Old 12-02-2005, 01:21 PM   #11611
alan1467's Avatar
Default 415 Spools
Ok I've run a Speedtech spool in my 415 for over a year with no problem but it now needs replacing. What's the best one avalible now regards wear, strength and use?
Alan
Tamiya TRF - Tekin
F104W Pro - CRC Gen X10
alan1467 is offline   Reply With Quote
Old 12-02-2005, 02:48 PM   #11612
V12
V12's Avatar
Originally Posted by Dongskie
Oh I'm susrprised you noticed that... yes they are Ceramic bearings..
And what ceramics are these in your 415?
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 12-02-2005, 03:02 PM   #11613
TCR
Default msx in stock for christmas
Ultimate hobbies has the MSX kit in stock.
419.95 free shipping
If anyone is looking
TCR is offline   Reply With Quote
Old 12-02-2005, 05:25 PM   #11614
Ballsie's Avatar
Alan
I've used three this season Alan, the Pro Comp from Titanium Racing, the Tamiya One and the one from Shooters Racing.
Scott Meichan swears by the TiR one so I'd have to trust him on it - I've found all to be quite good to be honest, although the Tamiya is a little weak.
Ballsie is offline   Reply With Quote
Old 12-02-2005, 08:53 PM   #11615
Customworksking's Avatar
Trader Rating: 73 (100%+)
Talking spool
how do like the spool vers the 1way ..r u faster ?
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 12-03-2005, 12:17 AM   #11616
maxepower's Avatar
Talking RE: SET-UP
Originally Posted by EDWARD2003
Hey guys i have a standard 415. This i the problem with my car. When i exit a corner and put the throttle down the car is really loose. Its almost like its on ice. But when i enter a corner the car hugs a nice tight line, it doesnt get loise. What should i do.
This is my setup so far
F/R Shock Oil) 40 wt
F/R Springs) Blue/Yellow
F/R Shock Tower Mount Holes) Outter Most Hole/ In one hole
F/R Sway Bars) Yellow/Yellow
F/R Roll Center) 2 mm / 2 mm
F/R Camber) -1.5 deg
F/R Toe In) 0/2.5 deg
Front Caster 4 deg
F/R Droop) 3.1mm/3.8mm
Ride Height 5.5 mm
Thanks for you help.
Edward Pickering.
You didn't say what blocks your running. I'm assuming your using the blocks that the kit says to use. Consider using narrower blocks. I remember when I got my original 415 and my car handled the say way yours did and the narrower blocks front and rear made the biggest difference in the on power handling coming out of a turn! TRY IT YOU'LL LIKE IT!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 12-03-2005, 11:12 AM   #11617
EDWARD2003's Avatar
Default 415 suspension help
"7yrs OK r u on the same lap as the fast guys or the same lap times ? what kind of carpet" I win and TQ with this set-up and i have really fastlap times but its soooo hard to control around the track.I work a sweat to keep the throttle control right and steering input smooth.
I can handel any car but i pefer a car with its ass end planted so i can hammer on the throttle coming out of the corner.
The type of carpet is Ozite, but its not the CRC type. Its some cheap type the produces alot of fuzzzzzzz.
Your right about the extra droop it will give more weight transfer from one end to the other. See i am slowly understanding everything, you would think 7 years of experience i would have this game of setup downpacked. lol
"narrower blocks front and rear made the biggest difference"
Are you talking about the Aluminum Suspension Blocks?
What do they look like.
Edward Pickering.
EDWARD2003 is offline   Reply With Quote
Old 12-03-2005, 11:44 AM   #11618
Charles Godwin's Avatar
Originally Posted by Charles Godwin
Hi guys, i've finally got round to ordering a Tamiya MSX for Xmas . I was wondering what is the biggest (or something near the biggest) 48dp spur gear that can fit and what make of spurs fit (i can get RW and Kimborough easily) also how does the DJ pro suspension affect the handling of the car .
Anyone
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 12-03-2005, 11:49 AM   #11619
Arrow blocks
the bridge blocks A,B,C,D,X,XA,XB ect try A A and go out with the ft block IE:A-B ,A-C ,A-D for inboar toe always check your camber droop and outboard toe after every change be sure not to run any toe with your wheels,center them as u work out with the block IE: A A blocks will have zero A B will have .5 ect fin a post from TRYHARD go to his web site get a few setups,spring chart and toe block chart it's a MUST! print them U wull see a lot of good setup's and see where u need to make changes trust me
Old 12-03-2005, 11:50 AM   #11620
Arrow 48p
Anyone
Charles
64pitch is a must
Old 12-03-2005, 11:53 AM   #11621
Is there any chance of running 48pitch as i don't have any 64pitch gears?
Charles
Old 12-03-2005, 11:59 AM   #11622
Arrow sure
u need to be the range of 3.77 3.92 thats 102/27 102/26 your track size will chage the ratio as well all I can say is see what u have in 48 pitch to get close the this ratio keep your motor around 130 to 140 deg....
Old 12-03-2005, 12:05 PM   #11623
I know about the ratios etc but i am wondering what is the biggest 48pitch spur gear i can fit without it hanging below the chassis
Charles
Old 12-03-2005, 01:26 PM   #11624
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
Has anyone been able to have a super stiff 3 or 3.5mm chassis made for carpet? Surely there is enough interest to get some made up. i think as light as this car is, it could be a beast on the carpet. I know Kai used to make a chassis, but it was a fortune. Cough cough BMI cough
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 12-03-2005, 02:22 PM   #11625
Also, I am planning on running my 415 on carpet and I am going to run the standard suspension..what universal length do I need, and can I use some of the Tobee craft bones on the Tamiya axles?
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
