Old 01-19-2006, 08:22 PM   #12391
Sushi Man's Avatar
Send a message via AIM to Sushi Man
Hey Guys When I bought this car it didnt come with stabilizers.. Just wondering If i would need them
I race at 2 track
Asphalt HIGH GRIP , little bumpy
Carpet HIGH GRIP OZITE, TINY TINY bumps..
Both are tight tracks and small tracks
Sushi Man is offline   Reply With Quote
Old 01-19-2006, 08:31 PM   #12392
Originally Posted by trf_racer
Yes, I agree that rubber tires should always to be used on electric cars. Foam is only for 1/12 scale and nitro.
Agreed...!
I race at 2 track
Thanks.
You race using rubber or foams?? Which car are you refering? The standard 415 or the MS or the MSX??
Ben.C is offline   Reply With Quote
Old 01-19-2006, 09:31 PM   #12393
Sushi Man's Avatar
Oh sorry.. Im running STOCK and maybe 19t soon... RUBBER
and I run the old susension (original 415) with 3 mm chassis and i took the sides of the stiffners all off (the 4 blue things)
Old 01-19-2006, 10:23 PM   #12394
squeege's Avatar
i need some foam tire set ups for the 415 msx preferebly w front diff and indoor carpet
squeege is offline   Reply With Quote
Old 01-19-2006, 10:26 PM   #12395
Sushi Man's Avatar
I ve heard that the old suspension (TA04) works better for foams rather than the new light weight/... again thats wat IVE been TOLD.
Old 01-19-2006, 10:43 PM   #12396
I think the old suspension is good for carpet is due to people are runnning foams on carpet.
For rubber,I think the new susp works better,and without the stiffeners for racing asphalt.
Old 01-20-2006, 05:57 AM   #12397
So last night I put evrything back to normal (suspension blocks) as per manual.
Anyone have a setup I can borrow to start with?? what settings? Is caster adjustable?
natskiboy is offline   Reply With Quote
Old 01-20-2006, 08:12 AM   #12398
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
I dont know how, but i found a set of 2 deg caster blocks in my tool box last night. I check out pics of the Pro-4 ones and they look like they are pro-4 ones. I know its mentioned somewhere in this thread (couldnt find it) but what extra hardware do i need to use these blocks? will they bolt inplace of the Tamiya ones? Thought id ask before stripping the front end! Thanks guys.
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 01-20-2006, 08:34 AM   #12399
m8commando's Avatar
Read post #12364, your going to have to use the Pro4 arms & hinge pins to use the castor blocks.
JAF RACING / AIRTRONICS
m8commando is offline   Reply With Quote
Old 01-20-2006, 08:39 AM   #12400
axle182's Avatar
Originally Posted by KilRuf
No, the outter hinge pins are different diameter. You'd have to use the Pro4 suspension arm if you wanted to use the castor blocks. The inner hinge pin for both the Pro4 and 415 is 3mm diameter....
which is larger diametre? the Pro4 outer hinge pin or the Tamiya? if the Tamiya is the larger diametre, i might try to widen the hinge pin hole on the HPI caster blocks so i can use 2 deg caster.
Aaron "AJ" Freind
Old 01-20-2006, 08:43 AM   #12401
So bottomline, the stock 415 doesnt have caster adjustment
Old 01-20-2006, 08:52 AM   #12402
axle182's Avatar
I beleive there is Tamiya 2 deg caster blocks. Im trying to use the Pro 4 ones on my 415 as the HIP blocks came with the car for some reason. It also came with that fancy alloy ball diff, just the halves. I finally got it working fine with Tamiya parts and a AE diff spring (Tamiya one was too long). Ive heard its supposed to have blades also (which i dont have) so the dog bone ends are covered in AW grease, and the car is only running in stock so hopefully it wont damage anything. We have a big race meeting here this weekend (drive down to it later today) and didnt have time to order in any parts
Im wanting to try different caster settings, trying to get a free and balanced feel on carpet with foams.
Aaron "AJ" Freind
Old 01-20-2006, 08:59 AM   #12403
Crashmaster's Avatar
Has anyone actually fitted the full pro 4 suspension to the 415? If so, do you need all different dogbones and axles etc, or can you just use the std 415 ones?
I know Reinhard was surposed to have done it, but wondered if any of you guys had. Seems a more viable route than buying all the parts to convert the std 415 suspension over to the LW stuff due to availability of parts in the UK.
Cheers
Dan Chambers
Crashmaster is offline   Reply With Quote
Old 01-20-2006, 09:04 AM   #12404
TRF415boy's Avatar
Pro4 hinge pins : 1.5mm
Tamiya LW hinge pins : 1.6mm...
BUT tamiya does make 2 C-Hubs for the LW suspension as well as 4 ones.
TRF415boy is offline   Reply With Quote
Old 01-20-2006, 09:04 AM   #12405
TRF415boy's Avatar
As said above, there are 2 and 4 C-Hubs for the LW suspension.
For the std suspension, there are 6 and 4 hubs.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
