Old 02-01-2006, 12:03 PM   #12571
Ballsie's Avatar
Originally Posted by Ben.C
Maybe UK drivers can lias with US drivers to get the chassis for you guys then ship it over to UK.
That's exactly what I was trying to suggest.
Ballsie is offline   Reply With Quote
Old 02-01-2006, 12:38 PM   #12572
Charles Godwin's Avatar
Another question , on the upper arm position (the aluminium bit which connects to the shock towers) what is the effect of changing from position 2 to 1 or 3 on the front, and from position 2 to 1 on the rear?
Thanks, Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 02-01-2006, 02:14 PM   #12573
Drcy's Avatar
Default MSX out of the Box on Carpet
Originally Posted by Charles Godwin
Hi Rick i have only just really got the car but on high grip carpet i have all the shims as standard at this point, Ride honda accord (A), Xray light blue springs, AE 40wt oil, 1*camber all around, 6mm ride height, no roll bars, direct centre pulley and 1 way at the front, front shocks moved in 1 hole on the shock towers. I'm gunna try a 1mm shim under the rear front block. To me it feels safe and easy to drive with full additive on rear and half additive on the front. I also use Take-Off CS22 preglued tyres with LRP carpet additive .
Charles
I found that your suggestion was a bit better than the out of the box setup but - still - I have more grip with this car than with other before but the times are not fast enough (about 0,5sec slower than my RDX) and everytime I try to make the car more agile I start loosing the rear.
Can be that the chassis is not rigid enough, or something else, but I do not know what to do...
Suggestions are welcome
rgds
Cy
Drcy is offline   Reply With Quote
Old 02-01-2006, 03:27 PM   #12574
maxepower's Avatar
Talking RE: 4MM CHASSIS!
Steve at WWW.SPEEDTECHRC.COM , sure will be able to get them thru TAMIYA and should be able to sell them at a reasonable price! He's my main connection for all my Tamiya needs!!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 02-01-2006, 03:34 PM   #12575
maxepower's Avatar
Talking SET-UP ISSUES!!!
rgds
Cy
Sounds like you need more toe-in or more camber in the back end! OH, and don't use any spacers underneath the blocks for the rear!
Old 02-01-2006, 08:35 PM   #12576
sohlman's Avatar
Trader Rating: 89 (100%+)
I made a refined version of the MSX editable set up sheet. But...I don't know how to post it for eveyone to download it. Too large to upload as a PDF (1.5mb). Could someone PM me and let me how to post a link so everyone can dowload a file from my server. Thanks.
Steve Sohl
sohlman is offline   Reply With Quote
Old 02-02-2006, 05:56 AM   #12577
I now have a MSX4 Will post some pics up later on. Bits fit straight on only needed to file the rear wishbones slightly.
Rick Draper is offline   Reply With Quote
Old 02-02-2006, 06:10 AM   #12578
Registered User
Default 415 Spool's
Hi guys !
Im new here, but I just wondered what ur opinion is about spools ? Do u race them, and which omes do u use ? I race both my EvoIV and my MSX in Stock and it seems that more and more runs spools both in Stock and Mod.
Best Regards
TRF-Alex is offline   Reply With Quote
Old 02-02-2006, 06:42 AM   #12579
veecee's Avatar
Trader Rating: 34 (100%+)
Maybe email it to Tryhard and he can put it onto his site - http://www.thard.co.uk/
veecee is offline   Reply With Quote
Old 02-02-2006, 06:57 AM   #12580
Eirik's Avatar
Thanks, Charles
Hello,
Up Front: Shorter link = less steering and more stable going inn to corners!!
Rear: Shorter link = more High Speed steering and more stabillity, "Less Grip"
Rear: Longer link = More turn inn, more traction, but less stabillity!!
This is more or less what you will feel when you make this changes....
Eirik is offline   Reply With Quote
Old 02-02-2006, 06:57 AM   #12581
sohlman's Avatar
TryHard, are you open to that? PM me.
Steve Sohl
Old 02-02-2006, 07:39 AM   #12582
TryHard's Avatar
sohlman, YGPM
| THard.co.uk | Xray | MuchMore |
Old 02-02-2006, 08:28 AM   #12583
Originally Posted by TRF-Alex
Hi guys !
Best Regards
I race my MSX bot indoors on carpet (with rubber-tires) and outdoors. Outdoors I almost ALWAYS runs the spool, as I think it has a big advantage in comparison to diff or oneway..... The pull out of corners, and the ability to bring the cars to a stop at the end of the straights. Outdoors I would say I use the spool 95 % of the time, and and indoors around 50-75% of the time. It tends to make the car understeer a little, but this is compensated by the braking, and I have seen my lap-times drop 1-2-3 tenths when going from one-way to spool !
Best Regards
Jimmy
Jimmy Swift is offline   Reply With Quote
Old 02-02-2006, 09:13 AM   #12584
TRF415boy's Avatar
Lol we already made an interactive setup sheet for the MSX.
TRF415boy is offline   Reply With Quote
Old 02-02-2006, 10:05 AM   #12585
Thanks Eirik
Charles
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
