Old 12-05-2005, 08:05 AM   #11641
Originally Posted by Smoking motor..
I have ordered a 415 refine 2 kit i could do with some build tips for this car.
Do I need to round the chassis edges and glue them and file the battery slots?
Is it advisable to drill the shock pistons out to 1.2 mm to reduce pack.
Do I need to get ceramic balls for the rear diff i have been told the old one wears fast.
Is the kit setup a good starting point for rubber tyres at D V?
Any tip would be helpful for me to know Plus i really don't want to trawl through 219 pages to find out this info !! I hate the search engine:P
Yes smooth all the edges of the carbon parts and then seal them with CA. Also make sure you chamfer the battery slots to stop the sharp edges cutting the cells heatshrink.
Leave the shock pistons as they are, there is no drilling needed.
Diff balls i changed for ceramics and i think i would always do this.
Rick Draper is offline   Reply With Quote
Old 12-05-2005, 09:01 AM   #11642
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
A tip when filing, file down the outer servo mounting hole AND screw (don't file it so much that you can't unscrew it) to prevent it from scraping and collecting rubber. By filing this much you can lower the car about 0,5 mm without scraping the "ear"
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Savx - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 12-05-2005, 10:52 AM   #11643
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
Anybody have a 3mm chassis from the standard 415 that they would like to part with?
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 12-05-2005, 01:03 PM   #11644
Default Where can i get ceramic diff balls cheap?
The ceramic diff balls what size are they 2.4mm ?
Is axiom the best place?
The thrust washer/balls would you replace it with one of a higher specification?
Also where can i get a Kimbourgh servo saver for the KO spline in the uk ? I have one on my 1/12th car but that was given to me.
I have ordered spare wishbones but not sure about the blocks, I usally run 2 degrees of rear toe and I am happy with that.
Smoking motor.. is offline   Reply With Quote
Old 12-05-2005, 02:58 PM   #11645
Jack2's Avatar
The diff balls are 3mm.
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 12-05-2005, 03:07 PM   #11646
Jack2's Avatar
Acer's line of diff balls
I am using Acer's Ceramic Nitride Pro Series Differential Balls and they make for an ultra smooth diff. I also used the Yokomo diff plates, they last a bit better and stay smoother than the Tamiya ones.
Schumacher Mi4CX
Mugen MTX & MRX
Old 12-05-2005, 03:56 PM   #11647
Burlap's Avatar
Send a message via MSN to Burlap
What's the model number for the Yokomo diff plates?
Burlap is offline   Reply With Quote
Old 12-05-2005, 04:20 PM   #11648
Jack2's Avatar
Part #: ZS-506
I got them from Champ
Schumacher Mi4CX
Mugen MTX & MRX
Old 12-05-2005, 04:26 PM   #11649
Burlap's Avatar
Part #: ZS-506
I got hem from Champ
Ta, I'm doing an order to RC Champ for the 415 MSX I have on preorder, and already have the Acer diff balls, but want to make sure it is low maintainence as possible.
Old 12-06-2005, 03:09 AM   #11650
Spud_J's Avatar
Hi Guys,
Could someone tell me are the titanium coated shock shafts for the TRF shocks 3mm or 1/8" diameter?
Cheers
Spud_J is offline   Reply With Quote
Old 12-06-2005, 06:33 AM   #11651
V12
V12's Avatar
I think all of the TRF shock shafts are 3mm.
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 12-06-2005, 11:35 AM   #11652
Martin Crisp's Avatar
I recently started using the APS cermamic diff balls for the cleveland race. I have to say they are very smooth and last much much longer than normal diff balls. I just replace the diff plates and re-use the diff balls and the diff is as smooth as the first time. I have replaced the diff rings 4 times already and I am still using the same APS cermaic diff balls. You might want to check them out at www.magmarc.com.
Martin Crisp
Power-Story.com | LearnSetup.com
Martin Crisp is offline   Reply With Quote
Old 12-06-2005, 12:12 PM   #11653
Matrin, do you have a setup for foam/carpet using the LIGHTWEIGHT suspension?
Old 12-06-2005, 02:16 PM   #11654
I use the same setup for the lw as I do the original one.
Front:
droop - 1mm
springs - 33lbs
oil -80 orion
shock Pos. - 3 holes in on shock tower. inner of 3 holes arm
inside upper links - 5mm spacer (take away spacers if you want more steering)
ackerman - rear holes on HPI knuckles, swept back bell crank
blocks - A and A no spacers
caster - 4 degrees
sway bars - Blue ( I am also going to try no swaybar and yellow swaybar)
toe out - none
wheel hub spacers - 0mm
belt - position 1
lw suspension - camber 1.5
wheel base - 3mm forward (using original 415 (not ms) chassis)
ride height - 5 mm
Rear:
droop - 1mm
springs - 28 to 30lb spring
oil - 80 orion
shock pos - two holes in on shock tower, inner of three holes on arm
inside upper links - no spacers
outside upper link - 0.7
upper link length - middle hole on upright
blocks - d and b, no spacers
upright - 1 degree allum (total 2.0 toe in)
belt - position 2
ride height - 5 mm
lw suspension - camber 1.5 inside tire (right) 2.0 on outside tire (left)
Martin Crisp
Old 12-06-2005, 03:48 PM   #11655
Front:
droop - 1mm
springs - 33lbs
oil -80 orion
caster - 4 degrees
toe out - none
belt - position 1
ride height - 5 mm
Rear:
droop - 1mm
oil - 80 orion
belt - position 2
ride height - 5 mm
what tires are you running ?
John Q is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
