Old 12-18-2005, 06:28 PM   #11761
Default Manual for MSX Complete Car Kit
Who has the Full 415MS Refine 2 (MSX) Manual scanned to pdf by now?
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 12-18-2005, 07:18 PM   #11762
squeege's Avatar
My 415 is loose in the rear no matter what I do. I run stock rubber and I have to run take off 27's ,and I am wondering about the tires. The tires on the car are 3 weeks old with 18 / 5 minute runs . Are they wore out already? Also I am running 2 degrees of caster on the front wheels , how would the cars handling change if I ran 4 degrees ?
squeege is offline   Reply With Quote
Old 12-18-2005, 07:27 PM   #11763
Jack2's Avatar
18 runs is quite a few runs on a set of tires. TO 27's wear pretty well tho. It might be worth getting yourself a few extra sets. I never go to a track without a good tire supply. If you have the TO 27 as a control tire, just get some more of those and try.
Give some more details ie. loose - on power, off power ?
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 12-18-2005, 07:42 PM   #11764
squeege's Avatar
loose off power in the rear
Old 12-18-2005, 07:56 PM   #11765
Originally Posted by Burlap
I've just scanned the official blank setup sheet for the 415 MSX. It can be found under this link. Beware, it is 890k in size:
http://www.maths.monash.edu.au/~dmcq...5msx_setup.jpg
Tryhard, you can use this on your 415 site as well.
Why scan one when there's one available to download from Tamiya? It's nice and good looking!
Blank Setup Sheet:
http://tamiya.com/japan/products/493...5msx_blank.pdf
Marc Rheinard's Setting:
http://tamiya.com/japan/products/493...xmarcc_int.pdf
Satoshi Mazumi's Setting:
http://tamiya.com/japan/products/493...toshi_1211.pdf
trf_racer is offline   Reply With Quote
Old 12-18-2005, 07:57 PM   #11766
Jack2's Avatar
Well if its loose off power the first thing that comes to mind is rear droop. Try reducing your rear droop 1mm at a time and see how that works.
Also, you mentioned what will increasing the caster do, in a loose off power situation, it should help. Definatly try the 4 degree blocks.
I think it would be worth while trying some of the X series blocks if you already haven't.
add some Anti dive, try a 0.5 or 1mm spacer under the front suspension block at the front of the car and see if that helps.
Get rid of any front toe-out if you have some dialed in.
if your running a lower ride hight in the front, Even it out so its the same front and rear. Then drop the rear by 0.5mm and see how that works for you.
maybe try increasing the rear Toe in.
If that doesn't work, try some harder springs up front.
there is a few other things you can do but try those first, there the things I look at first if my car is loose off power.
Schumacher Mi4CX
Mugen MTX & MRX
Old 12-18-2005, 08:11 PM   #11767
Jack2's Avatar
Blank Setup Sheet:
Satoshi's setup is for the TA05 ?
Also, I'd be interested to know what springs Marc used on that setup. I guess they would be either yellow's, blues or whites. I'll give it a try anyhow....
Schumacher Mi4CX
Mugen MTX & MRX
Old 12-18-2005, 08:12 PM   #11768
Burlap's Avatar
Send a message via MSN to Burlap
Blank Setup Sheet:
Ah, the Japanese site has them. The US hadn't and I thought I was on a winner
Burlap is offline   Reply With Quote
Old 12-18-2005, 08:20 PM   #11769
I am not sure if it's a TA05 setup or the 415 because I found it under the 415 section of Tamiya site.
Old 12-18-2005, 09:40 PM   #11770
Customworksking's Avatar
Trader Rating: 73 (100%+)
Lightbulb loosse
I race with this guy (Dan) and he has had a hard time the 1st thing to go I feel is the tires CS27's as I race every week on a new set the 1st thing to change is rear bite and I have found as I work the chassis the lap times fall off due to mainly toe hints freer =faster but @33.00 a set what is better I also went to big races and used club tires cs27 spent 1/2 the time setting the car up due to say 5 or 6 runs on them and when I put on the new ones to start the heats I spend the rest or the races freeing it up at a culd level race the traction is allways less than bigger race say 75 people or so...At the same time the tires U run at a big race will not work as good at a club race so,how long to run your tires=how much work u want to do and cash u have ...I know I will have 5 sets for the novak race
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 12-19-2005, 01:37 AM   #11771
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
Also, pull apart your rear diff. I had major problems before with my car before I pulled apart the rear diff. My thrust bearing was stuffed, so that may be your problem. If thats fine, then use Jack's ideas to see if you can resolve it.
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 12-19-2005, 08:50 AM   #11772
TryHard's Avatar
Blank Setup Sheet:
Interesting to see Marcs been running 0.5mm under his suspension blocks and camber links too...
Also interesting on the front suspension, running the shock out on the furthest hole on the arm..
Later
Ed
| THard.co.uk | Xray | MuchMore |
Old 12-19-2005, 09:50 AM   #11773
Talking try h
Later
Ed
Tryhard r u going to add Marcs setup to your web site?
Old 12-19-2005, 09:55 AM   #11774
F. Alonso's Avatar
The setup doesn't look.... authentic. From what I've seen of his car from the whole pile of photos, etc, the setup doesn't seem to resemble what is seen there, that's all. I am curious to give it a go though.
Simon Feigl
Old 12-19-2005, 10:16 AM   #11775
Marc was at the Japaneese nationals wasnt he? I bet that setup is from there.
Rick Draper is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
