Tamiya TRF415
Old 12-19-2005, 03:49 PM
  #11791
Originally Posted by GroffBall
You will need two sets of steel diff outdrives from a Tamiya TA04. I'm sure a lot of other people will have these in there pit boxes after replacing them with lightweight outdrives. You will only actually use the long side of the outdrive.
1. Cut off the end that goes to the diff right at the ridge that holds the bearing, see pic.
2. Grind it flat with the ridge
3. insert pins into the slot for the dogbone
4. put bearings on to hold in the pin
5. install as normal
I ran out of drive cups and didn't really want to buy a new spool so I dug around my box and tried every outdrive I could find and the inner diameter of these, the length, everything is a perfect fit. There will be a slight bit of play with the pin and the dog bone slot but it isn't a big deal. I havn't had a chance to try this yet but I don't see any reason why they won't hold up, but before anybody goes out and buys outdrives to do this I'll be trying it out and I'll report back.
Good guide, i will mostly be doing that on a lathe tomorrow. Thanks
Rick Draper is offline
Old 12-19-2005, 04:15 PM
  #11792
JimmyMac's Avatar
Originally Posted by Sparx
Can any japanese-talking person tell what springs are used on the Rheinard setup?
Not sure if it was answered yet, but they were Blue/Front and Yellow/Rear.
JimmyMac is offline
Old 12-19-2005, 04:31 PM
  #11793
F. Alonso's Avatar
Yeh, certainly not a "typical" Rheinard setup as everything is "Tamiyafied." But, if he raced at the Japanese Tamiya event or something like that, then its believable I suppose.
F. Alonso is offline
Old 12-19-2005, 04:53 PM
  #11794
Jack2's Avatar
Arrhh, Thank you Sir.
Yes, I agree Simon, It doesn't look like a typical Rheinard setup. I think he was probably given a base setup by Satoshi or someone and he has just run that or only made fine adjustments.
Jack2 is offline
Old 12-19-2005, 05:48 PM
  #11795
I heard that he ususally get his base setup from Kiyo Suzuki and other teammates. Marc usually have a mechanic that does the setup for him.
trf_racer is offline
Old 12-19-2005, 07:43 PM
  #11796
Originally Posted by TryHard
just makes it easier to get at the grub screw to take the spur mount off, means you can use a 1.5mm driver instead of an allen key... I've yet to find a driver that fits down that hole!
Groffball; Yes please!!!
Actually I have a driver that goes down that hole...But I got this driver years back when I started RC-ing...Think its gone the way of the DoDo bird.
Ben.C is offline
Old 12-19-2005, 08:41 PM
  #11797
Customworksking's Avatar
Trader Rating: 74 (100%+)
Arrow yurp
After looking at it I also agree
I never seen any of the top setups run the FT shocks that way and such less droop for rubber.........
Customworksking is offline
Old 12-19-2005, 11:35 PM
  #11798
brandbrainz's Avatar
The setup isn't typical Rheinard as the track conditions weren't very typical. The setup sheet is exactly what they have raced at the jap. nationals.(I've asked Marc last week) But before trying that at your lokal track keep in mind: The track temperature was 10 C and they used Sorex 32R. They heated the tyres until 30 sec. before the start. Runtime was 8 min with 11turns. I don't think it will work well in other conditions. The springs were blue/front and yellow/rear.
brandbrainz is offline
Old 12-19-2005, 11:37 PM
  #11799
SMcpot's Avatar
Trader Rating: 22 (100%+)
It was done on Marc R's car at the worlds in 04. Lowers weight, and allows more room to play with bump steer tuning... hopefully this pick shows it
http://www.thard.co.uk/images/415g.jpg
Charles;
Yup you'd hope people would twig that...
I've just remembered another one... rear diff covers..
Thanks Ed
SMcpot is offline
Old 12-19-2005, 11:47 PM
  #11800
Trader Rating: 30 (100%+)
My Hudy fits. Should try this 1.5. They are pretty strong too.
JoeyE is offline
Old 12-20-2005, 06:04 AM
  #11801
Marcs car from the GP masters?
Old 12-20-2005, 06:08 AM
  #11802
maxoo's Avatar
Normaly he use orion advantage charger... So i think that it's not the MR car... and it's not a KO sender
maxoo is offline
Old 12-20-2005, 06:11 AM
  #11803
Just noticed its the wrong transmitter behind it as well.
Old 12-20-2005, 07:02 AM
  #11804
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
Brandbrainz: nice art work, too bad I'm no longer living in Bayern.
I'm sure he is very busy, but perhaps you can convince Mark to come on RCTech and help us Tamiya fans from time to time. Is there a site in which he makes himself available to answer questions. I'll just have to brush up on my Bavarian...
Danke!
Carl Giordano is offline
Old 12-20-2005, 07:08 AM
  #11805
Holmenkollen's Avatar
http://www.rcinfos.com/
Holmenkollen is offline
