Old 12-28-2005, 08:09 AM   #11926
TRF415boy's Avatar
Originally Posted by Carl Giordano
I would recommend a servo saver...I had a direct servo horn on a KO digital servo and chipped a servo gear...I purchased a Tamiya heavy duty servo server...its white with 3 metal rings...the white looks cheezy but at least I know I won't damage a $90 servo. The white servo saver appears beefier than the standard black one thats included in the kit.
Actually the black one is supposed to be better. Fact is they both are crap and get some play after a few hits, which tend to make the car go one side in the straight, then after you touched a pipe/clipped a kerb it'll go the other way... making trim settings useless. This is the reason why we use the Kimbrough/Trickbits ones, they're the best out there.
TRF415boy is offline   Reply With Quote
Old 12-28-2005, 08:13 AM   #11927
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
a part number?
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 12-28-2005, 08:15 AM   #11928
just ask for a kimbrough medium servo saver at any good model shop
Smoking motor.. is offline   Reply With Quote
Old 12-28-2005, 08:18 AM   #11929
your assuming we have a well stocked LHS...
I've been puchasing RC stuff on-line...I'll give speedtech a call.
Old 12-28-2005, 08:35 AM   #11930
TRF415boy's Avatar
You'll find what you want HERE
Only thing, I just realized you said you'll only use your 415 at TCS races, I'm pretty sure the use of anything else than the tamiya servo saver or standard servo horn is forbidden there, I know it is over here. Saying that, if you race outdoors, unless track marks are nasty and walls are nearby you should be able to use a servo horn without any fears for your gears. I know I did, but once I got back indoors I put the servo saver back in.
Old 12-28-2005, 08:46 AM   #11931
Thanks for the link...I'll have to double check the TCS rules..thanks again...I've read somewhere that some drivers use medium size zip-ties around the Tamiya servo savers to help hold the pieces in place...
Old 12-28-2005, 09:09 AM   #11932
Originally Posted by Ben.C
Don't use the Tamiya tread lock....Use Loctite BLUE color liquid tread lock.
Its important to use tread lock if you're screwing into metal...Like beautiful Tamiya Blue color anodised Aluminuim!!
1 day,a screw holding you toe blocks will come loose and you'll have a couple of stuff all over the track when it does...!!
I got a scratch on the chassis because a screw came off during I ran my car!
trf_racer is offline   Reply With Quote
Old 12-28-2005, 09:15 AM   #11933
No worries on the Saver, screws, pinion, spur or batteries. All allowable for TCS, Hop-ups, tires, springs all need to be Tamiya
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 12-28-2005, 09:24 AM   #11934
An O-ring also works very well - gives a little in the event of a crash - however, still is strong enough to keep the servo-saver centered ... plus it looks a little neater as well.
duckman996 is offline   Reply With Quote
Old 12-28-2005, 10:14 AM   #11935
Customworksking's Avatar
Trader Rating: 73 (100%+)
Talking scews
I think I will put RDX screws in my 415 for some reason my allen is not a perfect it in tamiya screws aftermarket or stock...But corally has a star bit and fit perfect
just something to look into
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 12-28-2005, 10:52 AM   #11936
m8commando's Avatar
Can anyone, who ownes a 415 MSX Refine kit, tell me if the wheel hubs are 4mm or 5mm, I do not like running those washers.
And what is the total overall mm of the hub including the washer. does it equal 5mm or 6mm.
JAF RACING / AIRTRONICS
m8commando is offline   Reply With Quote
Old 12-28-2005, 11:03 AM   #11937
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
5mm hub, with a 0.5mm spacer (washer)
tamiyarcracer is offline   Reply With Quote
Old 12-28-2005, 11:42 AM   #11938
m8commando's Avatar
Thank you very much!
Old 12-28-2005, 12:53 PM   #11939
has anyone tried a cyclone pully?i heard it is larger then the standard 415 pully.
is this true?anyone used or tried it?
thanks
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
trf racer is offline   Reply With Quote
Old 12-28-2005, 02:23 PM   #11940
TRF415boy's Avatar
thanks
They're the same. Andy Moore used to borrow David Spashett's at nationals since his car was a prototype and parts weren't readily available.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
