Old 11-27-2005, 09:54 PM   #11521
BritRacer's Avatar
they only ship ups ground....I will call them tomorrow and see if they will ship usps priority, but their prices are almost 50% more expensive!!
BritRacer is offline   Reply With Quote
Old 11-27-2005, 10:45 PM   #11522
dodo's Avatar
Send a message via Yahoo to dodo
Originally Posted by erric_13
hi guys,
i have a TA05, mod it a little and thinking of changing to the msx refine2...what do ya guys think?
1) fully mod the 05 with cf chassis and such
2) just get the refine 2
on a tight budget..
if you're on a tight budget, i suggest that you stick to TA05 for the time being. Unless you really feel that the car can't compete with the other racers.
dodo is offline   Reply With Quote
Old 11-27-2005, 11:34 PM   #11523
SMcpot's Avatar
Trader Rating: 22 (100%+)
UPS Ground should take about 2 days to Texas from California
SMcpot is offline   Reply With Quote
Old 11-27-2005, 11:47 PM   #11524
huskerfreak's Avatar
need help! can anyone help, i need low friction belts for the 415 for next weekend. I have ordered from ebay, but they wanted silly money for EMS shipping for 4 belts (almost the same cost again!!)
does anyone have 2 new spare (R&F) they will sell me and send priority mail asap??
If you have a local HobbyTown they should be able to order them from Horizon Hobby as they have them in stock. I know that since HT and horizon work together and if your local HT has a big enough order you get them by Wednesday. That is if they order before noon Monday. None of the less you get them through Horizon on the web Hobbytown or LHS if they are set up with Horizon and have you should havethem before Friday.
huskerfreak is offline   Reply With Quote
Old 11-28-2005, 07:11 AM   #11525
hi. is it normal for the front wheels to "chatter" when at full lock going around a corner? any tricks/tips to resolve this?
Doomah is offline   Reply With Quote
Old 11-28-2005, 07:15 AM   #11526
Send a message via AIM to GroffBall
Are you running a spool and are you running foams or rubber tires?
GroffBall is offline   Reply With Quote
Old 11-28-2005, 07:19 AM   #11527
hi. i run rubber tires, and one-way.... does it matter? i am going to put a spool in for my next race though....
all the nuts are tight, but there seems to be alot of slop between the hubcarrier and the steering knuckle. i.e when the servo is on, you can wobble the wheel about 2mm's either side.
parts are still relatively new. only a few runs on them.
EDIT: THIS IS FOR A MS
Old 11-28-2005, 07:24 AM   #11528
Buyer Beware
who has pic of the new MSX kit....i pre-ordered one...kitty
HELLOkitty is offline   Reply With Quote
Old 11-28-2005, 08:14 AM   #11529
It matters because chatter is normal for a car running a spool, and possibly a one way I'm not sure as I've never ran a one way. is this only at full lock on the steering if so turn the EPA down a bit and try to make the car steer better so you don't have to steer as far if you know what I mean. When you put the spool in you will see what I mean about chatter
Old 11-28-2005, 08:52 AM   #11530
dodo's Avatar
there you go, 90% completed
Old 11-28-2005, 10:17 AM   #11531
Trader Rating: 27 (100%+)
Would be nice to if the kit also came with blue screws
JoeyE is offline   Reply With Quote
Old 11-28-2005, 10:25 AM   #11532
Buyer Beware
awesome...thanks !
Old 11-28-2005, 11:42 AM   #11533
TRF415boy's Avatar
To anyone who has his MSX kit, I'm looking after a dimension. I need to know where to locate the hole for the bulkhead stiffener that comes with the MSX kit, on the chassis side. I'm attaching a picture to make it clearer, the dimension I'm looking to get is the distance between this hole and the closest bulkhead hole, along the car's axis.
On the picture it's the dimension that is 10mm (it obviously is not 10mm, this was only made as an example). I need to know what to put instead of 10. Obviously I could do it once my car arrives, but i'd rather do it before that so i can mount my chassis directly on the car
TRF415boy is offline   Reply With Quote
Old 11-28-2005, 04:00 PM   #11534
Burlap's Avatar
Send a message via MSN to Burlap
Sweet, can't wait for mine
Do the shocks have the normal smooth caps, or do they have the ribbed caps like the Hop up you can get?
Burlap is offline   Reply With Quote
Old 11-28-2005, 04:30 PM   #11535
i see what u mean..... i put in a spool and it chatters bad now....
p.s my front spool doesnt seem to rotate straight... seems to wobble abit, not sure if its just the plastic edges on the pully just bent a bit... anyone else have this problem?
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
