Old 12-20-2005, 08:30 PM   #11821
Originally Posted by Pyramid
http://www.daltonshop.com/tips_tricks.htm
The first 5 pics.. all you need to do is to find local workshop with CNC machine.
OMG....Thats cool !!
Ben.C is offline   Reply With Quote
Old 12-20-2005, 10:28 PM   #11822
P-DUB's Avatar
Originally Posted by Jack2
Yeah.... good point.
finding pictures of Rheinard's stuff is like finding hens teeth sometimes.... I hate it.
Here are some pics of Marc's cars that he actually raced at the IIC Vegas race
Rubber Car
Foam Car
12th Scale
Larry Pryor
P-DUB is offline   Reply With Quote
Old 12-20-2005, 11:51 PM   #11823
Eirik's Avatar
Here's the car that Marc used at the Carpet World Cup.
Looks just like my car, a std 415 with the MSX Conversion kit
Eirik is offline   Reply With Quote
Old 12-21-2005, 07:06 AM   #11824
Jack2's Avatar
Thanks guys !...
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 12-21-2005, 07:38 PM   #11825
maxepower's Avatar
Talking RE: Vegas race!
Rheinards runs 1/12 pan cars? I didn't know that! Nice paint schemes.
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 12-21-2005, 07:43 PM   #11826
Burlap's Avatar
Send a message via MSN to Burlap
Took my 415MSX out for its first run. Seems nice, a tiny bit of understeer, but good all round. Unfortunately broke a front upright on one of the corners (damn bits of wood) so that killed the testing session.
Also looking at doing some fiddling with my car suspension. I know with moving the shock position on the shock tower, it can lessen or increase the amount of pressure the shock absorber is putting on the wheel, giving I guess fine control that changing a spring on that wheel would not do. But what does moving the bottom shock mount on the lower arm do? Is it a similar thing or a different kettle o' fish all together?
Burlap is offline   Reply With Quote
Old 12-22-2005, 06:02 AM   #11827
Charles Godwin's Avatar
Moving the bottom shock mount out will increase the grip at that end of the car and moving it in will decrease grip at that end
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 12-22-2005, 06:32 AM   #11828
bender's Avatar
Charles
Are you sure? That sounds backwards to me. Wouldn't mounting the shocks further out on the arm make the car stiffer - therefore less grip??
I would like to know generally what hole in the arms everyone uses for rubbers on ashpalt - I've been given a couple of setups to try but I don't want to reverse the arms yet (go to the 2-hole side) unless that is the way most people run them.
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 12-22-2005, 06:39 AM   #11829
I have always thought that a more led down shock will give more grip and a more upright shock will give less grip. I have always been told this and for me it works . But I think in a situation like this you should try things on your own to see how it works for you .
Charles
Old 12-22-2005, 09:15 AM   #11830
rtypec's Avatar
From my understanding, a more layed down shock will provide an initially softer feel that proportionally gets stiffer as the suspension compresses. It makes a car want to "carve" once a turn is initiated. Small corrections to steering once the car's weight begins to transfer is a bit more vague. Shocks that are stood up feel very direct and have a more linear feel when the suspension compresses. Moving the lower shock positions changes the suspsension and shock rates. Typically, moving them further out will provide a more direct rate to that of the wheel. That's my "non-precision" explanation
rtypec is offline   Reply With Quote
Old 12-22-2005, 09:58 AM   #11831
robertr's Avatar
Does anyone have a setup for smooth asphalt,outdoor rubber tire.
robertr is offline   Reply With Quote
Old 12-22-2005, 10:21 AM   #11832
TryHard's Avatar
The other thing to take into consideration is the leverage affect that the suspension arm puts on the shock.
Good guide on it http://home.tiscali.be/be067749/58/
Effectively, placing the shock further out on the arm has the effect of softening the suspension.
Bender;
I've been running my MSX in either hole 2 or 3 on the arm. Indoors on carpet I found 3 best, but outdoors on asphalt 2 works better. The lower CoG of the MSX allows you to run it softer, whilst still rolling the same amount.
Robertr;
Have a look at the link in my sig, there are a number of setups on there (yes I know I have still to add the rest.. I will do it soon, honest!)
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 12-22-2005, 12:27 PM   #11833
Just wondering what pistons and oil come in the kit and when i start to build it should i leave the bearings as standard or flush and oil
Thanks, Charles
Old 12-23-2005, 01:23 AM   #11834
Burlap's Avatar
Thanks, Charles
The kit comes with 3 oil pistons and I think #400 oil. I put in two hole pistons and Schumacher 40wt oil.
Old 12-23-2005, 04:01 AM   #11835
bender's Avatar
According to that link you posted you've got it backwards
"The formula tell us that the closer the bottoms of the shocks are mounted to the middle of the chassis, the softer the wheel rate will be."
Jason W
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
