Old 01-12-2006, 05:55 AM   #12226
Eirik's Avatar
I would take this one instead, lighter, cooler and stronger
This is the ones I use for my MSX!!
Eirik is offline   Reply With Quote
Old 01-12-2006, 06:48 AM   #12227
hierog's Avatar
Originally Posted by bender
Exactly!
Like this:
thanks!!! great explanation and thanks for the help!!
vic
hierog is offline   Reply With Quote
Old 01-12-2006, 07:53 AM   #12228
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
Originally Posted by sohlman
Just finished the ride. Getting ready to set it up and I could use a few suggestions. First, some background: planning on running carpet stock and 19T with foams, 3mm chassis, standard arms, front diff, etc (check the pics).
Questions:
1. What's the internal drive ratio for the MSX?
2. What's a good final drive ratio?
3. A hole does not exist to mount the center aluminum brace (in front of the motor, that goes from the top deck to the chassis)...should I drill one?
4. Do the diff need a lot of breaking in?
Any other suggestions would be greatly appreciated. I've never run Tamiya and after building it, this car has excellent fit & finish. I hoping to run it on asphalt one day with rubber, but I've got plenty of nitro onroad obligations to contend with before I launch into another category. Thanks in advance.
Watch out Carl...
The car looks really good Steve...I see you really made good use of the standard 415 parts... nice job on the graphite
Double check your wheel base width with a set of tires...May be too wide with both red and silver wheel spacers...
No need to break-in the diff...run it once and double check afterwards...my diffs have remained fairly consistent....run the front diff tighter than the rear.
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 01-12-2006, 02:31 PM   #12229
sohlman's Avatar
Trader Rating: 89 (100%+)
Thanks Carl. Do you know a decent final drive ratio? I usually run very small foams...like 58mm or less. Looking forward to running it next weekend at the Jam. Want to go?
Steve Sohl
sohlman is offline   Reply With Quote
Old 01-12-2006, 03:00 PM   #12230
Not to sure about the Jam as its a full weekend race...last time I ran 19T at Mimi's, I ran 37 / 102 with 56.5mm foams.
Old 01-12-2006, 03:05 PM   #12231
Default 415msx carpet setup with rubber
I'm lookiing for a 19t rubber on ozite setup. I can not seem to find anything. please can someone help me. thanks
tqboy is offline   Reply With Quote
Old 01-12-2006, 04:21 PM   #12232
JimmyMac's Avatar
Just Search this thread (button at top right) and look for "Vegas" and "Martin" and it'll bring up some posts that have the setups for 19t rubber/carpet for regular 415. For MSX just go to RCZone.net and look under setups/415MSX and Marcs setup is posted there.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 01-12-2006, 06:46 PM   #12233
maxepower's Avatar
Exclamation Spool issues!!!!!!!!!!!!!!!!!!!!!!!!
Originally Posted by TryHard
It is possible to get just the outdrives now. I know Champ RC has them instock. You could try asking steve at Speedtech to see if he can get them in as well...
http://www.rctech.net/forum/showpost...&postcount=339
HiH
Ed
I was told they were not going to sell them separetely!
Thanks for the info!
I got Speedtech's last one!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 01-13-2006, 09:58 AM   #12234
Trader Rating: 37 (100%+)
Ah...I'm back! :P
Tryhard...If I can find my old html page with the front diff pics and instructions I'll get that to you.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 01-13-2006, 01:52 PM   #12235
Default 3mm Chasis
With the 415 does running a 3mm chasis make that big of a difference ? I currently run stock rubber with the standard suspension on carpet.
RacerX18 is offline   Reply With Quote
Old 01-13-2006, 02:09 PM   #12236
Send a message via AIM to GroffBall
If you have the original 415 not the MS or MSX you already have the 3mm chassis.
GroffBall is offline   Reply With Quote
Old 01-13-2006, 02:25 PM   #12237
rayhuang's Avatar
Hey all,
I am currently running my 415MS with old school hard suspension. I have the D1 block in front (straight pins)and narrow hexes with a blue spacer and in the back are b and c-blocks for inboard toe in, narrow hexes and a blue spacer.
If I wanted to increase mechanical grip all around, would I run narrower inboard blocks and wider hexes or the opposite? Wider arms spacing and narrow hexes?
Thanks,
Ray
p.s. if anyone feels like giving a tutorial or a link to one-I am listening
Old 01-13-2006, 03:19 PM   #12238
m8commando's Avatar
Does anybody know where I can find the Tamiya spool Part# 49358. Thanks
JAF RACING / AIRTRONICS
m8commando is offline   Reply With Quote
Old 01-13-2006, 03:41 PM   #12239
Charles Godwin's Avatar
Probably best to e-mail rc-champ or get the speedtechrc spool
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 01-13-2006, 09:10 PM   #12240
maxepower's Avatar
Exclamation
If you can't find it anywhere, you can always order it online directly through Tamiya, of coase you'll have to pay full retail!
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
