Tamiya TRF415
Originally Posted by TRF415boy
Rick, would you take that new hole's position on the chassis for me mate ? Have a look at last page for the dimension i'm looking for. That'd be great !
Thx
fab
Thx
fab
Originally Posted by dodo
haven't check the shocks, but i think it's smooth cap, same as the other MS
Originally Posted by Rick Draper
I will measure it later on fab.
List of some of the new/option parts with the 415 MSX:
Gold hinge pins,
Steel outer hinge pins,
Fluorine king pins,
Gold shock shafts,
Knurled shock tops and bottoms,
Alloy rear hubs,
Crush spacers for between bearings,
Roll bar stops,
Gold shielded wheel bearings (new item possibly?),
New chassis with hole under motor and screw hole for centre brace,
5mm wheel hex's.
That is it off the top of my head.
Gold hinge pins,
Fluorine king pins,
Gold shock shafts,
Alloy rear hubs,
Roll bar stops,
5mm wheel hex's.
Corally blades fit the new back diff.
Fab i have the following measurements but i will not be held accountable if they are not bang on!
Hold the chassis with the motor area towards you, from the furthest forward hole on the motor mount measure towards the batterys 16mm then straight forward from that point 28.5mm. This is where i believe the center of the hole to be.
Buyer Beware
pics...
pics...
Originally Posted by HELLOkitty
pics
Do you mean there are only 2 screws to secure the motor mount on that version and so this corresponds to the middle screws on the old style bulkheads ?
Buyer Beware
Of what bit?
I am measuring from the center of the screw hole nearest the pinion hole in the chassis.
Gold hinge pins,
Fluorine king pins,
Gold shock shafts,
Alloy rear hubs,
Roll bar stops,
5mm wheel hex's.
Gold hinge pins,
Fluorine king pins,
Gold shock shafts,
Alloy rear hubs,
Roll bar stops,
5mm wheel hex's.
So the dimension I'm looking for is 28.5 - 16 from the furthest motor mount hole to the centre post hole, right ? Just making sure i get it right. Does that looks right to you ?
From the hole furthest forward on the motor mount measure towards the cells 16mm then towards the front of the chassis 28.5mm. The diagonal measurement between the original motor mount hole and the new hole you are going to drill is 24.5mm.
http://img.photobucket.com/albums/v4...aper/415-2.jpg
That is more like where it is positioned. Further forward than in the pic you did.
