Old 01-11-2006, 05:01 PM   #12196
m8commando's Avatar
A couple of questions for you 415MSX owners
1. Is there a durable spool out there for this car, and is the delrin Tamiya spool worth the purchase.
2. How do you get the steering slop out of the graphite/bearings. Anyone have any suggestions. It doesnt make sense.
JAF RACING / AIRTRONICS
m8commando is offline   Reply With Quote
Old 01-11-2006, 05:21 PM   #12197
TryHard's Avatar
The tamiya spool is fine for outdoor work I find... indoors, I wouldn't chance it though. You could try the TiR one, has removable alloy outdrives.
Regarding steering slop, most of it actually comes from the ball cups, but there are a few things you can do to help reduce it.
1) place 0.1 or 0.2mm shims on the aaxles, between the hex pin and bearing. Do so the axle still spins freely.
2) Use axle spacers on the steering posts. I've found that 0.3mm below, and 0.1mm above seems to work very well at stoping the bellcranks riding up the posts, which also seems to be a specific area which induces slop. (the old setup on the std and MS only required 0.3mm)
3) only use 1 0.1mm shim between the steering rack bearings and bell crank. 0.2mm seems to make the rack "wobble". Using 0.1mm keeps the rack from binding on the bell cranks, but reduces the wobble.
4) make sure your C-hubs are shimmed properly
A 5th one to add, for thoose who have the conversion, is get hold of the grub screw outer hinge pin set. This helps remove some slop also by tightening up the C-hub onto the pin. Just make sure the pins are still free to rotate in the wishbone.
With all thoose points done, you really are only left with changing the ball joints and cups. I've only really used the Tamiya ones, so can't comment on others... but a little bit of slop doesn't seem to hurt the performance (just make sure you push back on the axles when setting toe-in )
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 01-11-2006, 06:04 PM   #12198
JimmyMac's Avatar
Has anyone tried the "plastic" bag over the ball stud trick to remove slop? I know it worked on the Yokomo ones. But haven't tried it on the Tamiya ball studs. Also if you superglue the steering plate bearings in place, it will help reduce some slop as well. This prevents the bearing from wiggling around in the graphite steering plate.
As for the Tamiya spool, I very much prefer those over steel ones. My testing has showed me the Tamiya spool gave me more corner speed with less chatter vs the steel spools. However they can be very fragile. In fact I just bought 2 of them off of SpeedtechRC. They finally got a shipment in. Been looking all over for them.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 01-11-2006, 07:47 PM   #12199
hierog's Avatar
Default turning radius
i finished building my msx, put it on the setting board and started to adjust toe/camber etc. However, in order to get the settings correct, my right turnbuckle which adjusts toe is significantly longer compared to the left, which makes the turning radius turning right much larger than turning left. it's weird in that this is how it must be set in order to keep my toe/camber combination correct!! the turnbuckles are both the same size, so i am even more baffled.
any suggestions before i build another set of turnbuckles?
thanks
vic
hierog is offline   Reply With Quote
Old 01-11-2006, 07:57 PM   #12200
I am pretty sure that you did something wrong when assembling your car. Check the hole that you use on the front upright that connects to the steering turnbuckle.
trf_racer is offline   Reply With Quote
Old 01-11-2006, 08:11 PM   #12201
maxepower's Avatar
Talking Spool issues!!!!!!!!!!!!!!!!!!!!!!!!
You bought two spools! I've been wondering if there is any aftermarket company that just sells the delrin outdrives that will fit the Tamiya spool. If not then I will have to buy replacement spools just for the outdrives! I like the delrin outdrives, very smooth and improves turning because it's not as likely to chatter like the steel ones! I tried the steel outdrives on my 415 that was from the TA05 spool and it chatters at full throw. Anybody knows of replacement delrin outdrive or that maybe modified to work, I would greatly appreciate it! Thanks in advance!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 01-11-2006, 08:16 PM   #12202
sohlman's Avatar
Trader Rating: 89 (100%+)
Default Ready to go racing...almost
Just finished the ride. Getting ready to set it up and I could use a few suggestions. First, some background: planning on running carpet stock and 19T with foams, 3mm chassis, standard arms, front diff, etc (check the pics).
Questions:
1. What's the internal drive ratio for the MSX?
2. What's a good final drive ratio?
3. A hole does not exist to mount the center aluminum brace (in front of the motor, that goes from the top deck to the chassis)...should I drill one?
4. Do the diff need a lot of breaking in?
Any other suggestions would be greatly appreciated. I've never run Tamiya and after building it, this car has excellent fit & finish. I hoping to run it on asphalt one day with rubber, but I've got plenty of nitro onroad obligations to contend with before I launch into another category. Thanks in advance.
Watch out Carl...
Tamiya TRF415-trf415_side1.jpg   Tamiya TRF415-trf415_side2.jpg   Tamiya TRF415-trf415_side3.jpg   Tamiya TRF415-trf415_front.jpg   Tamiya TRF415-trf415_back.jpg
Steve Sohl
sohlman is offline   Reply With Quote
Old 01-11-2006, 08:24 PM   #12203
dodo's Avatar
Send a message via Yahoo to dodo
Questions:
Watch out Carl...
the internal ratio is 2.187, you can find it in the manual
it's strange that there's no hole to mount the center alum. brace. i got the first batch of MSX kit and it's there. in that case you should drill one, or maybe you want to check with your LHS whether they can do anything about it.
dodo is offline   Reply With Quote
Old 01-11-2006, 08:27 PM   #12204
Your chassis does not have a hole for the center post because it's the 3mm chassis. It's from the original TRF415.
Old 01-11-2006, 08:31 PM   #12205
sohlman's Avatar
I think the 3mm chassis is a MS chassis. My 2.5mm MSX chassis has the hole and I can line it up perfectly, but if it's not needed for stability, then why drill it.
Steve Sohl
Old 01-11-2006, 08:37 PM   #12206
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
My MS chassis is 2.5mm.
Racing4Evo is offline   Reply With Quote
Old 01-11-2006, 08:38 PM   #12207
Jack2's Avatar
The 3mm chassis is not from the MS, the MS was 2.5mm only. trf_racer is correct, it's from the standard 415.
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 01-11-2006, 08:45 PM   #12208
dodo's Avatar
my bad i didn't read abt the 3 mm chassis in ur earlier post.
my suggestion : try it out, if it feels fine then no need to go through the hassle of drilling the hole.
Old 01-11-2006, 08:46 PM   #12209
sohlman's Avatar
Sorry, I'm showing my newbie knowledge of this cars history. I received a back up car with full MS parts on it and it used this chassis.
Until the 4mm chassis arrives in the US in late Feb, is this the stiffest chassis I can get?
Steve Sohl
Old 01-11-2006, 08:52 PM   #12210
RayWarner's Avatar
Send a message via AIM to RayWarner
Originally Posted by Nexus
Joey,
Both cars are fast and I've raced both...the quality, fit and finish of a Tamiya is just so much nicer. Also driving the belt car will be much smoother.
With the new two piece bulkheads working on the car should be easier. Plus at times you might not be able to just walk into Trackside or IRP and find the part you need...
All that said I'd run a MSX anyday over the TC3....on rubber tires atleast.
See you at the track.
Oh yeah!! Who says? Look me up if you need something at IRP.
RayWarner is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
