Old 11-01-2005, 01:53 AM   #11041
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
- double post... read lower post.
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 11-01-2005, 01:54 AM   #11042
F. Alonso's Avatar
Are you running that setup exactly or are there some changes?
Also, what is the grip level like of the track? What tyres? Bumps?
Simon Feigl
Old 11-01-2005, 02:36 AM   #11043
V12
V12's Avatar
Originally Posted by Customworksking
every time I print it it's on 2 pages how can I get it on 1 ?
Im using Irfanview for the JPGs and so its printing right on 1 page.
Its a free programm. http://www.irfanview.de/
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 11-01-2005, 02:38 AM   #11044
TRF415boy's Avatar
running on new crc carpet
I got it printed thanks I do have the 3mm chassis ....only thing I see is a lot of toe in the rear C-X wow this is my 1st year running 19t I ran stock for years and never ran more than 1deg ....I will give it a try thanks!
Remember I got the 0 rear hubs, so I've only got 1.5, which I don't think is a lot really. To be honest, I've never tried any less than that on any of my cars, but I've always been racing mod, I've only been doing 19T since recently.
TRF415boy is offline   Reply With Quote
Old 11-01-2005, 02:42 AM   #11045
see pic alonso
Doomah is offline   Reply With Quote
Old 11-01-2005, 02:44 AM   #11046
SMcpot's Avatar
Trader Rating: 22 (100%+)
Does anyone else have issues with the screw-in hingepins on the lightweight suspension? Basically, it seems that if the pins were held in by setscrews, this would minimize wear in the rear for those of us running aluminum hubs, as the hub is currently wearing against the pin rather than the pin wearing out the hole in the arm. This also seems to be a major cause of the slop in both the front and rear of the car.
SMcpot is offline   Reply With Quote
Old 11-01-2005, 03:05 AM   #11047
TryHard's Avatar
Originally Posted by SMcpot
Does anyone else have issues with the screw-in hingepins on the lightweight suspension? Basically, it seems that if the pins were held in by setscrews, this would minimize wear in the rear for those of use running aluminum hubs, as the hub is currently wearing against the pin rather than the pin wearing out the hole in the arm. This also seems to be a major cause of the slop in both the front and rear of the car.
I switched to the Evo4 styles pins with the grub screw for my MSX, and I deffiently think it's an improvement. I did find the pins to be quite tight in the arms, so just ran a drill bit through the holes, and that solved the prob.
Mr-s413bt; which setup was it? Also, what tyres etc.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 11-01-2005, 03:21 AM   #11048
Mr-s413bt's Avatar
Heya GUys.
Heres the link.
http://www.thard.co.uk/rc/TRF415/setups/ashby(MSX).jpg
Except i ran D and D on the front and b and D on the rear!
I just can't seem to get it to turn/grip mid corner.......
CS-27's, track is medium traction, ashphalt.
Glenn
Mr-s413bt is offline   Reply With Quote
Old 11-01-2005, 03:26 AM   #11049
F. Alonso's Avatar
I'd say that you may want to try narrowing the track width of the front and rear of the car. I am using XB X for the rear with 1 degree hubs at the moment and the car works nicely. Also using C A on the front as the swept arms having given a bit more mid corner steering. I'm still lacking steering a bit, but the car is ultra consistent. You could also try raising the rear toe blocks evenly by 1mm. When I get a chance, I will write out my setup and PM you.
Simon Feigl
Old 11-01-2005, 05:05 AM   #11050
F. Alonso's Avatar
Mr-s413bt - You got PM.
Simon Feigl
Old 11-01-2005, 06:20 AM   #11051
Trader Rating: 27 (100%+)
[QUOTE=Rick Draper]
Thanks Rick. BTW, what tires are those?
JoeyE is offline   Reply With Quote
Old 11-01-2005, 06:49 AM   #11052
Those are T27's used as a control tyre in 97 i believe. they are very cheap and are not belted but good fun on carpet
ukmaxx is offline   Reply With Quote
Old 11-01-2005, 08:22 AM   #11053
Customworksking's Avatar
Trader Rating: 73 (100%+)
Default car
yah I also have 0 hubs I run .5 deg for stock the less toe the faster/freer ..this will be the 1st time I try the same tire all around I see everyone runs sorex24's what u think CS22 or CS27's...I ran 27 ft 22 rear in stock..thanks
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 11-01-2005, 08:44 AM   #11054
SMcpot's Avatar
HiH
Ed
Thanks Ed....EVOIV pins it is, then
Old 11-01-2005, 01:09 PM   #11055
jw92656's Avatar
Lightbulb
Just ran into this post. I was working on my car trying get it setup for the SoCal GrandPrix. I am running the MSX kit, and read a few posts here about the steering problem. I think I have found a minor design flaw in the 415, that the EVO4 (I also own) doesn't have. Look at the carbon link for the two aluminum, center steering arms. On the 415 the outer bolt heads that hold the ball stud hit the aluminum arm before the steering knuckle car go full lock to the left and the right. I had my car all set up last night, and was going through the EPA on my radio when I noticed it hitting the bolt, and not turn all the way. I have tried repositioning the carbon bracket with no luck. The only thing I can think of is to somehow extend out the bracket about 3-4mm and adjust the toe accordingly it will allow the arm to go full lock to lock. I am also considering tapping a ball stud to the top of the plastic hub, and seperating the hub carrier bolts, from the steering knuckle. I suspect under load there is a binding effect going on here.
jw92656 is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
