Old 10-18-2005, 12:39 PM   #10771
maxepower's Avatar
Talking RE:RE: TAMIYA SPOOLS!
Originally Posted by rtypec
There may be steel or some sort of metallic outdrives coming out for the TA05's spool. This should fit the 415's spool. I believe spares are also in the works.
All right, that's what I'm talking about! Thank you TRF Racing!! More delrin please! I haven't broken any outdrives yet, but my son has broken 3. Two was his fault but one wasn't! Either way it would be good to have extras, just in case!!!!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 10-18-2005, 12:40 PM   #10772
geeunit1014's Avatar
maxepower, they do sell just the outdrives, part #sp023, scroll down on the link to see them but i dont know if they fit on the tamiya spool, maybe but probably not.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 10-18-2005, 03:50 PM   #10773
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
Exclamation
TRF415 MS Conv Kit
Just received my kit today via UPS (free shipping) from Ultimate Hobbies. Upon opening the box, I was expecting a t-shirt (based from prev postings) hoping the kit came from Japan. But instead, I ended up getting the decal sheet for the 415 MS kit. Did any of you get a 415 MS decal sheet as well? Don't get me wrong, I appreciate the decal sheet since I was planning to get one when I order my next batch of spare parts again.
Haven't put it together yet since I'm still waiting for the Titanium screw set I ordered from Steve (SpeedTech) which the last time I checked is due to arrive tomorrow as well. For now just going to prep up the G-parts with CA glue.
Parts look awesome as described by others....worth the $$$$.
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 10-18-2005, 04:47 PM   #10774
Static_racing's Avatar
I got my MSX kit about a month ago. Its alittle more flexy then the tripple deck design but the parts are like jewlrey. Does anyone know where I can get a 3mm chassis for it or does someone make a thicker one?
[COLOR="Blue"]Mike Kling[/COLOR]
[COLOR="Red"]"BIG FEATURES INC."
RED [COLOR="Black"]Cup Racing[/COLOR][/COLOR]
Team Driver For:
[COLOR="DarkOrchid"]Schumacher USA[/COLOR]
e[COLOR="DarkOrange"]X[COLOR="Black"]press Motorsports[/COLOR][/COLOR] "You've Been Tagged!!"
John's [COLOR="Red"]BSR [COLOR="Black"]Racing Tires[/COLOR][/COLOR]
[COLOR="Red"][FONT="Comic Sans MS"]MW [/FONT][/COLOR]Designs
TXD Skin Graphix "Skin 2 Win!!"
[COLOR="SeaGreen"]Final Thoughts Racing[/COLOR]
Static_racing is offline   Reply With Quote
Old 10-18-2005, 06:29 PM   #10775
Unfortunately there dont seem to be any 2.5mm chassis available, i had to get a 3mm chassis from Hobbymania recently. it was all i could find. The car feels a lot stiffer with this chassis, i think i would actually prefer the thin chassis for Asphalt Rubber.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 10-18-2005, 07:11 PM   #10776
hi. i am looking at getting a trf415 as my first 1/10 tourer.... i was wondering what else i need to get me started racing? what sort of spares should i carry around?
i already got electronics and charger. no batteries or tires as yet.
qwerty is offline   Reply With Quote
Old 10-18-2005, 09:15 PM   #10777
Customworksking's Avatar
Trader Rating: 73 (100%+)
Default spool
Help I just put the spool in and the msx kit what I have is a real bad chadder when I turn L/R Ide say the 3 1/4 turn to max ....I know I dont need all the steering but I setup my car to max and take it out w/dual rate..the bearings are new I moved the arms etc...any help will do!
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 10-18-2005, 09:22 PM   #10778
Customworks, check that your universals a properly lubed and clean, and also use some thick grease on the spool outdrives.
Qwerty the 415 is a very complete car, for racing in Australia you dont need any other options or accessories. I run modified and when i was preparing for the TCS nationals the only thing i had to change was to replace the spur and pinion with a Tamiya unit.
Old 10-18-2005, 10:03 PM   #10779
CND
Send a message via AIM to CND Send a message via MSN to CND
I just bought a 415 as my new drift chassis and wow, so smooth and controllable.
CND is offline   Reply With Quote
Old 10-18-2005, 11:05 PM   #10780
Default need a #
can anyone tell me the part # for the spur gear adapter that u put on after the spur so that it lay's flat its carbonfiber round w/2holes ...I got my car when it 1st came out and I see they added it to kits now..I looked at speedtech,tamiyausa,stella....w/out it I got to jack with it to get the spur flat due to 2 screws it tends to worp the spur...thanks
Old 10-19-2005, 12:31 AM   #10781
CND
Hey just a quick question if anyone knows, Is there a rear spool diff for the TRF415 made? Im about to lock my Ball diff with Araldite but i would prefer a proper unit.
Im getting chronic understeer due to the rear wheels spinning at different speeds, regardless of how much i tighten the ball diff(Without going too far as i dont want the bolt to snap)
Thanks heaps
Jack
Old 10-19-2005, 01:00 AM   #10782
Rear spool???? i assume this if for your monging around on plastic wheels? If so to lock any diff, take the diff balls out, cut header cards out in the shape of the diff rings, and bolt it all together, with the cardboard placed on the diff pulley instead of the diff balls, tighten up and instant spool.
Old 10-19-2005, 01:38 AM   #10783
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Originally Posted by maxepower
Charlie ,
Will these fit on Tamiya spools and do they sell just the outdrives?
these are for the spools Max. Give Philip a call..he'll give u teh 411 on them.
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
TEAM ASSOCIATED|REEDY|HITEC|PARMA|PROTEKRC|SWEEP|IWATA| RPM|AMAIN|CREATEX/WICKED/AUTOAIR PAINTS|CFX|CAL RACEWAY
charlie_b is offline   Reply With Quote
Old 10-19-2005, 01:42 AM   #10784
Jack2's Avatar
LMAO
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 10-19-2005, 01:50 AM   #10785
CND
Ok thanks for that, Its less permenant than the araldite so that way i can revert to ball diff's if i chose to waste my time scooting around on rubber tyres
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
