Old 01-27-2006, 08:18 AM   #12511
Sushi boy
What wrong with the rear diff the thrust bearing should cope with 80 90 plus runs before needing to be replaced.
If the diff is gritty you need to sand the groove out of the diff rings with 800 grit wet and dry until you get a shiny flat surface. Then bed it in by running it slightly loose under load for 20 sec retighten and it should be smooth a silk with the wheels on when tighten so it dosen't slip.
Over tightening a without bedding in a new groove will flatten the balls and cause that gritty feeling.
You should also run as trf boy says ceramic balls ($10 form acer)in the diff and only put smear of lube on each ball. This stop the diff slipping and attracting dirt so you don't need to over tighten it.
Also clean your hands and every thing else you are using to put the diff back together with any grit in the rebuild will make it feel rough.
And make sure the thrust bearing has being fully flushed out and dryed before relubeing.
better instructions click here
We have to do this for a 1/12th and 2wd drive off road as a bad diff can chronicly screw up the handling making the car lose it smoothness in the corners.
Smoking motor.. is offline   Reply With Quote
Old 01-27-2006, 10:27 AM   #12512
Trader Rating: 18 (100%+)
Send a message via AIM to Roberto Falcon
If you guys are interested in my Tamiya stuff PM me so I can give you a price that I can't post ..
Roberto Falcon is offline   Reply With Quote
Old 01-27-2006, 06:21 PM   #12513
dsrbltoys's Avatar
Sushi, check your local track. Gee, guess what, its in stock!
dsrbltoys is offline   Reply With Quote
Old 01-27-2006, 08:42 PM   #12514
HVFracingwilly's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to HVFracingwilly
couple a questions for you guys
first what is the part number of the tuning spring set
second what is the part number for the tunning swaybars
thanks alot guys here are some pics of the new ride(first tamiya) im crossing my fingers in hope.
Tamiya TRF415-tamiya-001.jpg   Tamiya TRF415-tamiya-002.jpg   Tamiya TRF415-tamiya-003.jpg   Tamiya TRF415-tamiya-004.jpg
Hobbytown USA Oshkosh
www.revolutionraceway.com
HVFracingwilly is offline   Reply With Quote
Old 01-27-2006, 11:00 PM   #12515
R/C Tech Charter Subscriber
What is the biggest 64pitch spur gear that can fit in a MSX?
NismoSkyline17 is offline   Reply With Quote
Old 01-28-2006, 05:25 AM   #12516
I have got a 106 on mine and any bigger and it will probably be out of the bottom of the chassis.
Rick Draper is offline   Reply With Quote
Old 01-28-2006, 07:33 AM   #12517
Thanks. Guess that makes the 111t I found in my pit box useless.
Old 01-28-2006, 08:04 AM   #12518
sohlman's Avatar
Trader Rating: 89 (100%+)
Heading off for my maiden voyage tomorrow. Any glaring issues with my setup? Much appreciated.
Steve Sohl
sohlman is offline   Reply With Quote
Old 01-28-2006, 08:15 AM   #12519
E.J. Evans's Avatar
Send a message via Yahoo to E.J. Evans
Hey Sohlman, everything looks pretty good. At some point you should try running your droop settings the other way, (2mm in front and 4mm in the rear). Same with camber, (1.5 front and 2.0 rear). This works for me but could be differnet for someone else. I know Marc ran things the other way, but these changes take little time to do and won't hurt to try.
Good Luck.
T.O.P. Racing | APEX Hobbies | R1 | Solaris | NorCal Hobbies |
Solaris Racing Products (SRP) Solaris Spec Tires!
www.solarisrp.com | www.apexhobbies.com | www.topracingusa.com
E.J. Evans is offline   Reply With Quote
Old 01-28-2006, 11:08 AM   #12520
sohlman's Avatar
Thanks EJ. I'm planning on trying a few things...I'll add this to the list.
Steve Sohl
Old 01-28-2006, 12:02 PM   #12521
Trader Rating: 37 (100%+)
EJ is right for the droop switching...
But 2 and 4mm? That seems really high. Here in the Midwest where carpet is king I can pretty much say no one ever runs that much. I think for a foam car with that much droop it will feel lazy.
I would run 1.5 and 2.0mm if traction is decent.
That's just my opinion. Most people around this area race on carpet and I've never seen anyone run that much droop.
Good luck either way.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 01-28-2006, 08:37 PM   #12522
JimmyMac's Avatar
sohlman, I converted Marc's 4mm chassis wheelbase over the the 2.5mm wheelbase and the front inner shims would be 1mm and the rear inner shim would be 0mm. So it's a very short wheelbase. My droop when measured with the new Tamiya droop gauge and 56mm tires, comes out about 3.5mm front(under grubscrew hole) and 4mm rear(under rear hub). I also run 1.5 camber front and 2.0 camber rear.
I also found out that my corner speed got better when I added more rear toe. Today I was running my EvoIV on carpet. I got it just about dialed in finally. So I'm gonna try and convert the setup over to the MSX for testing next weekend. But anyways, I was running (in the rear) the 1X/1A block. And I had horrible corner speed. But I switched to 1X/1C and it picked up awesomely. So that might be something you can try.
Wish I had time to try EJ's setup. But I don't have all of my old style suspension parts laying around. Did you use a 3mm chassis?
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 01-29-2006, 09:17 AM   #12523
KillWency's Avatar
Should I use a spool or one way for this new track?
pics http://www.rctech.net/forum/showthre...page=316&pp=30 Post #9466 Post #9475
video of the track http://rapidshare.de/files/11926191/Mvi_0957.avi.html
Thats not me driving btw. local racers driving.
KillWency is offline   Reply With Quote
Old 01-29-2006, 09:18 AM   #12524
Well I'm ordering me a MSX2 tuesday from Steve as well as the DJ suspension and all the X* blocks and a spool. Anyone happen to have an extra locked center pulley for the car that they are willing to sell since everyone is out of stock on them?
Old 01-29-2006, 10:18 AM   #12525
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Rainbow Ten has the direct center pulley in stock, at least yesterday.
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Savx - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
