocks, the car may be about 191mm or so wide. Also to run Jaco with HPI knuckles, you will need either... the Cyclone wheel axles with Tamiya dog bones... OR... Pro4/3 MIP wheel axle with Corally RDX steel dog bones.
The only reason I see to switch to HPI knuckles is if your track needs Jaco 2 stage foams to be fast... Other than that, just stick with Parma Cyan/Magenta.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 02-14-2006, 05:26 PM   #12789
Thanks for your advice.
But how did Marc Rheinard run Jaco foam tires? Did he use HPI hubs too?
Old 02-14-2006, 09:31 PM   #12790
anyone already tried the new Trinity foam tires on 415?
does it fit well?
onroaddude is offline   Reply With Quote
Old 02-15-2006, 12:33 AM   #12791
Who makes the dark colored (dark grey) ballends that are on Marc R.'s car? I've also seen them on some other cars as well. Are these stantard in the MSX kit? if not who makes them and what is the part number? Thanks.
Old 02-15-2006, 01:15 AM   #12792
Eirik's Avatar
Brian,
It's Tamiya's own Flourine coated ball ends, super smoooooth!!
TAM53599 Tamiya FL Coated Aluminum Ball Nut 5mm
TAM53598 Tamiya FL Coated 5mm Aluminum Ball Studs
Eirik is offline   Reply With Quote
Old 02-15-2006, 01:28 AM   #12793
hi anyone know the link to the manual PDF file for the 415MS?
thanks
noobie is offline   Reply With Quote
Old 02-15-2006, 03:04 AM   #12794
thanks
http://tamiya.com/english/rc/manuals.htm
I asked same question a few pages back and i got that site.
Simon A is offline   Reply With Quote
Old 02-15-2006, 03:06 AM   #12795
Maybe your setup was to soft?
marc was running a very hard setup in vegas. 60wt oil and 33lb and a 28lb springs.I ran harder springs and oil lately and it is much better. I would love to get the 4mm chassis tho
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
