Old 11-20-2005, 10:02 PM   #11386
Jack2's Avatar
Originally Posted by F. Alonso
Hmmmmm, I disagree. If that were truly the case, then why isn't the Cyclone and BD like the TA05!?!
Yep I agree the TA05 is never going to be better than a 415. It was never planned to be better. I know the TA05's are good, I have been using one lately at a local track that runs foams(on asphalt). I have been running it in Mod with a 8x1 and I have to say it has been brilliant ! Its a very fast car, and I have only put a few hop-ups on it. The bonus with the TA05 is you don't have to play around with putting Pro4 hubs on it like you do with the 415 to be able to run the wider foams. I find the car just works well with foams, and that lets me leave my MSX in rubber spec.
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 11-20-2005, 10:26 PM   #11387
TXR2Racer's Avatar
Does anyone know where I might be able to purchase blue anodized aluminum front diffs for the 415?
TXR2Racer is offline   Reply With Quote
Old 11-21-2005, 01:24 AM   #11388
Burlap's Avatar
Send a message via MSN to Burlap
Surikarn didn't have time to take pics as he was being kicked out of Tamiya?
Burlap is offline   Reply With Quote
Old 11-21-2005, 02:51 AM   #11389
Jack2's Avatar
Ha !
Schumacher Mi4CX
Mugen MTX & MRX
Old 11-21-2005, 05:27 AM   #11390
maxoo's Avatar
the Jurgen front diff...
Send a mail at this man: [email protected]
he made an alu rear diff, an alu front diff and a spool. all in blue
maxoo is offline   Reply With Quote
Old 11-21-2005, 05:34 AM   #11391
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
NICE ONE!
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 11-21-2005, 06:39 AM   #11392
V12
V12's Avatar
As maxoo said, Jürgen is the only one making that blue aluminium diffs.
There was a website in Denmark showing all that staff from Jürgen but unfortunately this site don´t work anymore. Here´s a picture from the front diff halves.
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 11-21-2005, 06:41 AM   #11393
V12
V12's Avatar
Oops, wrong picture. This is the newer one using blades.
Old 11-21-2005, 07:06 AM   #11394
TXR2Racer's Avatar
Thanks for the info about the diff!!!! Any idea on how they cost?
Any recommendation on using the DJ Pro Module for carpet racing?
I'm currently running a Yok BD... Can't wait to run my MSX!!!
Old 11-21-2005, 07:13 AM   #11395
maxoo's Avatar
jurgen front diff = about 40€ (euros)
Dj pro modul isn't for carpet racing!!!
Old 11-21-2005, 07:17 AM   #11396
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
SMcpot, v12. croy, odawg..thanks to the early tips with the MSX steering rack. I did notice that the original 415 steering rack is drilled to same as the MSX with the exception of the milled bearing spacer.
I will epoxy the msx plate and clamp in a vice...this should work...in the meantime I'm going to use the original steering rack.
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 11-21-2005, 07:42 AM   #11397
TryHard's Avatar
Originally Posted by RobertF
how do i convert my 415 to a 415ms or can i??????
Hi,
Best thing to do is run through the main differences of the cars.
TRF415;
The original car came with -
3mm chassis,
TA04 style suspension
48.5mm hinge pins
Taller shock towers (with a 5th body post mounting on the front)
Straight edged bulkheads
TRF415 MS
2.5mm chassis
Evo4/MS Lightwieght Reversible suspension
46mm hingpins (suspension piviot blocks 2mm closer together)
Lower shock towers (with extra hole on the rear, and no 5th body post mount)
"curvy" edges to the rear bulkheads.
TRF415 MSX
as per the MS
Also, New bulkheads (including an extra stiffening brace NOT in the MSX conversion) shock towers (same mounting positions as the MS), and a new metal rear diff, allowing for external adjustment
There never was a conversion kit for the standard car to MS spec, however in reality all that was needed was the thinner chassis, the LWT suspension kit (with the shorter hinge pins) and the MS shock towers. I actually ran my old car with the 3mm chassis for most of the year, with the LWT suspension.
Now there is some confusion around regarding the MSX conversion (not the kit), as Tamiya say it won't work on a std 415, without the LWT suspesnion. Thats complete BS. Marc R at the IIC in Vegas ran an MSX with the standard suspension (and I'd assume a 3mm chassis) in Mod rubber, so it works fine.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 11-21-2005, 07:50 AM   #11398
I'm using the MSX conversion kit with the standard 415 arms and the 3mm chassis...works great with foams on carpet...
I will switch to the LWT arms, only because I want the 2 degree caster option that available with the LWT arms...not available for the standard arms.
Questions: When using the LWT arms and castor blocks with the HPI steering knuckles....(needed to clear foam tires only)....Do I put a spacer on the top or bottem of the HPI knuckles to take-up the space with the Tamiya castor blocks???
Old 11-21-2005, 08:09 AM   #11399
V12
V12's Avatar
I think from what I was reading here the washer goes on top. But putting the washer at the bottem also would affect rollcenter.
Old 11-21-2005, 08:14 AM   #11400
V12
V12's Avatar
And yes the MSX conversion kit also works for me very well on my std 415 with 3mm chassis and old suspension.
I also was confused when Tamiya said you need a 415MS for the conversion kit. But it´s good that´s not true.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
