Old 01-18-2006, 05:36 PM   #12361
Trader Rating: 18 (100%+)
Send a message via AIM to Roberto Falcon
You guys are talking about using the Pro4 steering knuckles.. does the pro4 castors also work ?
Roberto Falcon is offline   Reply With Quote
Old 01-18-2006, 05:51 PM   #12362
Trader Rating: 37 (100%+)
Default 415 Tamiya/Yokomo Front Diff
Here's what I put together awhile back but took the website down...
Parts Needed:
Yokomo ZS-501 Diff Halves or ZS-502S for steel outdrives
Yokomo ZS-506 Diff Rings or Tamiya 50880 TA04 Ball Diff Plate Set
Yokomo ZS-507 Thrust Balls and Washers
Yokomo ZS-508 Diff Screw and Locknut
Yokomo ZC-S100 10.0mm spacer shim set
Tamiya 51055 TRF415 Ball Diff Pulley
Tamiya 53379 3mm Lightweight Diff Balls
2qty Tamiya 53030 Ball Bearings
2qty Tamiya 53126 Ball Bearings
I'll have the actual website up and running again soon. Some people on this thread might remember I had parts and pics of everything needed and almost step by step on how to put the diff together.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 01-18-2006, 05:51 PM   #12363
rtypec's Avatar
Originally Posted by Evicerator
Do they sell that new bladed diff assembly separate now...? Anyone have part #s for EVERYTHING you would need... including dogbones/blades...?
Hi Steve,
RC Alum Diff Joint Set - TRF415
Item #53889 (COMING SOON)
High precision aluminum parts allow diff adjustment without removing joint from chassis, and are easy to perform maintenance on.
*Compatible chassis: TRF415, TRF415MS, Chassis with Item 49378 TRF415MS Up-Grade Parts Set, TRF415MSX
I'm not sure exactly what this comes with it.
rtypec is offline   Reply With Quote
Old 01-18-2006, 05:54 PM   #12364
JimmyMac's Avatar
No, the outter hinge pins are different diameter. You'd have to use the Pro4 suspension arm if you wanted to use the castor blocks. The inner hinge pin for both the Pro4 and 415 is 3mm diameter....
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 01-18-2006, 06:01 PM   #12365
Alright thanks Jimmy... Btw anyone know where can I find this piece ?
the plastic piece that says Tamiya..
And where can I get setups for the MS ?
Old 01-18-2006, 06:09 PM   #12366
TryHard's Avatar
With regard to std suspension rear uprights...
http://www.speedtechrc.com/store/ebp...id=267&id=1714
Come as standard with the original 415, 2deg toein
http://www.speedtechrc.com/store/ebp...id=267&id=1710
Optional 1deg rear hubs.
@Nexus, Awesome news, when you get it back up I'll link to your site on mine for the tips bit
@Roberto Falcon;
I believe you can get that part with some Evo4 bits... ah yes, here we go.
http://www.speedtechrc.com/store/ebp...id=272&id=1695
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 01-18-2006, 06:38 PM   #12367
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
does anyone have the email contact of the Jurgen aluminium front and rear diff outdrive please PM me thanks a lot.
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 01-18-2006, 06:54 PM   #12368
[email protected]
DOTMAN is offline   Reply With Quote
Old 01-18-2006, 07:06 PM   #12369
Well i bought the MSX conversion the first week t was out and still have not run it. Anyone have a good baseline set up for Tamiya America runnig 19 turn?
FT B44 - FT J82
LRP TC SPHERE - Futaba Fasst
Orion Lipo & Vortex motors
" Go that way really fast, if something gets in your way, turn"
tcmerf is offline   Reply With Quote
Old 01-18-2006, 09:09 PM   #12370
maxepower's Avatar
Talking
The Tamiya website has the Dave Jun set-up. It's a good baseline for the MSX!
There will be a couple of them. One of them is for the MSX! I think it is! You can fine tune from there!
It will work at the Tamiya Track!
Use RP-30's, Takeoff -27's or Sorex 32's. All these tires work well at Tamiya!!!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 01-18-2006, 10:16 PM   #12371
Where can I get the conversion kit at?
Old 01-18-2006, 10:30 PM   #12372
Thanks. How do the RP's work. I have never run anything but Take offs out there. As far as the conversion goes i would try Steve at Speedtech first. Ultimate had them last time i was there but that was quite a while ago.
FT B44 - FT J82
Old 01-18-2006, 10:58 PM   #12373
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Seattle Indoor Raceway has them instock.
tamiyarcracer is offline   Reply With Quote
Old 01-18-2006, 11:03 PM   #12374
Maybe you can try the japanese importers....
ChampRC or Rainbowten
Ben.C is offline   Reply With Quote
Old 01-18-2006, 11:21 PM   #12375
maxepower's Avatar
Talking Take-off's vs. RP's
RP's work good once they warm up! If the weather is too warm the Take-offs might overheat and make the car a little slippery towards the end of a run!
Still, both are very similar!
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
