Like Tree3Likes
Tamiya TRF415
Old 01-20-2006, 08:06 AM
  #12406
TRF415boy's Avatar
Originally Posted by Crashmaster
Has anyone actually fitted the full pro 4 suspension to the 415? If so, do you need all different dogbones and axles etc, or can you just use the std 415 ones?
I know Reinhard was surposed to have done it, but wondered if any of you guys had. Seems a more viable route than buying all the parts to convert the std 415 suspension over to the LW stuff due to availability of parts in the UK.
Cheers
Dan Chambers
Why not buy the LW conversion kit for the TA05 ? It will fit, only spacers for the wishbones will have to be fitted for the 415, look at setup sheets to see how many.
TRF415boy is offline
Old 01-20-2006, 09:03 AM
  #12407
axle182's Avatar
Trader Rating: 18 (100%+)
Originally Posted by TRF415boy
Pro4 hinge pins : 1.5mm
Tamiya LW hinge pins : 1.6mm...
BUT tamiya does make 2° C-Hubs for the LW suspension as well as 4° ones.
Do u have a part No. for the 2 deg hubs only? Im not forking out for the LW just for the c hubs lol Ill give the Hpi c hubs a go, hopefully ill have it running. Thanks
axle182 is offline
Old 01-20-2006, 09:12 AM
  #12408
Whats the LW suspension? sorry new to all this
natskiboy is offline
Old 01-20-2006, 09:31 AM
  #12409
V12
V12's Avatar
The LW suspension is the one as used in the 415MS and MSX.
V12 is offline
Old 01-20-2006, 06:51 PM
  #12410
Does anyone know the part no for the diff ring replacement?
I am trying to rebuild the rear diffs on the 415 and I got some stock parts from a TB02 diff but its not as smooth. I already am using new Tamiya Carbide balls so it cant be that
Old 01-20-2006, 07:40 PM
  #12411
OK guys i need some opinions. I want to do TCS this year. I have an original 415 with the MSX conversion that i have not even run yet. I live in Socal so i can practice at Tamiya to get it dialed in, but after reading the TA-05 thread it sounds like that car may be a little easier to dial in. Which car is easier to tune? i see a few that have both. Alhough GT1 sounds like it may be more fun since it is 19turn now and Tamiya is a little on the bigger size.
tcmerf is offline
Old 01-20-2006, 08:42 PM
  #12412
The 415 is easy to dial in at the tamiya track. But, it's always fun to get new toys.
Juan Aveytia is offline
Old 01-21-2006, 10:24 AM
  #12413
Guo Chean's Avatar
does anyone have any link to get the Jurgen front alum ball diff outdrive in United States? thANKS
Guo Chean is offline
Old 01-21-2006, 12:45 PM
  #12414
Charles Godwin's Avatar
Finally got a picture of my 415msx ,click here to view but it is a bit blurry
Charles
Charles Godwin is offline
Old 01-21-2006, 02:19 PM
  #12415
Dan415ms's Avatar
Talking Pic of my new shell
Just mounted my new shell courtesy of and signed by Mr. Rheinard himself
It looks awesome on my MSX!! May even run it at our Scottish GP if i'm brave Just need to add a few decals......
Dan
www.sdrcc.co.uk
Dan415ms is offline
Old 01-21-2006, 03:36 PM
  #12416
Can anyone post a pic of how they mounted their ESC and receiver on a 415?
I have a Novak GTX and a KO310Rf receiver, currently I have the receiver standing at the back of the servo and the ESC close to the motor. I am afarid the heatsinks on the GTX touch the motor mount
Pics would be appreciated
Old 01-21-2006, 07:17 PM
  #12417
Casey's Avatar
anyone know the spring rate in pounds of all the Tamiya Onroad springs,
blue, red, white, yellow, grey, purple, ect.......
Casey is offline
Old 01-21-2006, 07:24 PM
  #12418
No, I don't think anyone would know except they measured it. That's why Marc Rheimard uses Xray springs.
trf_racer is offline
Old 01-21-2006, 10:03 PM
  #12419
Customworksking's Avatar
Trader Rating: 74 (100%+)
Arrow springs
red 10.5,Yellow 11.83,Blue 14.08,White 17.25,Gray 20.91,Purp 22.72 U can get them all on Tryhards web site find one of his post's and click on the link
Customworksking is offline
Old 01-22-2006, 04:45 AM
  #12420
dodo's Avatar
here you go, i can't get the capacitor down and double-taped to the chassis though. maybe someone out there got a better layout. but this might give you some idea. i managed to snap this pic a few weeks back, now i'm already using VFS-1 , btw mine is KR-302F receiver, not sure how different it is in terms of size with KR-301F...
dodo is offline
