Old 12-29-2005, 11:16 PM   #11971
Originally Posted by Retard
the warmer will release within this few days but only in black if im not wrong.. http://www.much-more.jp/
the price is insane!!!
Damn....!! That price!!!
$300+ for a tire warmer?!
Neh.I'll have mine good'ol traditional 12V tire warmers....
Ben.C is offline   Reply With Quote
Old 12-30-2005, 01:26 AM   #11972
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Originally Posted by Charles Godwin
Do you know the part number for Kimbrough medium
Thanks, Charles
201 if I'm not mistaken
tamiyarcracer is offline   Reply With Quote
Old 12-30-2005, 03:35 AM   #11973
TRF415boy's Avatar
Not quite 300, maybe including postage. Still this is retail pric, not street price you'd expect it to be a little less street price. I still think Much More products are way overpriced and contribute a lot to the cost of TC racing, never seen so much useless bling than since they're here, but that's just my opinion.
TRF415boy is offline   Reply With Quote
Old 12-30-2005, 03:55 AM   #11974
TryHard's Avatar
Originally Posted by CND
Hey thanks again lads, brilliant advice on both accounts(I hadnt even considered cross pollination)
Yeah, I would consider using one from another car first, machining you own could be expensive.
I'm not sure on the measurements, but one from a Cyclone might work. Best bet would be to measure one from a friend, and see if the distance between the outdrives is wide enough. If i'm correct, I think the pulley size is the same too.
Then again, if you make your own, you could always produce a batch and sell them to other drifters to help recoup some of the cost...
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 12-30-2005, 05:17 AM   #11975
TRF415boy's Avatar
HiH
Ed
Ed, pulleys on the Cyclone are 39 teeth. It's only on the layshaft that they're the same.
Old 12-31-2005, 01:54 AM   #11976
bender's Avatar
HELP!!!!
In the process of doing some maintenance on the car I have stripped the heads on 3 of the 4 rear suspension blocks screws
Doesn't help that my 2mm driver is a piece of crap
How can I get them out? If I'd only stripped 1 on each block then I could have dis-assembled the car and rotated the blocks to loosen them, unfortunately one block has both screws stripped.
I tried to dremel a slot in the head - not enough room without damaging the chassis.
Any other ideas?
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 12-31-2005, 01:57 AM   #11977
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Originally Posted by bender
HELP!!!!
Any other ideas?
JB weld some allen keys to the stripped screws then twist them out when the JB weld hardens.
Racing4Evo is offline   Reply With Quote
Old 12-31-2005, 02:16 AM   #11978
HELP!!!!
Any other ideas?
I've had the same problem before. I used a 2mm metal drill and slowly drilled the screw's head off. You'll find that it's binding to the carbon fibre rather than the aluminium. Once the head is drilled off, it comes out very easily.
flashvc is offline   Reply With Quote
Old 12-31-2005, 02:25 AM   #11979
Send a message via MSN to Grindog001
if you have a dremel or access to one, use a cutting disk and make a slot onthe screw head. then use a flat blade screw driver and remove in the normal way. This way is very quick but be careful not to catch your chassis with the disk.
Grindog001 is offline   Reply With Quote
Old 12-31-2005, 02:34 AM   #11980
How do people put the pics in the post on the server?
Old 12-31-2005, 02:41 AM   #11981
bender's Avatar
Thanks for the answers guys.
I can't really do the drill idea, can't find the right drill bit
Might try the JB Weld, all I gotta do is find where I can buy it from in Brisbane.
Jason W
Old 12-31-2005, 04:21 AM   #11982
TRF415boy's Avatar
You can do with a 2,5 or 3mm drill too, it don't matter since you're only drilling the screw's head...
Old 12-31-2005, 09:49 AM   #11983
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Hey Jason,
You won't find JB weld here in Brisbane (it's called araldite or 2 part epoxy/resin glue). What a way to wreck the bling!!! Hope you get it out without damage!!! And here I was concerned about you crashing.......sounds like the first 'breakage" or mass piece of destruction might come from your very own hands!!! J/K
Hope you get it fixed mate.
:::Smokem Racing:::RCMaker.com.au:::Speedy RC.com.au:::
"It's more fun to drive slow cars fast, than fast cars slow"...
DirtyDog3375 is offline   Reply With Quote
Old 12-31-2005, 09:52 AM   #11984
Charles Godwin's Avatar
Or you could cut a slot into the screw head the un screw it with a flat head screw driver, but you might also put a slot in the chassis at the same time
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 12-31-2005, 09:59 AM   #11985
Customworksking's Avatar
Trader Rating: 73 (100%+)
Exclamation cut
the best way is to cut a slot in it and move it side so side if the other screw is out as you try to back it out the other way is I have a small drill that has hammer action set it to 1 and work your way up on the action 1- 10 as U do it go both ways in and out it works every time..
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
