Like Tree2Likes
Tamiya TRF415
Old 03-05-2004, 10:35 AM
  #1081
jeffreylin's Avatar
Originally posted by tiggersz
The blue shocks are not fluorine coated. If you look at the blue and red shock kits the bodies are still the normal color and the rest is red or blue.
Yes they are.
jeffreylin is offline
Old 03-05-2004, 10:41 AM
  #1082
V12
V12's Avatar
How is the position of the body posts? Will a body made for the EVO3 work with same holes for the 415 also?
V12 is offline
Old 03-05-2004, 10:44 AM
  #1083
jeffreylin's Avatar
Originally posted by rtypec
Come on guys lol. Any way you look at it, your still using some pretty damn smooth shocks. BTW, the textured shock top and bottom pieces are really nice, makes it easier for them to screw on. Also, the aluminum color with o-ring locks in the spring setting. I don't run the aluminum top hat thingy as I believe it adds weight when coupled with the connecting hardware that you need to add. Also, I use the plastic spring retainers (again weight savings). But if you want bling bling.....
The spring retainer adds only 1g for all 4 of them...
Here is a picture of my 415:
Old 03-05-2004, 10:47 AM
  #1084
jeffreylin's Avatar
Oops, here it is:
Old 03-05-2004, 10:50 AM
  #1085
Regional Moderator
Im sure this has been asked but once more the thickness of the chassis ?
Ko Racer is offline
Old 03-05-2004, 10:53 AM
  #1086
jeffreylin's Avatar
3mm
Old 03-05-2004, 10:55 AM
  #1087
jeffreylin's Avatar
Unfortunately not. I was hoping it will since I too have an EVO3. all 5 holes are different.
  #1088
Regional Moderator
3mm
Thank you so its like the MY02R then chassis wise does it have the 3D cut outs in the bottom?
Ko Racer is offline
Old 03-05-2004, 11:00 AM
  #1089
JeffreyLin
If you look at the package the body of the shock is not blue. The rest of the parts are. They are talking about the full blue bodied shock from the M2
JC
tiggersz is offline
Old 03-05-2004, 11:05 AM
  #1090
jeffreylin's Avatar
Not sure what 3D cut outs are but here is a picture of the chassis:
Old 03-05-2004, 11:10 AM
  #1091
jeffreylin's Avatar
Originally posted by Fire
i wonder why they don't include the TRF blue shocks
JeffreyLin
JC
tiggersz, they are talking about exactly the shock I am talking about, the TRF blue shocks, not the ones from the M2.
Old 03-05-2004, 11:14 AM
  #1092
Regional Moderator
3D Tech chassis
Ko Racer is offline
Old 03-05-2004, 11:16 AM
  #1093
JeffreyLin
Ok my bad. When I think of blue shocks I think of the M2 ones since they are truly blue and not fluorine coated and the New blue ones the bodies are the normal fluorine coated shock body with the blue pieces.
JC
tiggersz is offline
Old 03-05-2004, 11:22 AM
  #1094
V12
V12's Avatar
Thanks for that information. Seems I will stay completely with my EVO3 as I just have finished a bunch of bodies and don´t like making some new ones again.
V12 is offline
Old 03-05-2004, 11:31 AM
  #1095
rc-zombies's Avatar
3D Tech chassis
KO..
I think the motor area is the only place that got the 3D treatment.
rc-zombies is offline
