Old 01-07-2006, 07:04 AM   #12091
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Originally Posted by qwerty
hi. i cant find my manual.
anyone knooe the part number for the front pulley? (just the black pulley, no outdrives required)
51055 is the part number for diff pulley
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Savx - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 01-07-2006, 08:01 AM   #12092
JimmyMac's Avatar
A friend fitted on a Yokomo BD battery strap onto his MSX... so you might wanna try that.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 01-07-2006, 12:17 PM   #12093
TryHard's Avatar
Originally Posted by Charles Godwin
I am wondering what the effects of having the urethane bushings in the shocks (red foam peice 53577) are and having them out and how this effects the handling of the car .
Thanks, Charles
I go this from Dave Spashett.
Tryhard
The foam above the bladder increases pressure in the shock. This can help to make the car react quicker. One because it will allow you to use lighter oil and secondly because the shock will return quicker. I have used this on faster circuits and found it to work well. On carpet i prefer to use no foam and slightly more oil.
David
I'm going to try it myself tomorrow, one set of shocks with 50wt oil, 3 hole pistons, and the foam, and one set with 60wt, 3hole pistons, no foam. I'll let you know how it goes.
EDIT - On the Bench in front of me, it's quite easy to tell the difference between the two sets. The one with foam certainly bounces back quicker, which in turn seems to make it feel stiffer (this was done without any springs btw). I think I'll try it on the track before I make any predicitons
Ed
| THard.co.uk | Xray | MuchMore |
TryHard is online now   Reply With Quote
Old 01-07-2006, 12:36 PM   #12094
Send a message via MSN to Grindog001
Tryhard
David
Ed
where are you trying this? don valley or carpet masters? i will be at the carpet masters if you are there?
Grindog001 is offline   Reply With Quote
Old 01-07-2006, 12:40 PM   #12095
TryHard's Avatar
going to West Bridgeford, for the Schumacher indoor winter series.
Don Valley is the next three weekends on the trot
Old 01-07-2006, 01:20 PM   #12096
Charles Godwin's Avatar
Thanks TryHard
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 01-07-2006, 03:59 PM   #12097
Sushi Man's Avatar
Send a message via AIM to Sushi Man
Yeah I just got this car (415with some ms parts) WoohHOO
It looks great, I need help with setup tho. Going to be racing in VERY low grip Carpet, (Cant use foams). I need to know shock position maily (ill just go softer on the springs). Thanks you
also we are not allowed to use traction compund either ( its a public community center and they dont want marks ) but i use simple green.
Sushi Man is offline   Reply With Quote
Old 01-08-2006, 05:32 AM   #12098
did he have the get the battery tray (BD-118T MR-4TC BD BATTERY TRAY
) that goes on the bottom aswell?
thanks
qwerty is offline   Reply With Quote
Old 01-08-2006, 09:53 AM   #12099
Crashmaster's Avatar
Evening all,
Got a few questions to ask. I have a std 415 on the way (thks TryHard) nd I'm going to put a MSX conversion kit onto it. Now after having a word with TryHard with regards to tuning parts, I'm about to order the following:
2 x Tamiya 53440 On-road tuned hard spring set 735x2=1470Yen
1 x Tamiya 53685 TRF415 Front bridge suspension mount (A) 662Yen
1 x Tamiya 51067 TRF415 Suspension mount (C) 588Yen
1 x Tamiya 51066 TRF415 Suspension mount (B) 588Yen
1 x Tamiya 51065 TRF415 Suspension mount (A) 588Yen
Are there any other parts that I would be recomended to look at? I;ve had a read though some of the older stuff in the thread, just its abit difficult to find out what I need, lol.
Also, do I need different length driveshafts to run the front A-Bridge (read something about it earlier in the thread).
Cheers all
Dan Chambers
Crashmaster is offline   Reply With Quote
Old 01-08-2006, 10:02 AM   #12100
Send a message via AIM to GroffBall
Has anyone ever tried to put the STD suspension on a MS car. I know the suspension mounts are closer together just wondering if it will work before I start ripping cars apart. I'm grasping for straws trying to get this car to steer on a very high grip asphalt track. Its so sticky your feet stick when you walk. If anybody has an setup advise it would be greatly appreciated I've never been this stumped before.
GroffBall is offline   Reply With Quote
Old 01-08-2006, 10:15 AM   #12101
Trader Rating: 27 (100%+)
I have the stock suspension from the original TRF415 on my TRF415-MSX if that helps you any? I use the Stock suspension for carpet racing and the LW suspension for outdoors.
JoeyE is offline   Reply With Quote
Old 01-08-2006, 12:02 PM   #12102
if your running outdoors then stick with the ms suspension set up.
try HPI silver spriongs all round and HPI front hubs,this will give you more steering
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
trf racer is offline   Reply With Quote
Old 01-08-2006, 12:32 PM   #12103
Ran the car for the first time today, must say that there is a lot to come from it. Qualified 8th in the B and in the final manged to get to 4th . Probably would have qualified higher but due to problems (turn left and it went right ) i qualified lower. Tried the Tamiya spool and i bust an outdrive which was a bit annoyin but tried a 1way and it went better in the final. Car definetly feels smooth to drive and not 'pointy' like the 'X-gay'
Charles
Old 01-08-2006, 12:49 PM   #12104
Originally Posted by tryhard
Tryhard
David
Use to do this on a mates rover metro to lower it (take the air out of the pressure cap) , and make it slide, the good old days of hydro pnumatic supension and weezy 1.4 series ....... Had a few scary moments in that thing.
Any way back to model cars
Smoking motor.. is offline   Reply With Quote
Old 01-08-2006, 12:54 PM   #12105
Its a large indoor asphalt track with forgiving pipes, but I was just thinking about trying the old suspension. HPI stuff is out since its hard to find around here and I'd like to stick with Tamiya Stuff. I'm grasping for straws here I feel like I've been chasing my tail around for the last 2 months with this car. I'm about to go nuts! I went from fighting for the win every week to fighting to make the A.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
