Old 11-12-2005, 12:17 AM   #11221
MikeR's Avatar
Trader Rating: 15 (100%+)
Here's the quote from Dave Jun about that;
That’s a good question. Most people tend to relate the droop measurement by the actual distance from ride height that the suspension is allowed to extend and there is nothing wrong with that because it does make sense to think of it this way. Measuring from the top of the axle reflects a totally different number and it does take a little getting used to. However, to get the number you’re looking for, measure the diameter of the tire you plan to use. Let’s say its 63.2mm (Tamiya type A) now divide that in half and you get 31.6mm. Now add 2mm to that (2mm is half the thickness of the wheel axle) and you get 33.6mm. Then take your droop measurement from the top of the axle and subtract it from the 33.6mm. Let’s say you’re running 24.5mm from the top of the axle, your subtracted number is 9.1mm. Finally, subtract your ride height. If you’re running 5mm of ride height, you actual droop is 4.1mm. This is good to know if you’re switching from Sorex to take offs or any tire that has a different diameter, you can precisely account for the change accordingly. Again, good question. “Precision”
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆TEKNO☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 11-12-2005, 12:49 AM   #11222
hi. i wonder if you guys dremel mod your c-hub to get tighter turning?
also is there a cnc steeriing knuckle hop up? my steering knuckle screw got strip easy on the plastic
Doomah is offline   Reply With Quote
Old 11-12-2005, 01:04 AM   #11223
Trader Rating: 27 (100%+)
Is there a difference between the droop gauge from AE and HPI.
JoeyE is offline   Reply With Quote
Old 11-12-2005, 03:21 AM   #11224
TryHard's Avatar
I complied a word doc with all David Juns tips for droop here.
David Jun Droop Method
Very useful, and also runs through how to set-up roll bars as well
HiH
Ed
(P.S. Woooo just noticed I've past the 1000 post mark )
| THard.co.uk | Xray | MuchMore |
Old 11-12-2005, 08:04 AM   #11225
HiH
Ed
NICE! THANKS FOR THAT!
Here are a couple pix of my unfinished TRF415MSX.
Old 11-12-2005, 08:09 AM   #11226
what motor is in there
Matthew.H is offline   Reply With Quote
Old 11-12-2005, 08:33 AM   #11227
ORION 23T KATANA SL
Old 11-12-2005, 08:41 AM   #11228
thanks
Old 11-12-2005, 09:41 PM   #11229
Customworksking's Avatar
Trader Rating: 73 (100%+)
Arrow jun droop
HiH
Ed
I went throu his droop Method and I came up with the same droop the way I do it...His way is very precise..not sure what to do but it doe's help now U would think if the rear arm stops sooner as the weight go's forward wouldnt it lift the arm due to the less droop thus loosing rear bite...I know it should keep it from transfering as much
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 11-12-2005, 11:48 PM   #11230
MikeR's Avatar
You would think that but all it takes is that initial weight shift to lose rear bite or induce steering.... but go ahead, add even more rear droop
Old 11-13-2005, 03:17 AM   #11231
Where or how can I get a set of florescent colored TAMIYA springs?
Old 11-13-2005, 06:51 AM   #11232
Joel Lagace's Avatar
Those droop methods are fine, i use the hudy blocks to set the car the same left and right. But once your at the track and your making on the fly adjustments the simplest way of comparing droop(UPTRAVEL) to another brand car or simply your buddies car of the same brand is to measure ride hieght and then the ride height at full uptravel.
Typically the uptravel value is 1mm,2mm and 3mm ect ect. This is univeral across any brand car and weather or not your using foam or rubber. The blocks are great to "square" the car precisly. But 2 ride hieght mesurments is fast on the fly way of adjusting uptravel and comparing to other racers setups
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 11-13-2005, 07:10 AM   #11233
Send a message via AIM to GroffBall
Does anyone know where I can find an A block Bridge for the front?
GroffBall is offline   Reply With Quote
Old 11-13-2005, 07:20 AM   #11234
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
Default Shooters Alum Spool for 415
Would like to know any feedback from those who are currently using the alum spool by Shooters. Thanks for the responses.
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 11-13-2005, 08:28 AM   #11235
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
Its 53163 On-road tuned spring set (4WD Touring/Rally)
Give that a go!
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
