Old 10-12-2005, 06:10 PM   #10636
BritRacer's Avatar
try tryhards web page, he posted at the top and its in his signature.
It worked not too bad for me!
Would like to try more though
BritRacer is offline   Reply With Quote
Old 10-12-2005, 06:54 PM   #10637
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Originally Posted by Keith Billanti
dialed...
LMK price asap.. ill try to call them today.. im on the east coast though
do you think they have the HPI spindle carriers ( i run foam)?
Keith
Keith I'll be honest. I can't beat the price at ultimate. We don't have the carriers, but we can get them in for ya. and make it one big goodie bag. I'll be there tomorrow eve call me and I can figure it all out with ya. heck I'll be there till midnight your time!
tamiyarcracer is offline   Reply With Quote
Old 10-12-2005, 07:12 PM   #10638
maxepower's Avatar
Exclamation 415 Lt wt. reversable conversion kit!!!!!!
Maxepower and Tamiya racer.. you guys are awesome.
TR/ or anyone, the TA04 set, you need different swing shaft to run in 415? Meaning CVD shaft?
Maxepower, is this the TA04 set @ ultimate? or is this specific to 415?
owe'in ya both a beer-
Keith
This is the 415 kit that Ultimate Hobbies has. Tamiya isn't making this kit anymore but like I said Ultimate has (4) of the 415 kits, which are probably the only ones in existance on the planet. So these kits come with the 46MM swing shafts and all the shims, spacers, screws, uprights, arms,connectors, etc. etc.
So you better get one before their all gone!!!!!!!!!!!!!!!! So.........Don't say I didn't warn you!!!!!!!!!!!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 10-12-2005, 07:21 PM   #10639
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
Tamiyaracer/ I appreciate it.. but I did pick one up from Ultimate..
I also picked up an extra set of arms.. and I tried to get new ball cups as the previous owner roached mine.. but they were out..
I did find the HPI hubs at MY LHS... what bearinds will I need to run these??
Keith
OUT
Keith Billanti is offline   Reply With Quote
Old 10-12-2005, 08:24 PM   #10640
Send a message via AIM to odawg315
8 5x9
odawg315 is offline   Reply With Quote
Old 10-12-2005, 08:27 PM   #10641
is that 8.5X9 or 8 total, 5x9??
i have never heard of a 8.5X9
Keith
OUT
Old 10-12-2005, 08:47 PM   #10642
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
Originally Posted by MDawson
Simon-
Check all of the radio trims, binds in the suspension, tweak and ride height.
Which chassis did you mount the MSX kit on?
Mod, stock or 19T?
Rubber tire? Bad set of tire perhaps? Sidewalls?
Suspension is great, the ride height is around 7mm all around, radio trims seem to be all good and the car appears to be fine tweak wise. I mounted the MSX on an MS chassis and I have to say that while my car was a bit funny to drive because of the tweak, I generally agree with you on the behaviour of it. I believe that it is something however that you can dial out so I'm not typically fussed. I may try something like the center post mod but for the moment I'm just going to view the MSX as a different car to the MS, so therefore requires a different setup.
Ummmm, I run Modified and with Rubber tyres, Take Off 27s actually. I did change tyres as well as I thought that might have been what the cause was but it still didn't appear to be much different. When I do find the cause I'll certainly let you guys know.
BTW - thanks for everyone's input on my problem.
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 10-13-2005, 01:54 AM   #10643
V12
V12's Avatar
Keith
The HPI hubs are using 10x5 bearings. And yes 8 of them if you want using them front and rear.
9x5 bearings are wrong, these are for the 415MS/EVO4 hubs.
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 10-13-2005, 02:31 AM   #10644
V12
V12's Avatar
The postman just brought my 415 MSX kit.
But the Tamiya T-shirt also isn´t included.
In the next days I will rebuild my 415 then using the new parts.
Old 10-13-2005, 02:36 AM   #10645
Oh well....
Mine too didn't came with the T shirt.But then you probably can't fit into it either...Its like very small like XS or something...??
Ben.C is offline   Reply With Quote
Old 10-13-2005, 02:41 AM   #10646
V12
V12's Avatar
At least I got a MSX what wasn´t that easy. So better a MSX than a T-shirt.
Old 10-13-2005, 02:43 AM   #10647
TryHard's Avatar
When i spoke to Dave Spashett at the Barham mod national, he told me that becuase the CoG of the MSX is lower, you can get away with running the car softer, as this will allow the car to roll more, and hence generate more grip.
I think the two things I saw were
1) shocks in position two on the arms (outside hole, two hole side)
2) slightly softer springs, HPI Blues I believe
However, I do think that this was with a 3mm chassis plate... but not entirely sure. I'm gonna look into swapping between 2.5 and 3mm plates on my MSX, and see what diff i can find. (don't particularly want to do it... pain in the arse, as I know the 3mm one is tweaked badly on the front right, and has been for about the past year ... thank F for an MIP tweak station!)
@ MDawson; If you could, can you post some pics of the centre post? Quite intrigued as to how you've mounted it with regards to batts and so forth. You could email them, and I'll post them onto my website (pm me for an email address).
Regards
Ed
| THard.co.uk | Xray | MuchMore |
Old 10-13-2005, 02:43 AM   #10648
Oh Yeah...
Old 10-13-2005, 02:47 AM   #10649
TryHard's Avatar
t-shirt too small... fits me "snuggly" apparently, according to some of my so-called mates ..... and I'm generally a UK L or XL.
Personally I think it shows off my "curves" wonderfully....
Old 10-13-2005, 05:51 AM   #10650
maxoo's Avatar
what is the better for carpet tracks: use a standard 415 with the MSX kit (3mm chassis) or the MS version with MSX kit (2.5mm chassis+LWS)???
thanks.
maxoo is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
