Old 10-20-2005, 03:59 PM   #10831
TRF415boy's Avatar
Originally Posted by Mal
Well ... what ever the reason for the chatter ... There are two of us using spools at our track. I'm using the delrin spool and my friend is using the speedtech steel spool. Neither one makes noise while cornering ... if there is a noise it's not a noise you can hear while the car is on the track. This isn't a big track either, it's an indoor 45x85 carpet track.
One thing that I have noticed is the variation of quality from CVD to CVD. I've noticed some have CVDs that have a notchy feeling when you pivot them at a certain angle. I've also noticed other CVDs that aren't notchy at all, they spin free even at full steering lock.
Ok let's put it this way : Why the heck did Team Losi went into great lengths to develop a driveshaft joint that reduces chatter, if the actual joints are real CVD and spin free and at constant velocity ? I'm telling you, all actual RC design driveshafts are not constant velocity drive and thus do not deserve to be called CVD.
The only problem is that no one has been able to make constant velocity driveshafts for RC cars, not to a reasonable cost and weight anyway.
Good for you you don't have chatter, still when i go from a spool to a one way i feel a huge difference in mid corner steering.
TRF415boy is offline   Reply With Quote
Old 10-20-2005, 04:27 PM   #10832
Mal
Registered User
I'm not doubting you regarding the CVDs. I'm just stating that there are different degrees of chatter. Don't know if it's set-up or what but at our track we don't have any noticable chatter. The point I'm trying to make is that the chatter can some how be decreased.
Mal is offline   Reply With Quote
Old 10-20-2005, 04:46 PM   #10833
TRF415boy's Avatar
Yes, you can decrease it, a delrin spool helps because it allows some degrees of twisting, but on high grip carpet spool is definately not the quickest option, one way is miles quicker. Also, keep the driveshafts in good condition : change the crossjoints regularly, make sure they are lubed, etc.. all these little details can make a difference.
Old 10-20-2005, 05:02 PM   #10834
Mal
Registered User
Not sure if a one-way is a lot quicker. I think it depends on your set-up. With a spool you can drive a lot more agressive. It also makes your car more consistant. When you race on a tight indoor track with traffic, consistent is a good thing. Up until 2-3 months ago I hated spools and prefered one-ways then I decided to give the spool another try. All I'm trying to say is don't rule out the spool as a tuning option.
Old 10-20-2005, 05:22 PM   #10835
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
Thumbs up
Originally Posted by Jack2
You dont have to remove the diff from the bulkheads with the normal diff, you just have to pop one end of the top rear link off and remove the right rear drive shaft from the diff outdrive and you can adjust the diff. Only takes around 30 seconds.
Thanks for pointing that out. I thought I was the only one (probably there's more than you & me) have had thought of that way of adjusting the rear diff w/out removing it from the bulkheads. The difference w/ my 415, is that my upper links are connected to the F/R shock towers (orig 415 towers) and uses the the inner linkages based from the TRF414M & EVO3 set-up. I don't need to pop the ballcup, I just lossen up the screws or just the remove the outer hinge pin via the e-clips (standard arms) or hinge pin (screw type/set screw) light weight rev arms. I also did the same thing when I installed the MS conv kit on my 415 & kept the same linkage set-up which are directly screwed into the bulkhead. For the rear bulkhead though, I had to attach the said linkage on the alum rear upright. Here are some pics from the TRF414M II & TB EVO III SE to give you an idea what I did to the linkages on my 415.
Tamiya TRF415-trf414m2.jpg   Tamiya TRF415-trf414m2.b.jpg   Tamiya TRF415-tb-evo-iii-se.jpg   Tamiya TRF415-tb-evo-iii-se.b.jpg
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 10-20-2005, 07:20 PM   #10836
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
as promised, the photos from my earlier post....lets see if this works
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 10-20-2005, 07:23 PM   #10837
geeunit1014's Avatar
i never figured out what the hack the seconf turnbuckle in the front is for. could you clue me in
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 10-20-2005, 07:27 PM   #10838
shit....i can't get it work...I hate computers...any help
I have a MAC, which I'm not familar with...I have the photos saved as JPG...what do I have to do to attach the photo from the RCTECH reply section???
Old 10-20-2005, 07:37 PM   #10839
I keep getting an error message saying the file type is too larger 293.3KB my photo is 1.69MB???
Now I have no clue what to do?
Old 10-20-2005, 07:38 PM   #10840
KoE
KoE's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to KoE
those are torque rods; somewhat popular and hated on 414 variant and 04
Yo!
KoE is offline   Reply With Quote
Old 10-20-2005, 07:48 PM   #10841
JRRobiso's Avatar
Thumbs up
If you're asking about the 2nd pic I posted, it's a torque rod that's connected to front C-hubs. The purpose for it & I'm just guessing it, it's probably to support the front C-hubs against frontal impacts especially when the wheels are in a turning position & also probably to give a more precise steering response with less slop. But as I said it's just a guess & I eventually took it off my 414M when they came out w/ the hard front upright.
"Carl Giordano - shit....i can't get it work...I hate computers...any help
I have a MAC, which I'm not familar with...I have the photos saved as JPG...what do I have to do to attach the photo from the RCTECH reply section???"
At the reply portion section Carl, goto to ADDITIONAL OPTIONS & click on Manage Attachments. You'll be able to upload from your MAC & will post when you hit the Submit Reply button.
Old 10-20-2005, 08:39 PM   #10842
Customworksking's Avatar
Trader Rating: 73 (100%+)
Default chatter
thanks for all the chatter on the chatter! It is true there is less with a 1way ves spool...I did add my ft and rear supports to the msx and wow no flex will post pic soon
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 10-20-2005, 10:21 PM   #10843
maxepower's Avatar
Exclamation RE:PHOTO ISSUES!
Right click on the picture and go to properties, then change the resolution and quality to low, so you can bring the amount of memory used to display the picture, right now you are at 1,690 KB and like it says maximum is 294 KB.
Play with the properties until it accepts the picture in the attachment.
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 10-20-2005, 11:06 PM   #10844
Default msx
0-flex
Old 10-20-2005, 11:09 PM   #10845
Default msx zero flex now
works well
Tamiya TRF415-s4010007.jpg   Tamiya TRF415-s4010005.jpg   Tamiya TRF415-s4010003.jpg
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
