Old 11-23-2005, 05:13 PM   #11461
Buyer Beware
Originally Posted by Ballsie
There's an "A" block too, I've just found it!
pics....please......kitty
HELLOkitty is offline   Reply With Quote
Old 11-23-2005, 05:14 PM   #11462
Ballsie's Avatar
Originally Posted by SMcpot
Hmmm....according to Tamiya, adjustment without disassembly should be possible. The halves look a lot like the plastic ones from your pics, so I thought the difference would lie with the screw, and maybe a hole in the outdrive for an allen wrench to pass through.....
You might be able to fit an "L" shaped Allen key in the end of the outdrive and into the screw head with removing the diff - I'd have to build it and try it but its 00.15 here and I need some sleep !
Anyone else got one of these yet?
Better pics tomorrow when I get the camera - I promise !
Ballsie is offline   Reply With Quote
Old 11-23-2005, 05:22 PM   #11463
V12
V12's Avatar
Can you tell if the diff screw can be used with the plastic outdrives? Would like to retain the plastic, while being able to adjust the diff externally....
I just saw at the stock 415 manual the diffscrew is 30mm long.
If that screw on the new diff really is just 25mm then there must be a difference in the diff halves. So this won´t work on the plastic diff.
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 11-23-2005, 05:27 PM   #11464
Anyone know of the part number of the new diff bolt coming out for the aluminum diff joint set?
This bolt will have a bigger head with a hole cross drilled to allow the allen key to pass through to be externally adjustable without taking the diff out or removing the camber link to access the diff bolt from the side in the car like we do now.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 11-23-2005, 05:32 PM   #11465
SMcpot's Avatar
Trader Rating: 22 (100%+)
Oh well.....it was a lovely thought
SMcpot is offline   Reply With Quote
Old 11-23-2005, 05:36 PM   #11466
Oops just seen that it is 25mm long? Why would they go that smaller? They must have bored out the centers deeper into each diff half. The 30mm's are barely long enough.
I want to use this with my existing design aluminum front diff that uses all Tamiya parts and the plastic rear ones.
I was going to make a production run of matched externally adjustable diffs front and rear and just anodize them black.
I guess I'll just have to get diff bolts made too. Why do I always have to re-engineer everything I own?
Old 11-23-2005, 06:12 PM   #11467
V12
V12's Avatar
Is your aluminum front diff your own construction or is it a Jürgen diff?
If it´s a Jürgen diff you can´t use such a special diff screw as there isn´t just enough room for the larger head of the screw.
But I think this would be the same with all sorts of 415 front diffs as the pulley is centered and the halves are just too short for this.
Old 11-23-2005, 06:52 PM   #11468
I originally bought Jürgen's diff last year. I wrecked it as the one swing shaft kept popping out and mangled the look of it. I felt it was too short and the diff screw was not centered in the diff when assembled as it was off to one side too much.
I drew up AutoCad drawings and made the outdrives a bit longer so the swing shaft reaches a bit further into it without going to 46mm swing shafts or anything and not popping out. Also the diff bolt is properly spaced left to right when assembled. I also scrapped the blades idea. I was actually pushing out the original swing shaft pin and drilling the hole out to the size of associated pins and installing IRS pin cushions and the diff is in perfect shape after many runs.
I believe as long as the diameter of the diff bolt head of the new Tamiya or a design I can come up with is smaller than the diameter of the thrust bearing then it will work no problem. You will have access to the hole in the bolt head from a peek hole or the slots from the swing shaft pins coming in from each end.
My next design will probably go back to blades as they are going to be more common with Xray and Tamiya packaging them. The Xray ones I think give you 6 in a package and it's like $6 canadian here. Not Bad.
Old 11-23-2005, 07:19 PM   #11469
V12
V12's Avatar
Hmm seems the Xray blades are way cheapier in Canada than here.
But they don´t work very good with Tamiya driveshafts. Just too much play.
The Corally ones are a perfect fit and I´m using them on my Jürgen rear diff.
Old 11-23-2005, 07:22 PM   #11470
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
Are there any estimations on the price of the Alloy Diff seperately?
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 11-23-2005, 07:24 PM   #11471
V12
V12's Avatar
I asked this the guys at R10 not very long ago and they didn´t know.
Old 11-23-2005, 07:27 PM   #11472
veecee's Avatar
Trader Rating: 34 (100%+)
Default 48 pitch gears
Anybody use 48 pitch gears on the 415? If so what range of spur/pinion sizes work? Thx.
veecee is offline   Reply With Quote
Old 11-23-2005, 07:51 PM   #11473
V12
V12's Avatar
Stock or Modified?
I´m using a 72 DP Xenon gear for stock. Pinion 21 - 32 teeth at least.
Old 11-23-2005, 08:45 PM   #11474
F. Alonso's Avatar
I used a 78tooth for a while when I was using 48dp, but now I use 64dp. 78t in 48 is pretty similiar to the kit supplied 64dp 102t spur, in physical size. I don't think you could go much bigger then that as its pretty close to the ground as is.
Simon Feigl
Old 11-23-2005, 10:15 PM   #11475
I normally stay around 75-78t for the spur, and pinions will depend on tire diameter, but usually in the 20-25 tooth pinion range running mod.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
