Old 10-24-2005, 10:19 AM   #10891
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Originally Posted by Carl Giordano
When I used the 3mm shim in the rear, I felt it was too tall.
The 3mm's can be a bit thinner, i took some plastic "shims" that nearly slid through, then took a sand paper and made them so thin that they slid through smoothly. Then i glued the shims on the posts so i won't have any loose plastic pieces rolling on the floor
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Savöx - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 10-24-2005, 10:58 AM   #10892
koabich's Avatar
Send a message via Yahoo to koabich
Originally Posted by TRF415boy
DESIGNED FOR ? I don't know where you have seen that really. It was designed for the TRF 404X, which later became the TRF 414 and from what i know, it hasn't been designed for FOAM. As far as I know, it's just a coincidence that it works well on high grip with foam. You can read that article about the development of the TRF 414 series.
Having said that, I can recall of Charlie Suangka saying he used the LW suspension indoors with foam, so I don't see it being a big problem. I myself use it on carpet with rubber.
Actually, this was all discussed long ago on here. I did not make this up but was from an interview with David Jun. He disccused the difference between the 2 suspensions and why Tamiya saw a need for 2 different suspensions on the same car. And you are right in saying the A-Arms of the car are old, but the suspension geometry from a 415 is completely different that that of a 414. The 415 has different shock towers, camber locations, wheelbase...etc.
I never said the stock suspension was designed for foam either. I said it was designed for tight tracks. It just so happens that tigh tracks are usually carept tracks and that foam is mainly run on carept.
Hey, if you like the LWT Arams on carpet with foams, try the standard arms, you may like them better.
koabich is offline   Reply With Quote
Old 10-24-2005, 12:03 PM   #10893
Quick question, what's the difference if you compare the regular X-A-B-C-D Blocks with XA-XB-XC-XD blocks?
Old 10-24-2005, 12:12 PM   #10894
Customworksking's Avatar
Trader Rating: 73 (100%+)
Default x-xb-xx
width ...the x blocks are narrow.if your car does not react fast enough use these blocks
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 10-24-2005, 12:17 PM   #10895
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
Originally Posted by Customworksking
did u need to cut for the front belt I did'nt
No, there is no need to sand the top plate to clear the belt...I just did it to be safe...if the blet bounces around.
I did notice that the blue washers you used do not look like the stock tappered washers from the standard 415.
If you notice I used them so the steped portion would rest within the larger center holes for the graphite brace.
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 10-24-2005, 12:20 PM   #10896
Thx for VERY quick answer!
Old 10-24-2005, 01:18 PM   #10897
geeunit1014's Avatar
Originally Posted by koabich
You are better off sticking with the stock arms for carpet. You may have a hard time finding a good carpet setup with the LWT Arms.
The standard 415 with standard arms geometry was designed for tight, high traction tracks (typical carept tracks) where the LWT Arms were desinged for long, flowing tracks (typical asphalt).
If you switch to the standard arms, I have a killer carpet setup for foams if you want it.
kool where could i find this, i think ill probably put the standard arms on for carpet, ive been outrside all summer
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 10-24-2005, 01:19 PM   #10898
Ballsie's Avatar
Default My latest addition
Arrived from RCScoringPro today - Thanks Doug!
Tamiya TRF415-1.jpg   Tamiya TRF415-2.jpg   Tamiya TRF415-3.jpg   Tamiya TRF415-4.jpg
Ballsie is offline   Reply With Quote
Old 10-24-2005, 01:26 PM   #10899
TRF415boy's Avatar
I don't run foam... And so far, LW have been quicker for me everywhere, and no problems with durability, I've broke a C-Hub in 8 months running it and that's it (and a few HPI front hubs, eek)
TRF415boy is offline   Reply With Quote
Old 10-24-2005, 01:59 PM   #10900
Send a message via AIM to odawg315
prick, i was bidding against you and ran out of time!!!
odawg315 is offline   Reply With Quote
Old 10-24-2005, 02:27 PM   #10901
Ballsie's Avatar
So it's your fault that I paid so much for it
Old 10-24-2005, 02:31 PM   #10902
V12
V12's Avatar
This is my MSX now based on the 3mm chassis and the old suspension. But used the 6mm adjusters from the EVOIII for the upper arms as it´s easier trying different shimming for rollcenter changes. Also less play. For the rear a different diff is used. Some of the screws were replaced with steanless steel versions but didn´t have enough here for replacing all of them.
Tamiya TRF415-img_3550-2.jpg   Tamiya TRF415-img_3546-2.jpg   Tamiya TRF415-img_3543-2.jpg
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 10-24-2005, 02:49 PM   #10903
maxoo's Avatar
Is it a Jürgen diff??
maxoo is offline   Reply With Quote
Old 10-24-2005, 03:13 PM   #10904
yup, i tried to go up to 350 at the last second but i missed it!!
Old 10-24-2005, 03:18 PM   #10905
TRF415boy's Avatar
duuuude that's a BIG fan on that motor, I guess you're not fussed about being underweight
PS : I know you're taking it off before racing, i'm only messing
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
