Old 10-17-2005, 09:27 PM   #10756
Customworksking's Avatar
Trader Rating: 73 (100%+)
Default msx
Martin, thanks for taking the time to help I will try your setup for rubber..Im going to put the DJ mod on and try it just to see how it works
as u I will up-date how it works...
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 10-17-2005, 09:36 PM   #10757
Joel Lagace's Avatar
Hey Martin, Perhaps you could share with us some tips on gluing rubber tires?
Check your PM
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 10-17-2005, 10:08 PM   #10758
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
Originally Posted by TryHard
hey all.
I've just updated the Universal spring chart on my site, turns out my supicisions were right, some of the values for the tamiya springs were off. This has now been corrected, with thanks to TRF415Boy.
Also made it easier to read off the values.
Hey, does anybody know how much tension is in the Spring Set for DJ Pro Module Suspension? Just a curiousity thing really and would be handy to know the figures. (Spring Set 53163 - Onroad tuned spring set)
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 10-17-2005, 10:28 PM   #10759
Default setup info
hey with the msx upgrade does the dj module work better on asphalt or does the standard lightweight rear work better with the msx I will be doing testing the next couple of weeks but I want your guys' input for a start, thanks in advance for any input.
Charles is offline   Reply With Quote
Old 10-17-2005, 10:54 PM   #10760
Trader Rating: 23 (100%+)
Maybe someone will have a compression rate tool. The approximations are...
The spring rate range for #53163 are:
Blue 10-11 lb
Yellow 8-9 lb
Red 6-7 lb
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 10-17-2005, 11:21 PM   #10761
maxepower's Avatar
Lightbulb RE: Tamiya composite battery hold down!
Originally Posted by tony montana
Anyone know how to make a battery hold down, Or if someone makes one? I hate taping batteries.
Tamiya makes two composite battery hold downs. One is for the TA05 and the other is for the 415. It comes with the lower chassis kit for stick packs batteries. I couldn't believe my eyes when I saw it. But the lower deck is $90.00
or I would have bought it myself! I would think the composite TA05 would fit, you would need to drill holes in the chassis of coarse!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 10-17-2005, 11:50 PM   #10762
maxepower's Avatar
Unhappy Out drives for Tamiya Spool!
O.k.
Does anybody know if Tamiya is going to sell just the outdrives for their spool, and if not does any aftermarket company have them? Anybody?.......................Anybody?........... ...........Anybody?...................
Old 10-18-2005, 12:40 AM   #10763
Originally Posted by maxepower
O.k.
Nopee....Never heard of.Your best bet would be to see whether you local tamiya distributor can special order those for ya...
Good luck
Ben.C is offline   Reply With Quote
Old 10-18-2005, 04:16 AM   #10764
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
O.k.
Here ya go MAx.
The good guys at Kenon Hobbies Carries them. They are local too!
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
TEAM ASSOCIATED|REEDY|HITEC|PARMA|PROTEKRC|SWEEP|IWATA| RPM|AMAIN|CREATEX/WICKED/AUTOAIR PAINTS|CFX|CAL RACEWAY
charlie_b is offline   Reply With Quote
Old 10-18-2005, 05:09 AM   #10765
TryHard's Avatar
Actually TRF415boy has calculated the rates, and there now on my chart. the fluro reds come in sofest, at around 9.1lb, the fluro yellows come in at 10.9, and fluro blues at 13.
btw... the link to the chart is currently wrong, if you want the new one, use this for now, I can't actually change it till I get home.
http://www.thard.co.uk/rc/TRF415/set...ng%20Chart.xls
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 10-18-2005, 09:01 AM   #10766
F. Alonso's Avatar
Thanks TryHard. Surprising to see them that close to the other spring set actually. Like... only 2 pounds between yellow and fluro red basically.
Simon Feigl
Old 10-18-2005, 10:15 AM   #10767
rtypec's Avatar
O.k.
There may be steel or some sort of metallic outdrives coming out for the TA05's spool. This should fit the 415's spool. I believe spares are also in the works.
rtypec is offline   Reply With Quote
Old 10-18-2005, 10:50 AM   #10768
Default spool
whats wrong with the ms oneway outdrive's ..I mean I pulled out my 1way and put the spool in.. do they make out drives for the spool? due to TCS racing I need to keep my car all Tamiya...
Old 10-18-2005, 12:26 PM   #10769
maxepower's Avatar
Exclamation TAMIYA SPOOLS!
That's exactly what I'm saying! I would also like aftermarket ones for practice and then use Tamiya outdrives for TCS!
Old 10-18-2005, 12:34 PM   #10770
maxepower's Avatar
Exclamation RE: TAMIYA SPOOL
Originally Posted by charlie_b
Here ya go MAx.
Charlie ,
Will these fit on Tamiya spools and do they sell just the outdrives?
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
